Hot Bodies TCX
Old 08-01-2011, 11:31 AM
  #3331
Trader Rating: 61 (94%+)
i got Cyclone TC Version. With Exotek upgrade chassie. with the 39 tooth Pullys
tcb22185 is offline
Old 08-01-2011, 08:52 PM
  #3332
Suspended
Trader Rating: 86 (100%+)
quick question of spec r top deck.
whats advantage of spec r top deck?
i measured my stock top deck and its same thickness as spec r (both 2.0mm) and its same shape.
littlealex is offline
Old 08-01-2011, 10:57 PM
  #3333
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
my bad, I have 37 tooth pullies. The 39 tooth pullies are fine, If your running the spec classes you will need to get the larger pinions for the tall ratios if your running 17.5 (as tall as 3.16 for huge tracks) with appropriate spurs. Just make sure you have the 20 tooth center pullies and you will be fine. The drive ratio didn't change from the TC to the TCX. Example, I just ordered pinions up to 60 tooth.
rx7ttlm is offline
Old 08-02-2011, 12:00 AM
  #3334
Korey Harbke's Avatar
The Cyclone TC has 18T center pulleys. I don't know of any 20T pulley that will work correctly, as they are designed to be secured with a setscrew on the TC. The TCX has a capture pin system that keeps everything together (and more compact), so the 20T center pulleys will not work. The diffs use a 39T pulley. You might be able to retrofit some Tamiya 37T pulleys, but you would also have to find some belts that fit correctly as well. For reference, the original cyclone, Hara/Surikarn Edition, and Andy More WCE edition all used 16T center pulleys, and 39T diff pulleys.
With the Cyclone TC, you just need to use some pretty small spurs. 88 or even a little lower is what you'll need, and some fatty huge pinions.
-Korey
Korey Harbke is offline
Old 08-02-2011, 09:43 AM
  #3335
spring71's Avatar
Smile
New products are arrived from RIDE at TQ
Click Here to see the new arrivals
Click here to visit TCX parts store.
Ride EVA bumper for TCX is now available.
FYI, Thanks.
spring71 is offline
Old 08-02-2011, 09:51 AM
  #3336
i can get this
http://www.rcmart.com/catalog/rc-cyc...th=595_870_890
and put this on it
http://www.rcmart.com/catalog/rc-sak...o-p-32891.html
did not mean to hijack your TCX Thread.
tcb22185 is offline
Old 08-03-2011, 12:44 AM
  #3337
frk
frk's Avatar
Default Question on HPI High Traction Arms
I would like to know from Mr. Korey if the use of HPI 31420 can be recommended even on the TCX model, and under what conditions. Personally I never understood the conditions under which the arms were used high traction. With little grip? More grip? With the heat? With the cold? Or work better on carpet? I've seen that are more soft and flexible (not as the standard arms) and I was very confused ideas. Could you give me an explanation? Thanks so much
frk is offline
Old 08-03-2011, 01:22 AM
  #3338
Ahhh... The high traction arms.
Well, I personally have never tried these arms on the TCX, or the Cyclone TC. I have always used the reversible arms because they are pretty awesome . But I will elaborate on my experiences on other cars I have driven in the past.
In lower grip conditions, I feel the soft arms can SOMETIMES be advantageous. They seem to make the setup window a little bigger (much like a softer chassis), and more notably steering around the middle of the corner. I'm not sure as to why, but the flex can make the geometry of the car change slightly (notably caster) as it goes through the corner. I feel maximum potential corner speed is lower though, so that is why I would only use super soft arms in very very extremely low bite conditions. Usually a little more durable too.
In high grip conditions, I have found they give really inconsistent results. Sometimes less grip, sometimes more. It really depends on what the tire is doing, and what the rest of the setup is like.
In the end, I still feel the carbon reversible suspension arms will be better in most conditions. Plus you get more tuning options!!! Hiro might jump in if he has some time in the near future and give his experience with the arms, as I don't have any direct experience with the arms on our cars.
Hope that helped a little bit???
Old 08-03-2011, 07:20 AM
  #3339
frk
frk's Avatar
Default Re
Thanks for your opinion Korey!
frk is offline
Old 08-03-2011, 08:10 AM
  #3340
I totally agree with what Korey explained. I think that they make the setup window just a little bigger. Ultimately to accomplish the maximum corner speed, i would still recommend the reversible arms.
Thanks,
Hi-LowBlow is offline
Old 08-03-2011, 10:27 AM
  #3341
What's the part number of these reversible arms?
markrobinson is offline
Old 08-03-2011, 11:11 AM
  #3342
Barry_Hughes's Avatar
67717 - the ones that come in the kit!
Barry_Hughes is offline
Old 08-03-2011, 01:02 PM
  #3343
Ah sorry for being stupid!
Old 08-03-2011, 01:25 PM
  #3344
ZEe_NYC's Avatar
Trader Rating: 78 (100%+)
really interesting to read that people are/were using such small spurs/large pinions in their TC's.
i'll be running 17.5, soon... just reading up on FDR's for a med/large track, and it seems that i've been finding that 3.5-4.5 FDRs are optimal (read: i'm not running boost/turbo/advance timing software).
wondering if anyone actually fitted 20 tooth center pulleys on their TC in the past.
ZEe_NYC is offline
Old 08-03-2011, 01:42 PM
  #3345
im thinking about Fitting 20tooth pullys to my Tc's But Need to do the homework to make sure i only spend the money 1s if you go back a page i posted a link to some 3racing parts that i think i might beable to make work..
tcb22185 is offline
