Old 05-08-2011, 11:32 PM   #2731
cain_2010's Avatar
Exclamation gear diff in front.
hi,
Has anyone had trouble with puttting the spec-r gear diff in the front of the car and it hits the block, this only happens when i move the notches in a certain direction.
_________________
Cain Reardon.
cain_2010 is offline   Reply With Quote
Old 05-08-2011, 11:59 PM   #2732
cain_2010's Avatar
Smile Just some pictures of my TCX.
[ATTACH][ATTACH][ATTACH]Hot Bodies TCX-lold-006.jpg[/ATTACH][/ATTACH][/ATTACH]
Hot Bodies TCX-lold-004.jpg   Hot Bodies TCX-lold-003.jpg   Hot Bodies TCX-lold-005.jpg
Old 05-09-2011, 12:49 AM   #2733
AGNO's Avatar
Originally Posted by Yokomo_Ant3 View Post
Yes thats a prototype Smokem Top deck Im not sure we are allowed to share pictures but its quite different to the std topdeck and should be released in the near future!
Cheers,
Antoni
Ok thanks, wait for more news.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-09-2011, 07:56 AM   #2734
Originally Posted by cain_2010 View Post
hi,
_________________
Cain Reardon.
I had the same problem, a little sanding on the diff belt guides and it spun freely. You could probably notch the block too, but the annodizing was too pretty to grind.
ebruce is offline   Reply With Quote
Old 05-09-2011, 09:49 PM   #2735
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
hi,
Yeah, i had the same issue...but I was also running 1.5mm spacers under the suspension mounts...I ended up dremeling a chunk out of the rear mount to get the gear to clear - i suppose I could have lowered the suspension block, but I didn't feel like doing the whole car before giving it at least 1 run on the track
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-10-2011, 04:11 AM   #2736
Potoczak's Avatar
Trader Rating: 107 (100%+)
What are you guys using to replace the aluminum driveshafts in the front?? Does anyone make ecs's for this car????
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 05-10-2011, 06:54 AM   #2737
spencehotbodies's Avatar
Default front drive shafts
I have run the original pro 4 hard, but at the moment I am running litemods in the front with litemods spool, runs faultless..
hope that helps..
spencehotbodies is offline   Reply With Quote
Old 05-10-2011, 09:15 AM   #2738
san.'s Avatar
Trader Rating: 59 (100%+)
I noticed in your signature that you run at T&L. Speak to Orlando, as he knows the options to address the front bones.
  • HB TCX One Way w/DCJ's
  • Side Piece Drive Cups w/Xray ECS's
  • Yokomo Drive Cups w/Steel Bones
  • Hot Bodies Cyclone Drift/Pro 4 Steel Bones
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 05-10-2011, 10:28 AM   #2739
Hi Guys,
just switched to TCX and trying to find spare and option parts for this car,
I must say it is very difficult to find shops that have them in stock.
any suggestion is welcome,
thanks a lot.
Ralf is offline   Reply With Quote
Old 05-10-2011, 10:32 AM   #2740
Originally Posted by Ralf View Post
Hi Guys,
thanks a lot.
Try Planet-rc.ch or Demonpowerproducts.co.uk
johnsen-dk is offline   Reply With Quote
Old 05-10-2011, 10:35 AM   #2741
thanks Johnsen !
Old 05-10-2011, 05:13 PM   #2742
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Hey Pete
The best option, I've true so far is Yok BD5 spool cups with either top photon bones or BD5 bones and I have been using the photon axle pin holder freakin great.
I should be at the track this weekend, I will get you the parts list.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 05-10-2011, 06:04 PM   #2743
Potoczak's Avatar
Thanks guys and Orlando!! I will see you at the track this weekend..
Pete Potoczak
Old 05-11-2011, 03:46 AM   #2744
cain_2010's Avatar
Thumbs up
hey
i am running the spec-r tamiya shafts, they are spring steel.UMMM there really good and i am really happy with them. i think now they haave a set for hot bodies. if your running a solid in the front there are some mods you need to do but if your running a gear diff they should fit nice.im in 13.5 and have done about ten race meets and soo far have had very little wear.defenttly must buy.
Old 05-11-2011, 09:02 PM   #2745
Default Parts
Hello,
first of all, sorry for my English.
Will there be in the future better parts support fir this car?
Because now, if you need some parts you have to look in 10 different stores until you find it.
Even simple shims are hard to find. And i don't want to buy shims in 3 different stores and pay 3 times shipping.
I have the car from the release and since then you have to search for parts.
If it stays like this I think to move on to another car.
It is a nice car, butt you need parts to keep it nice.
justfun is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
