Old 07-14-2011, 09:15 AM   #3256
Originally Posted by EAMotorsports View Post
Hirrrroooooosan. Nationals?
EA
What's up EA! Yes i will be there. Are you going too? I hope i will see you there.
Hi-LowBlow is offline   Reply With Quote
Old 07-14-2011, 09:47 AM   #3257
Korey Harbke's Avatar
I forgot to mention, I already put some of the Exotek 46mm driveshafts on my car with good results. I had a small (read as huge) mishap in a high speed section and they survived the unscheduled impact really well .
I did notice a tiny bit less aggressive steering in comparison to the stock aluminum driveshafts, but that is probably due to the small amout of additional rotaional mass that comes with steel. I'd still recommend them if you are seeking a more durable front end setup.
Pro Spec America/Apex RC - Team ORCA - Awesomatix USA - Roche RC USA - AVID - Sweep - Protoform - Pro-One RC - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers - Timezone Hobbies
Korey Harbke is offline   Reply With Quote
Old 07-14-2011, 06:09 PM   #3258
Suspended
Trader Rating: 86 (100%+)
just wondering what do you think of the Ride Pro TC Matched Springs for tcx?
i am thinking of getting some
also can you tell difference of using rear gear diff compare with stock rear ball diff and front gear diff with putty and rear gear diff with oil
thanks for any suggestions
littlealex is offline   Reply With Quote
Old 07-14-2011, 07:11 PM   #3259
mazmo's Avatar
Default Roche Spool cups - don't fit HB spool
Got the roche spool cups (to go with Yokomo driveshafts).
I understood they were supposed to be a direct fit onto the HB spool, however they are too small ... so don't fit.
I know people have been using them, now wondering how are they getting them to fit. Are modifications required?
Any feedback greatly appreciated.
Cheers
Alan
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 07-14-2011, 07:26 PM   #3260
Kenny L's Avatar
Trader Rating: 16 (100%+)
I've been running dual gear diffs in my TCX from day one. 500k in front and rear as low as 30-80wt oil. I ran a ball diff and spool in buddies car felt the gear diffs where hands down better on the rug at least. Right now I'm trying ofna diff lock in front see how it feels tomorrow. Like the tune ability of the gear diffs.
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
Old 07-14-2011, 09:42 PM   #3261
Originally Posted by k_bojar View Post
I mean I'm sure it does work - they wouldn't have been produced if they didn't do something good
but really - they must look like swiss cheese
Mmmmmmmm..... cheese. If it's like.cheese, it has to be awesome.
Old 07-15-2011, 10:34 AM   #3262
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Cheers
Alan
You need the Roche spool also, the outdrive internal diameter of the Roche spool cup is the same as a tamiya spool cup.
Cheers,
Antoni
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 07-15-2011, 06:43 PM   #3263
mazmo's Avatar
Thanks Antoni ............ So should I get the TCX or Yokomo Roche spool?
Cheers,
Antoni
Old 07-15-2011, 06:45 PM   #3264
mazmo's Avatar
Thanks DJGonzo
Originally Posted by DJGonzo69 View Post
I use the whole unit, bones & Spindle. I had to shave the steel Yoke outdrives to make it fit properly & line up with the holes on the HB front spool.
Old 07-15-2011, 07:59 PM   #3265
Get the TCX Roche spool, use the cups you have and just replace the front driveshaft bones with the Yokomo ones You may aswell buy a complete spool set, as its only about $4-5 more with another set of spool cups
Antoni Caretti
Old 07-15-2011, 09:30 PM   #3266
mazmo's Avatar
Thanks Antoni ... complete TCX spool set it is
Old 07-16-2011, 01:51 AM   #3267
I'm using the Roche spool with 46mm TOP steel driveshafts. Drops straight in with no mods.
markrobinson is offline   Reply With Quote
Old 07-16-2011, 04:52 AM   #3268
mazmo's Avatar
Thanks Mark .... I've got some of those & will try them
Old 07-16-2011, 06:04 AM   #3269
Send a message via AIM to Matt W
Default lowered shock towers
Hey guys,
How do the lowered shocktowers affect the cars handling, I know they reduce the pack in the shocks and the amount the collars are wound down but what difference will I notice when racing? (I race indoors on carpet)
Matt W is offline   Reply With Quote
Old 07-16-2011, 08:30 AM   #3270
Originally Posted by Matt W View Post
Hey guys,
I found the car frees up in the corners, rolls a little more, and has a more aggressive feel overall. They just make the car rotate harder throughout the corner.
-Korey
SEO by vBSEO 3.5.0
