Old 08-09-2011, 06:45 AM   #3391
tomracing's Avatar
Originally Posted by scoyle View Post
What is the UNIVERSAL AXLE PIN COVER 68759 for?
I think the explanation on the hb website explains it sufficiently:
Originally Posted by HB website
This anodized aluminium collar replaces the set screw in the universal axle for quicker axle rebuilds and increased durability. It surrounds the pin to prevent it from slipping out.
It is the same as using the cup that was around the old pom outdrives just in cool purple and no sanding required (at least I assume they made sufficient clearance)
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 08-09-2011, 06:45 AM   #3392
mazmo's Avatar
When using this cover, grub screw not needed to hold axle pin in ... this reduces binding, make axle operation very smooth
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 08-09-2011, 07:29 AM   #3393
scoyle's Avatar
"at least I assume they made sufficient clearance" - I was just trying to imagine how this would look as I wondered about the clearance.
I have ordered a set anyway so will see how they go... yep they are available in the UK.
scoyle is offline   Reply With Quote
Old 08-09-2011, 02:45 PM   #3394
jmackani's Avatar
Trader Rating: 14 (100%+)
Default Getting out
Putting it up for sale: Hot Bodies TCX Roller
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 08-09-2011, 03:32 PM   #3395
Mike Haynes's Avatar
I have been using the top ones, these are a must have
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 08-09-2011, 06:27 PM   #3396
T.O.P. have some parts like this
mr.ng is offline   Reply With Quote
Old 08-09-2011, 09:09 PM   #3397
Team STPN's Avatar
I agree i use them too
Team STPN is offline   Reply With Quote
Old 08-10-2011, 12:15 AM   #3398
AGNO's Avatar
Yes, I will also use, less chatter and more reliable by removing the screw.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 08-11-2011, 04:53 PM   #3399
RC MARKET's Avatar
For Cyclone DCJ
& TA06 Gear Diff fit for TCX to use , but need change TAMIYA Drive shaft .
RC MARKET is offline   Reply With Quote
Old 08-13-2011, 06:22 AM   #3400
cheehtae's Avatar
Trader Rating: 15 (100%+)
Thinking of getting aTCX, my question is are the c hubs, arms and knuckles still the weak point? Thanks in advance.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 08-13-2011, 07:05 AM   #3401
Dog Bone's Avatar
Yes.
For me personally, knuckles are the bane of my TCX. It seems that if I touch a board, I break. However, once I ground down the axles so they didn't protrude past the wheel nuts, my breakage rate went way down.
I've also used x-ray knuckles - they seem to be a bit more robust.
I have also broken my share of arms. Not very many c-hubs tho.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 08-13-2011, 08:00 AM   #3402
Send a message via AIM to Matt W
Default New Tcx chassis
Hi,
Do we know when the new tcx chassis will be available to purchase?
(#68760 NARROW MAIN CHASSIS- 2.5mm)
Matt W is offline   Reply With Quote
Old 08-13-2011, 09:46 AM   #3403
RC MARKET's Avatar
Originally Posted by Matt W View Post
Hi,
where to see this item ?
Old 08-13-2011, 10:09 AM   #3404
Fjeld's Avatar
I use hpi pro4 arms in front, alum c hubs and trf knuckels. I have never broke non of them
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 08-13-2011, 10:53 AM   #3405
Pro 4 arms for me to. There way less brittle. Also running a Roche spool and Tamiya 46mm steel front drive shafts.
Car is very robust now
markrobinson is offline   Reply With Quote
