Old 04-18-2011, 04:15 PM   #2656
san.'s Avatar
Trader Rating: 60 (100%+)
Originally Posted by Hi-LowBlow View Post
Here you go.
Thank you Hiro-san
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 04-18-2011, 07:37 PM   #2657
M3Armand's Avatar
Exclamation Stock sway bar setting instruction manual discrepancy
What is the true "stock" sway bar setup?
I just found out a discrepancy in the manual. On page 24 and 25 it says to use black 1.4 mm front and copper 1.2 mm in the back.
On page 36, the standard setup sheet says black 1.4 mm in the front and silver 1.3 mm in the back.
Which is correct? And this is annoying...
M3Armand is offline   Reply With Quote
Old 04-20-2011, 06:53 PM   #2658
Could someone direct me to the Cyclone TC page please? I can't seem to find it...and I wouldn't be posting this if I didn't try really hard.
bdbachus is offline   Reply With Quote
Old 04-20-2011, 07:09 PM   #2659
RaceAce701's Avatar
Trader Rating: 84 (99%+)
Hot Bodies Cyclone
here u go
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 04-22-2011, 05:37 AM   #2660
V-Liqour's Avatar
Default Dual gear diffs???
Hi , could anyone advise the advantage or disadvantage of using oil filled gear diffs front and rear in the TCX
I am currently running spool front and rear spec-r gear diff in 17.5 boosted , and it's on rails but just needs a touch more off power steering .
Rgds
Scott
Purples Great HB:TC:TCX:BLITZ ESE: And More Xxx's
HobbyWing V3:Xtreme : EXOTEC: HBX : HBXX : SPEC R:
XXX4 : B4 : JET:Pro Amp: STRC
: and other stuff I can't remember??
"Genuine Authentic Copy". "tunay na tunay na kopya"
V-Liqour is offline   Reply With Quote
Old 04-22-2011, 06:58 AM   #2661
M3Armand's Avatar
Default Why Xray T3 knuckles vs HB alum knuckles?
I'm trying to find sturdier replacement parts for the super brittle 73507 knuckle hubs.
I read that the Xray T3 (or even T2) knuckles would work, but that I'd have to add some shimming and remove a 2mm spacer from the steering rack to achieve the same Ackermann.
So my question is, why don't I just go with the 67698 HB aluminum knuckles to begin with? I assume this would be a direct bolt on with no shimming necessary? My only reservation about using the HB aluminum knuckles is that if this is "unbreakable", then "something" else has to break down the line upon impact...like the steering or servo...
Thoughts?
Old 04-22-2011, 07:02 AM   #2662
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Thoughts?
Go for the Alu replacement. I feel that is my next change. I am sure you have extra arms and c-hubs so you should be fine.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 04-22-2011, 09:08 AM   #2663
Trader Rating: 18 (100%+)
I have been running the Aluminum knuckles for the entire carpet season and the beginning of the asphalt season with no real issues. The only breakage that has occured was deserved. LOL
SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 04-22-2011, 01:38 PM   #2664
Dog Bone's Avatar
I'm not so sure about the aluminum knuckles - any impact *may* cause them to bend, which will make the car behave strangely, and it may not be apparent that it's the knuckles causing the problem. If they bend at all, it may cause binding at the c-hub, which will lead to some pretty bizarre behavior when exiting corners (the car won't center properly).
At least with the plastic knuckles, you know when they're damaged. Yeah, it's not that great when they break, but at least you know when they're good, they're good.
Regarding the x-ray knuckles, I've switched over to them - they require a very small shim so they fit better in the c-hubs, but this is easily done with a bit of shoo-goo (a tiny amount), and you just stick the shim on. Makes it much easier to put the knuckle in
Ken Miller
T4 2015
CRC Twenty5
Dog Bone is offline   Reply With Quote
Old 04-22-2011, 11:22 PM   #2665
Hi
Do any one know the difference between the stock motormount and bulkhead and the optional HD ones ??
Have seen Andy's setup from TITC , he use 650oil , but what brand ?? Do any one know that `??
Do any one drill a breathing hole in the top of the damper ???
Anything that you need as spare parts ??
johnsen-dk is offline   Reply With Quote
Old 04-23-2011, 02:01 AM   #2666
Originally Posted by johnsen-dk View Post
Hi
That was muchmore shock oil.
Hi-LowBlow is offline   Reply With Quote
Old 04-23-2011, 03:37 AM   #2667
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Hi
Muchmore oil and he did drill a hole in the caps
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-23-2011, 06:59 AM   #2668
steveonamission's Avatar
So a mate dremels 1.5 blocks so that we can run 1.5 fr pivot block and 1.5 ff block. However he had to dremel the ends aswell, not just the underneath for the belt, as with 4mm of ackerman and 1.5mm shims under the block the steeing turnbuckle ball joints hit the blocks... but just clear on load. Would a solution be to run a hub that creates the same ackerman angle with using less shims on the steering rack? Anyone else had this problem?
steveonamission is offline   Reply With Quote
Old 04-23-2011, 07:32 AM   #2669
ali_g's Avatar
is it a must to dremel the 1.5fr block? do you need to flip the block?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 04-23-2011, 07:46 AM   #2670
You have to dremel it for the belt to run underneath it. Can't run the blocks flipped, as shims don't work with it that side.
