Old 05-12-2011, 04:30 AM   #2746
ali_g's Avatar
Originally Posted by Ryan Maker View Post
Okay here are some pretty good photo's of the blocks
Thanks Agno for posting that pic
Hope this helps explain things!
Ryan.
Hey ryan, did you try to compare smokem vs the exotek tcx?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 05-12-2011, 05:16 AM   #2747
Have many people been running a gear diff up front with a very heavy oil at all ? Takes me back to making up carpet spool's for the Mi2EC :O)
Makes sense as it gives the drive train some resiliance to accidents.
Jo90uk is offline   Reply With Quote
Old 05-12-2011, 05:17 AM   #2748
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
Just wondering if anyone has run the TCX one way but using the Pro4/Cyclone 44mm steel dogbones? It should fit right?
Also this one way can be run as a spool as well? I noticed there were pins to lock the outdrive cups.
Ooj is offline   Reply With Quote
Old 05-12-2011, 07:43 AM   #2749
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I have not tried it but have seen posted multiple times the one-way/44 mm bones combo.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 05-12-2011, 08:55 AM   #2750
Hi all
Im new owner of TCX after few years with Tamiya cars.
Have a question what is the difference bettwen using standard knuckles and Tamiya one.
orzel24 is offline   Reply With Quote
Old 05-12-2011, 09:15 AM   #2751
Trader Rating: 18 (100%+)
Originally Posted by orzel24 View Post
Hi all
Ackerman arms are longer and inset a little bit. Your tie rods would probably be shorter by 1 or 1.5 mm.
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 05-12-2011, 05:45 PM   #2752
san.'s Avatar
Trader Rating: 60 (100%+)
According to HB's site, you can only use the 44mm shafts or DCJ's with the TCX One Way/Spool. (see attached)
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 05-12-2011, 11:51 PM   #2753
cain_2010's Avatar
Thumbs up
hi
i am running the spec-r gear diff with yokomo 5000 oil in the front seems to run pretty good.
cain_2010 is offline   Reply With Quote
Old 05-13-2011, 04:33 PM   #2754
Trader Rating: 17 (100%+)
Send a message via AIM to DJGonzo69
So I ordered these today so i can run steel bones on the front for my TCX...
http://www.rc-mushroom.com/product_i...ducts_id=19229
and
http://www.rc-mushroom.com/product_i...ducts_id=16984
Are these all I need?
Thx!
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 05-13-2011, 05:38 PM   #2755
That is correct, that is all you will need.
V-Dezign 4.0
Old 05-15-2011, 01:42 AM   #2756
AGNO's Avatar
For carpet I recommend 500K, same hardness works very well also on asphalt, yesterday I used to race in one track very small and technical, I won the TQ and won the race, very fast car and easy to drive, I used two differential Spec-R with 500K ant. and 1K post. with the front differential I have combined with the DCJ 44mm resulting a truly exceptional steering with the total absence of chattering.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-15-2011, 02:33 AM   #2757
have u ever use 300k...? i'm using 300k seem loosing little torque when exit corner compare to spool...
zamrioo2 is offline   Reply With Quote
Old 05-15-2011, 03:36 AM   #2758
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
This is common when using a front gear diff
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 05-16-2011, 03:16 AM   #2759
AGNO's Avatar
Default New steering spindle
Any news on the release of new steering spindles and new options?
Hiro you have any news?
Old 05-16-2011, 06:23 AM   #2760
about electronic configuration, why not place the ESC after servo (from front to rear) then receiver? i think placing more front will give better weight distribution and car more stable... hope to see feedback... thanc for reply
