Old 05-30-2011, 08:03 AM   #2881
Send a message via AIM to Matt W
Default Gear diff oils
Hi guys,
Im currently running the spec r gear diff in the rear of my tcx. Im racing indoors on carpet using Fastrax 1000w oil. I was just wondering what are the cars handling characteristics of using a slightly thinner or thicker oil?
Matt W is offline   Reply With Quote
Old 05-30-2011, 12:08 PM   #2882
RC MARKET's Avatar
Around 1000cst
RC MARKET is offline   Reply With Quote
Old 05-30-2011, 01:04 PM   #2883
Trader Rating: 16 (100%+)
Stuff seen in the HB pits. (sorry no pics)
New Shock Towers
Steel Front Axles
New Top Deck
New Front Steering Knuckles
New Rear Hubs
New Chassis (in development, not ready yet)
New Front(rear) Toe Blocks
New Motor (seen in Hara-san's car) VERY FAST!
Also seen was the New TCFD Drift Car! Very Nice!
Can't forget the new Logo's and Decals!
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-30-2011, 01:42 PM   #2884
Trader Rating: 15 (100%+)
Send a message via AIM to DJGonzo69
Thanks to Hiro for the help on parts & the new Subaru body. Body works well alot. It got rid of my front scrub. Also big thanks to Advil & his son for all the set up help!
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 05-30-2011, 11:15 PM   #2885
hey Guys,
Have been running Xray for a few years and decided to move away and try out the TCX. Any hints/tips on the initial build?
Looking forward to getting a car setup that actually corners well
|Awesomatix A800|MM Fleta Pro|R1 Wurks 13.5|SANWA|
niskie is offline   Reply With Quote
Old 05-31-2011, 12:31 AM   #2886
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
Anyone know where I can get dcj's?-67699
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 05-31-2011, 02:43 AM   #2887
RedRc reported that Andy Moore used the new springs when winning UK nationals.
Any idea where I could see a setup sheet with info on which springs he uses?
jarkko is offline   Reply With Quote
Old 05-31-2011, 05:29 AM   #2888
bigz's Avatar
anybody know what adapter i can use for the diff? can't seem to find HB diff cup adapters anymore. always out of stock. will yokomo and sakura 3.5's fit?
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 05-31-2011, 05:55 AM   #2889
Jamesalex's Avatar
I know there were new Moorespeed springs flying off the shelf at the BTCC meeting at Kemble in the UK on sunday. (Which Andy won). I think there was about 5 spring values. If you drop an email to the lads at www.mmrflux.co.uk then they should beable to tell you what they are.
www.cmcc.org.uk
www.mmrflux.co.uk
www.hpiracing.co.uk
www.hotbodiesonline.com
Jamesalex is offline   Reply With Quote
Old 05-31-2011, 07:45 AM   #2890
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hara TCX at Reedy
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 05-31-2011, 08:17 AM   #2891
spencehotbodies's Avatar
Default motor mount
Hello
Can you remove the small screwed foot on the motor mount? am running a bd and with the size of pinion I have to run it is very close.
Cheers
Spencer
spencehotbodies is offline   Reply With Quote
Old 05-31-2011, 08:57 AM   #2892
Default spec-r gear diff
Hello
Has any body run the spec r diff in the front and rear? if so whats the benfit over a spool and gear diff?
WHAT OIL WOULD YOU RUN IN THE FRONT?
Old 05-31-2011, 09:02 AM   #2893
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
which subaru did you end up running?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-31-2011, 09:26 AM   #2894
Subaru Impreza Type C.
Old 05-31-2011, 09:31 AM   #2895
k_bojar's Avatar
damn...there's that mysterious "C" again...any part number - that is actually searchable and buyable in the USA?
SEO by vBSEO 3.5.0
