Old 07-07-2011, 10:16 AM   #3196
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by Hi-LowBlow View Post
I think you could use the 46mm if yours doesn't bind, but might want to check with 0 or 1.0deg FF block. The key is when the front suspension compressed all the way up, it shouldn't bind any.
Hope it helps.
Thank you.
ok - i'm running a 2.0 FF block, not sure if I'd got down to a 1.0 or 0
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 07-07-2011, 10:51 AM   #3197
Korey Harbke's Avatar
Originally Posted by k_bojar View Post
if it doesn't bind, does it hurt anything if you're running the 46mm shafts???
because, honestly, mine doesn't bind - it was tight the first time I ran it, but then after a day of racing everything loosened up
I know the 3Racing blades are tight in the SpecR diffs, it was just tight sliding them into the outdrives - but after a full days of racing, everything seems all good
It will probably feel a tiny bit different. I haven't played with it much on this car, but on others cars... longer driveshafts generally make the car feel a little smoother and less aggressive. It's something you might try and experiment with to see what 'feel' you like best. In the end if it doesn't bind up, everything should be fine .
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-08-2011, 02:45 PM   #3198
AGNO's Avatar
News from ETS
New pivot FR and DCJ 46mm
New chassis
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 07-08-2011, 04:28 PM   #3199
Suspended
Trader Rating: 4 (75%+)
Originally Posted by AGNO View Post
News from ETS
New chassis
can you tell where can i get the blocks and chasis?
amygal is offline   Reply With Quote
Old 07-08-2011, 11:18 PM   #3200
Suspended
Trader Rating: 86 (100%+)
how will the fr blocks effect handling?
will the dcj fit stock c hub? how much would all these parts cost?
News from ETS
New chassis
littlealex is offline   Reply With Quote
Old 07-09-2011, 01:40 AM   #3201
Those wider blocks typically give a little more initial steering into the corner, and rolls a little less in the front end. We have been grinding the standard blocks to allow room for the belt and the steering links.
DCJ will more than likely give more steering overall, and less chatter. They worked really good on the Cyclone TC in the past.
-Korey
Old 07-09-2011, 05:57 AM   #3202
mazmo's Avatar
When using the yokomo 45.5mm steel driveshafts in the front, will I need to use the TCX axles or the Yokomo ones?
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 07-09-2011, 12:50 PM   #3203
spring71's Avatar
Smile
New Spec-R swing shafts 44/46mm are available at TQ.
Ride TCX bumper is also available.
www.tqrcracing.com
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 07-09-2011, 02:50 PM   #3204
Airwave's Avatar
New upper deck too
And new front shock tower, and new front knuckles and new rear hubs!
I think he's not using the new DCJ because of the front SpecR diff, which need 44mm dogbones...
Airwave is offline   Reply With Quote
Old 07-09-2011, 03:07 PM   #3205
Fjeld's Avatar
What about a new car???
|| Yokomo BD7 2015 || XRAY T4'15 ||
|| Muchmore Fleta POWER :D ||
Fjeld is offline   Reply With Quote
Old 07-09-2011, 04:10 PM   #3206
Suspended
Originally Posted by Airwave View Post
New upper deck too
any idea what weight of oil or putty use in gear diffs?
Old 07-09-2011, 06:34 PM   #3207
mazmo's Avatar
Hey guys ... would appreciate any assistance with this.
Do I use the complete Yokomo driveshaft, or just the dog bone.
Old 07-09-2011, 07:36 PM   #3208
Suspended
dont seem like we can get it anywhere.
maybe 1 day i will sell my tcx just coz lack of part support!
Old 07-09-2011, 09:32 PM   #3209
k_bojar's Avatar
Why do you ask that?? This one is like 6-8 months old - not every manufacturer is like xray
Old 07-10-2011, 02:15 PM   #3210
Fjeld's Avatar
Why not? Think it is better to buy a new car full of option then spend much money on options.
