Old 04-25-2011, 04:32 PM   #2686
Hugh Jazz's Avatar
Originally Posted by Yokomo_Ant3 View Post
Hey guys, im wondering (yes i know this sounds silly) does anyone else have a problem with their car hopping? yes, hopping! My car is now known as "The rabbit car" on our track because it is hopping on the sweeper especially, but slightly coming out of corners too. we have narrowed it down to that the car has so much forward traction that my car is actually hopping bacuse the wheels are skipping across the surface because the car has so much front grip? If that makes sense.
Im running mod so obviously the car is going at good speeds when this is occurring, and its not really slowing the car down at all, it just makes it a little annoying to drive consistantly for 5 minutes. And before anyone says is it bumpy in those parts of the track, no its not. ive tried droop and all but nothing seems to work. One lap today my car even lifted the inside 2 wheels off the ground without even hitting anything, and its not a traction roll issue as this is outdoor asphalt that is untreated.
Any help appreciated, btw Any Moore's car did this a TITC a bit also, but my car is taking it to another level
Cheers,
Antoni
I declare from this day forth you shall be know as Bugs.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 04-25-2011, 05:59 PM   #2687
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys
Is there any compatible belt set that fits on the TCX ? (long and short) ?
thanks,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-25-2011, 06:49 PM   #2688
V-Liqour's Avatar
Thumbs up Belts
You can use the front belt from the Xray T3 171tooth
And the rear use a Assoc TC6 64tooth
Rgds
Scott
Purples Great HB:TC:TCX:BLITZ ESE: And More Xxx's
HobbyWing V3:Xtreme : EXOTEC: HBX : HBXX : SPEC R:
XXX4 : B4 : JET:Pro Amp: STRC
: and other stuff I can't remember??
"Genuine Authentic Copy". "tunay na tunay na kopya"
V-Liqour is offline   Reply With Quote
Old 04-25-2011, 07:09 PM   #2689
hanulec's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Tabushi View Post
Guys
thanks,
Rgds
Scott
Unless the info I have on belt pitch is wrong -- the TC5/TC6 rear 64t belt shouldn't fit.
http://racerlog.com/wiki/Touring_Car_Belts
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-25-2011, 07:13 PM   #2690
Cheers,
Antoni
I had the same issue with my car and I found the end of the aluminum drive shaft at the knuckle joint stretch out and start jamming up the joint as it rotates. Check to see if the finish is wearing off the drive shaft end, if so that is almost certainly your hopping. If the joint stretches out enough it will even jump going straight due to the joint is always at a slight angle and binding.....
Cyclone Bender is offline   Reply With Quote
Old 04-26-2011, 01:01 AM   #2691
AGNO's Avatar
Guys
thanks,
The Spec-R produces the belts, low-friction version
http://www.spec-r.com/specrr2/module...roducts_id=112
http://www.spec-r.com/specrr2/module...products_id=82
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 04-26-2011, 04:46 AM   #2692
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Thanks for all the suggestions guys, managed to fix it today by going back to my other modified spool with Yok spool cups and tamiya driveshafts The pin had worn out on the other spool too much and was cause the car to behave erratically. Now to just get my Roche spool next week It will be available soon! I dont have any info atm guys, besides the picture I posted a few pages back now. I will ask Max for an update asap.
Im really happy with my car at the moment, I dont think i can get it any better on our asphalt track at the moment! And the best thing is, the car is super fast whether it be on old or new tyres, Last meeting i was .3 off track record on 6 run old tyres! No way i could do this with my previous car There is just one thing annoying me at the moment, I cant seem to break into the 14 second lap times lol. I did 8 15.0 laps in a run today, but nooooo, not a 14. I think Alycat hates me If anyone needs help with setup shoot me a pm and ill be glad to help.
Cheers,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-26-2011, 05:28 AM   #2693
Tabushi's Avatar
THANKS AGNO !!
But anyway, i ordered belts from www.toughracing.com ... i use them on my nitro and they are awesome so ...
cya !
Old 04-26-2011, 06:55 AM   #2694
crabboy's Avatar
Trader Rating: 58 (98%+)
Is that the track record that is currently held by a TAMIYA.
Rhys
Cheers,
Antoni
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 04-26-2011, 07:16 AM   #2695
Rhys
Which probably used new tyres that run Ill see if we can all have a crack at beating it on Sunday Besides, I even had the slow Yokomo springs on that run
Antoni Caretti
Old 04-26-2011, 01:21 PM   #2696
Potoczak's Avatar
Trader Rating: 109 (100%+)
Yokomo would you mind posting your setup so everyone can take a look at it?? Thanks.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 04-26-2011, 03:46 PM   #2697
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by AGNO View Post
be careful with the SpecR belts...I ordered a rear one and it wasn't enough teeth to fit the TCX It was like 1 tooth too short - so i had to use it on my TC
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-26-2011, 04:02 PM   #2698
Send a message via Yahoo to 180rbSx
that is pretty how much do they cost roughly?
180rbSx is offline   Reply With Quote
Old 04-26-2011, 06:35 PM   #2699
Hi guys.
I have a great problem with my TCX, the front drive shaft broken all time, I'm looking for a steel drive shaft HPI88914, but all the store are out of stock, Is there other option? I read about tamiya drive shaft with yokomo blades, that parts fits on TCX? Anyone knows a part number?
wilson godoi is offline   Reply With Quote
Old 04-26-2011, 07:05 PM   #2700
wa7ash's Avatar
Trader Rating: 37 (100%+)
Perhaps you should look back a few pages, a lot of info has been provided regarding this issue.
Xray | Muchmore | Sanwa | Orion | G-Force | Scorpion | Fantom
wa7ash is offline   Reply With Quote
