Old 05-02-2011, 03:21 PM   #2716
Jerry P's Avatar
Trader Rating: 44 (100%+)
If anyone is interested i have a TCX for sale.
http://www.rctech.net/forum/r-c-item...es-spares.html
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 05-03-2011, 01:52 AM   #2717
unknownmember's Avatar
Sup guys
Looking to get myself a Spec R diff and was just wondering what weight oil do you guys run? No to be confused, I'm not after " what weight oil is best.. " just a poll really because I've never used a gear diff like the Spec R before. I have a SP V3 3.5 with 115 spur and 25 pinion. I don't race it at the moment just mess around with it at car parks and such. I know, absurd but that's just me .
Probably the wrong thread but it is for my TCX so I figured here should be good.
unknownmember is offline   Reply With Quote
Old 05-04-2011, 07:52 AM   #2718
ali_g's Avatar
Originally Posted by Ryan Maker View Post
Since everyone has been sharing setups, here's the setup ive been using for the past 6 months Yes, the car is that good, i never have to change it
I have been playing with 1.5 Deg Blocks FF and FR, feels very direct, easy to drive! I think i will just have to test this at different tracks, but other than that, everything else always remains unchanged.
5000 Gear diff oil in Capricorn is equivalent to about 3000 in Spec-R.
If anybody has any questions, let me know
Ryan.
Hi Ryan, can show a pic on yr front blocks and where do i need to dremel for clearance?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 05-06-2011, 06:03 PM   #2719
Suspended
Trader Rating: 86 (100%+)
hey man, i tried to fix the sloppy steering today and i remember your post.
i had some .2mm shims between front arm and c hubs and changed ball ends to losi type r on steering crank.
i m still waiting for your pics
Originally Posted by Jamie Hanson View Post
I know a bunch of people have complained about slop in the steering system. I played with mine yesterday and was able to completely eliminate it with 4 small shims.
The first shim is a 4mm .02 thick on the steering post itself. It eliminates the up and down slop.
The other shims are a 3/16th shim I think. Very thin. If you look at the alum piece that connects the two bellcranks, there is a small lip that goes towards the bearing side. This shim fits around the lip and when bolted on, eliminates the slop there.
I will take some pictures today and post tonight.
littlealex is offline   Reply With Quote
Old 05-06-2011, 06:05 PM   #2720
Suspended
can anyone explain why use 1.5 degree fr as pivot block and where to dremel?
Old 05-06-2011, 07:39 PM   #2721
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
You dremel underneath the block enough so that the belt can pass under it. You need to use Tamiya steering knuckles with this mod though. Otherwise you will have to dremel the outside edges of the block away. And basically it just makes the car have a different feeling, puts the steering elsewere. You just have to test for yourself and see if you like it.
HTH,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 05-07-2011, 01:27 AM   #2722
AGNO's Avatar
I hope this helps.
However I have not needed to dremel the edges when using the original steering knucle.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-07-2011, 09:07 AM   #2723
Suspended
thanks for the pic agno
is that 1.5 block?
can you tell how different it will be compare to stock fr block please?
Old 05-07-2011, 12:17 PM   #2724
AGNO's Avatar
is that 1.5 block?
Yes, it is a of 1.5 block.
I used it only once on the carpet, but honestly I have not found major differences, just a bit "flatter" the front on corner.
Old 05-07-2011, 10:10 PM   #2725
Trader Rating: 17 (100%+)
Send a message via AIM to DJGonzo69
Front steel 46mm universals. Does HB plan on making steel universals for the TCX?
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 05-08-2011, 12:25 AM   #2726
Smart_Racer's Avatar
Where can I get the 46mm Steel ones from.
Also looking for some steel 44mm ones for sons Cyclone TC.
Team Associated TC6 - Futaba 3PKS - Hobbywing Xtreme Stock - Savox
Smart_Racer is offline   Reply With Quote
Old 05-08-2011, 01:31 AM   #2727
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
Okay here are some pretty good photo's of the blocks
Thanks Agno for posting that pic
Hope this helps explain things!
Ryan.
Hot Bodies TCX-2011-04-26-11.32.22.jpg   Hot Bodies TCX-2011-05-08-16.39.13.jpg
Awesomatix - Muchmore - Protoform - Silverback - Radtec - LeeSpeed - Hiro Seiko - SG PitDesign - Plaig
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Old 05-08-2011, 04:13 AM   #2728
cain_2010's Avatar
Default New Roche spool.
Hi,
Has anyone herd any more news about the new Roche spool for the new TCX.
cain_2010 is offline   Reply With Quote
Old 05-08-2011, 06:23 AM   #2729
AGNO's Avatar
Ryan.
Hello Ryan, I have noticed in photos that you have a different upper deck, is a new Smokem?
You can post a photo?
Old 05-08-2011, 07:11 AM   #2730
Originally Posted by cain_2010 View Post
Hi,
Its been a bit delayed but should be ready next week!
Yes thats a prototype Smokem Top deck Im not sure we are allowed to share pictures but its quite different to the std topdeck and should be released in the near future!
Cheers,
Antoni
Antoni Caretti
