Old 04-03-2011, 09:14 PM   #2551
Originally Posted by Yokomo_Ant3 View Post
http://www.youtube.com/watch?v=CrEnW_19IFQ
Heres a Video of Ryan Maker winning the Victorian state titles yesterday with his TCX in front on Simon Nicholson. Wish i could have been there now!
Great job Ryan! Did you see my email I sent last week?
Hi-LowBlow is offline   Reply With Quote
Old 04-03-2011, 09:23 PM   #2552
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Im not Ryan, Hiro I will ask him for you later though
Cheers,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-04-2011, 07:13 PM   #2553
Robertcooper88's Avatar
Trader Rating: 15 (100%+)
I was wondering if anyone knew when we should expect the following parts. All of the known shops have been out for a while now.
Suspension Arms
46MM Drive Shafts
CVD Rebuild Kits
Any help would be appreciated.
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 04-04-2011, 09:34 PM   #2554
louielou's Avatar
Trader Rating: 16 (100%+)
Default drive shafts
any ecs drive shafts that would work in the TCX.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 04-04-2011, 09:49 PM   #2555
dameetz's Avatar
I m using Hudy ECS 52mm. You need to enlarge the steel spool outdrives to 7mm to fit the Hudy ECS end. My case, I just sent it to the local machine workshop and only took them 5 mins to do it. I ve been using it for 3 months now with no major problems at all. The only thing that you need to look after is the ECS's pins. I broke them twice already.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-04-2011, 10:53 PM   #2556
David Galdo's Avatar
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I too am using the HUDY ECS drive shafts for about five months now.
I drilled out the outdrives to fit the HUDY dog bone end. Pulled the HB pins from worn dog bones and pressed them into the HUDY dog bones. You will have to drill the hole a bit larger to allow the HB pins to press in. Having pressed the pins in will mean not having to use axle pin adapters.
You will have to chamfer the HB c-hub opening on the inside. It will allow free movement of the ECS otherwise it will make contact and appear to be a chatter problem. I used a hobby knife.
One more thing to check is bearing binding. I am using XRAY knuckles and while using the HB wheel hex clamps, the hex pin is completely recessed leaving no free play between the HB hex and the bearing so binding would occur when the wheel is mounted. I am having to use Tamiya hexes cause the pin is not completely recessed in the hex and therefore no binding. I am not sure what the outcome would be if using HB knuckles.
Need pics, send me a PM.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 04-05-2011, 01:03 AM   #2557
dameetz's Avatar
I m using mine with HB knuckles with no problem. Jusn need to add shim between the knuckles and the wheel hex to reduce the slop. Additional info, for me, I just dremel the outdrive slot to 3.5mm so that I can use the Xray ECS blades. So far the outdrives do not have any signs of wear.
Old 04-05-2011, 05:01 AM   #2558
hanulec's Avatar
Trader Rating: 27 (100%+)
Or you could convert your belts, diff and spool to a 40t setup and start running a Side Piece racing Mira outdrives like Mike Haynes does - Side Piece Racing. Mike has posted previously after his Snowbirds win the parts you need to do the 40t conversion- this would just involve buying a TOP Photon spool instead of a 2nd gear diff.
Before making the Mira Outdrives I tries running a machined Hot Bodies spool but I had issues with the steel cups breaking after hard hits.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-05-2011, 05:37 AM   #2559
Jerry P's Avatar
Trader Rating: 44 (100%+)
I'll be running the setup on my new TCX. We also have another person that is converting to the mira and ECS setup.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 04-05-2011, 06:09 AM   #2560
san.'s Avatar
Trader Rating: 59 (100%+)
+1
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 04-05-2011, 07:13 AM   #2561
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
i have to say this is a very nice option, the Mira outdrives are fantastic.
made in the USA.
for everyone having problems with the HB front bones, this setup will take care of the issues....and will probably make the car just a bit easier to gear correctly. especially in blinky mode (17.5 non-boosted)
i do believe Haynes is using it Mod as well.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 04-05-2011, 07:20 AM   #2562
Dont forgt the Roche spool that should be available within the next 2 weeks! All you need is spool and tamiya/yokomo/top front steel bones.
BTW those wanting rebild kits, ive noticed tamiya and yokomo parts especially are almost identical Also, has anyone else noticed the DCJ driveshaft being available again almost everywere! Just wish they were 46mm
Cheers,
Antoni
Antoni Caretti
Old 04-05-2011, 07:59 AM   #2563
Jerry P's Avatar
Cheers,
Antoni
The reason for us using the Mira out drives is the ability to use Xray ecs'. I run them on my top car it is amazing how different the car is with the Ecs'.
Jerry P
Old 04-05-2011, 09:11 AM   #2564
Default help
Hello everyone
I explained how I can buy a frame for my smokem tcx??
I have already sent three emails but no response, someone tells me the correct procedure?
thank you very much
biagio23 is offline   Reply With Quote
Old 04-05-2011, 10:39 AM   #2565
+1
Entirely different feel and consistent through the entry to exit of turns.
V-Dezign 4.0
