Old 03-22-2011, 12:10 PM   #2476
Originally Posted by AGNO View Post
The outdrive POM work very well, more smoothness and less chatter, but unfortunately they are rather fragile, especially when using large apertures of the arms, as 2.5, because the head of the axle shaft is not perfectly inside the outdrive, personally counsel with a maximum swep of 1.5 or 0 is better.
thank but english is not my first language and i have some difficulties to understand you
by swep you mean inboard toe at the front end?
mac gregor is offline   Reply With Quote
Old 03-22-2011, 02:28 PM   #2477
AGNO's Avatar
Sorry, but also I have trouble with English language, However, I refer to front pivot (FF).
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-22-2011, 03:03 PM   #2478
thanks
ok, i see, the part 75161 in the manual
if i really need to change this part to use the pom joint, may be a front gear diff with 500 000 oil is a better idea ?
Old 03-22-2011, 04:11 PM   #2479
AGNO's Avatar
thanks
Yes, the part is the 75161, the differential gear with 500 000 oil is really a good idea.
Old 03-23-2011, 10:02 AM   #2480
Send a message via AIM to Matt W
Default Rear driveshafts
Hi,
Has anyone found a better replacement for the 44mm aluminium driveshafts in the rear. I find they wear too quick and would like to use steel. Im using the yokomo driveshafts in the front and would like to use their 44mm ones but can not find any blades that will fit....
any ideas?
Matt W is offline   Reply With Quote
Old 03-23-2011, 10:18 AM   #2481
Is anyone out there running a TCX in USVTA class? If so, any setup advice would be appreciated.
ebruce is offline   Reply With Quote
Old 03-23-2011, 10:32 AM   #2482
Mike Haynes's Avatar
Originally Posted by Matt W View Post
Hi,
any ideas?
HB sells steel 44mm from the front on the cyclone tc, they are an exact fit
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-23-2011, 12:23 PM   #2483
TheCoolCanFanMan's Avatar
Hi,
any ideas?
Yep, use CVS's in the rear, you won't get ANY wear then :0)
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-23-2011, 12:31 PM   #2484
Supposedly the HB 44mm steel driveshafts for previous cars have all been discontinued and replaced with the aluminium ones.
any other ideas??
Old 03-23-2011, 02:07 PM   #2485
warnos's Avatar
any other ideas??
They are on ebay..
http://cgi.ebay.com/Hot-Bodies-Front...item255e5edcdf
Should not break these in a hurry in the rear. I have never had any issues with the rear shafts.. unless the track is not very car friendly..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 03-24-2011, 12:54 PM   #2486
AI
AI's Avatar
Send a message via MSN to AI
It's my new super narrow chassis, made by M.M.H Racing.
Wide only 8*mm, more flex and better balance, include cabron battery holder
Hot Bodies TCX-003814w9fma968zdyakwiw_jpg_thumb.jpg   Hot Bodies TCX-dsc00183.jpg
|TianHao Racing battery&motor&hop-up chassis|Nirvana Hobby|Tcx|Formula Rabbit|
AI is offline   Reply With Quote
Old 03-24-2011, 03:23 PM   #2487
Barry_Hughes's Avatar
Shame it won't take a lipo battery with humps on the bottom, as some can only be used with the humps down
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 03-24-2011, 04:22 PM   #2488
Dog Bone's Avatar
Where did you pick that up from?
Looks like the chassis would be a touch stiffer due to smaller/fewer cutouts. But, it's narrower, so maybe that gives you a bit of flex back.
Interesting.
Ken Miller
T4 2014, 10r5.1 (F/S), 12r5.2 (F/S)
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 03-25-2011, 02:05 AM   #2489
AI
AI's Avatar
Originally Posted by Barry_Hughes View Post
c, as some can only be used with the humps down
only can use flat case lipo
Old 03-25-2011, 03:08 AM   #2490
AI
AI's Avatar
Interesting.
I buy it from a china net shop
SEO by vBSEO 3.5.0
