Old 06-14-2011, 10:47 PM   #3061
Suspended
Trader Rating: 86 (100%+)
i m having some on power push on medium grip asphalt but couldn't figure the problem and my setup is pretty close to andy moore at titc but i used hudy 600 oil, xray 3.0 front and 2.8 rear springs
littlealex is offline   Reply With Quote
Old 06-14-2011, 11:49 PM   #3062
ekim628's Avatar
Originally Posted by k_bojar View Post
Welcome back, Korey
On a different note, any hotbodies team guys going to be at the ROAR nationals in July??
I will be attending the ROAR Nationals I hope other hotbodies drivers are attending so we can get a strong team going.
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 06-15-2011, 12:03 AM   #3063
Originally Posted by Hi-LowBlow View Post
What's the shock length? Which hex hubs you have on the car?
I think the shocks are 64 mm all round (not too sure on that though) and the hex hubs are the standard ones that come in the kit.
A.Wojtecki is offline   Reply With Quote
Old 06-15-2011, 12:03 AM   #3064
ekim628's Avatar
Hi Alex, if you are using Andy Moores TITC setup then you are running way to stiff all around. His setup was more suited for high traction smooth asphalt. If you are running on medium traction outdoor asphalt then i would suggest Hpi silver front springs and Hpi silver or blue springs in the rear to generate more grip and reduce pushing.
Eric K.
Old 06-15-2011, 12:19 AM   #3065
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Go to 450 shock oil with pink springs all round, then test silvers all round and see what you prefer, my car has so much high speed steering its ridiculous, it would traction roll if we had the grip
Go to a 4.5mm or 4.3mm front hex, say hello to entry steering
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 06-15-2011, 03:13 AM   #3066
Mike Haynes's Avatar
Il be running mine as well.
BTW for those who pm'd me looking for pics of my car here's a few.
Hot Bodies TCX-imag0185.jpg   Hot Bodies TCX-imag0182.jpg   Hot Bodies TCX-imag0183.jpg   Hot Bodies TCX-imag0184.jpg   Hot Bodies TCX-imag0187.jpg
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-15-2011, 03:29 AM   #3067
Send a message via AIM to Matt W
You will want to change your shock length to 65mm so that you can get the lower droop values!
Try some of the changes, if not all of them i suggested on the page before and you will definitely hav more turn in! No need to alter the wheel hexes!!
Matt W is offline   Reply With Quote
Old 06-15-2011, 04:43 AM   #3068
Airwave's Avatar
Would the SpecR shock towers be a good solution for that?
Airwave is offline   Reply With Quote
Old 06-15-2011, 05:31 AM   #3069
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Well I knew YOU were going to be there
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-15-2011, 05:32 AM   #3070
Hi
just 3 questions ,
why have you lowered the steering ??
And what is the outdrive off the top spool in front ??
What belts are you using with the 40t spool and diff ??
thanks Mike
HB-forever is offline   Reply With Quote
Old 06-15-2011, 06:21 AM   #3071
I think the end result would be the same, its just a cheaper option to lengthen the shocks by 1mm rather than 2 new shock towers, lol!
Old 06-15-2011, 06:31 AM   #3072
hanulec's Avatar
Trader Rating: 25 (100%+)
Originally Posted by HB-forever View Post
Hi
just 3 questions ,
thanks Mike
40t drive line answers --
http://racerlog.com/wiki/Hot_Bodies_TCX#40T_Drive_Line
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-15-2011, 07:53 AM   #3073
Thank you for more detail about your setup.
The shock length 64mm w/stock shock tower would be ok. But i would suggest using 4mm hex in the front along with 0.5mm spacer (each side) and 5mm hex (kit stock) in the rear.
Also, i would try inner shock mounting hole on the rear tower that would be #3 with 2mm inner camber link height.
Most importantly for carpet racing in general, way of applying traction additive is the key. I think you should try many different ways of additive like more front tire additive or longer time and find what the best drive feel for you. This should make more drastic change on the drive feel than finer setup changes.
hope it helps a bit.
Hi-LowBlow is offline   Reply With Quote
Old 06-15-2011, 08:28 AM   #3074
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
All things being equal in setup, does using the 4mm wheel hex clamps make a big difference or do you guys use it as a fine tuning aid?
Ooj is offline   Reply With Quote
Old 06-15-2011, 12:57 PM   #3075
ekim628's Avatar
Its a fine tuning aid rather than a big change. Normally all the team drivers run 4 mm hex clamp with a 0.5mm spacer in the front. Sometimes i run without the spacer to get more initial turn in on tight technical tracks.
Eric K.
