Old 05-23-2011, 03:35 PM   #2821
Mike Haynes's Avatar
Rumor has it exotek will be having a product soon that all of us tcx guys will want
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-23-2011, 03:39 PM   #2822
san.'s Avatar
Trader Rating: 60 (100%+)
Are they 46mm in length?
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 05-23-2011, 04:18 PM   #2823
MikeR's Avatar
Trader Rating: 15 (100%+)
I'm surprised no one noticed the pre-production part in the photo posted for the QC posts, lol.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 05-23-2011, 06:29 PM   #2824
tenpins77's Avatar
Send a message via AIM to tenpins77
tcx kicked some butt this weekend at my local ashfault track.. Very solid car!
"Im on a Drinking Team, With a bowling problem"
"13th Grade Design", Web Design, Company Marketing, E'commerce Development
www.crgraphicsonline.com
tenpins77 is offline   Reply With Quote
Old 05-23-2011, 10:50 PM   #2825
Look like some new rear hub ??
Does anyone have problem with wheel shattering with stock setup. Can only hear it with wheels on the car.
Does anyone use #88914 in the front ???
Best regards
Mike
HB-forever is offline   Reply With Quote
Old 05-24-2011, 01:01 AM   #2826
Airwave's Avatar
Thanks sir!
Hey, if you can't switch shock locations quicker (compared to the stock bits) with these units I will refund the price to you.... but I know, once you try them you will be a believer
That's quite nice of you!
On my TCX I always mount the hpi parts with the screw head on the side of the damper, So I think I can change dampers position as fast as you
Aside of these new parts, do you plan to produce a new top deck?
(Can find some pictures here)
Airwave is offline   Reply With Quote
Old 05-24-2011, 03:47 AM   #2827
VintageFrog1's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Yokomo_Ant3 View Post
I was thinking the same thing, im thinking its the spool cups, but i only replaced them 2 days ago, damn things wear too fast Cannot wait for this Roche spool!
The Roche spools look nice, got two sitting on my table at home
VintageFrog1 is offline   Reply With Quote
Old 05-24-2011, 05:19 AM   #2828
Default Xray ECS
Hi
Just want to know if it is possible to use the Xray ECS and what do I need to do to fit them ??? Will be running the stock spool but will change to Spec R diff in the front next week
Thanks in advance
Mike
Old 05-24-2011, 05:55 AM   #2829
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
Anyone know where to get some dust covers for the diff?
Ooj is offline   Reply With Quote
Old 05-24-2011, 08:16 AM   #2830
bigz's Avatar
top racing make them.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 05-24-2011, 10:25 AM   #2831
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
the only thing i noticed was the little tiny holes in the shock caps
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-24-2011, 10:45 AM   #2832
David Galdo's Avatar
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally Posted by HB-forever View Post
Hi
Thanks in advance
Mike
There is some work to be done and it may not be worth it in the end with all the other options available.
But if you must... you will need to slowly and carefully drill the outdrives to allow the larger ball end of the ECS dog bone to fit. The ECS pin is smaller so you could find an end cap that will work or press the pin out. If you press the pin out, the hole will have to be drilled just smaller than the HB pins you will have pressed out of the old HB dog.
Take note, the axle is a tad bit shorter than the HB's, so when you put on the wheel hex and tighten the wheel to it, you will be up against the bearings and that is not good. I had to use a Tamiya hex to fix that problem.
In the end, this process is a PITA!
I have returned to a regular axle and dog bone setup with sleeves holding the axle pin in place, not a grub screw. I am using Top steel axles so I still had to press HB pins into them...
I found nearly no advantages to running the ECS. After awhile they wear and are costly to repair/replace compared to a regular set of drive shafts.
My .02...
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 05-24-2011, 04:38 PM   #2833
Suspended
Trader Rating: 86 (100%+)
which body do you guys like to run on your tcx?
littlealex is offline   Reply With Quote
Old 05-24-2011, 04:48 PM   #2834
bukil's Avatar
Trader Rating: 39 (100%+)
Subaru Type C
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 05-24-2011, 06:40 PM   #2835
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Speed 6 is the most populour, LTC-R a close second P37 I dont like, and the new RIDE Subaru has CRAZY steering, especially high speed. Up too your driving style though
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
