Old 03-20-2011, 06:55 PM   #2446
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by stuey View Post
it looks like he is using tamiya springs and it looks like a down 2mm tower simular to the spec r version also wonder what deg FR pick up point that is/
stu
2mm down tower would be interesting, and generally Andy Runs 1.5 blocks FF and FR
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 03-20-2011, 07:01 PM   #2447
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Originally Posted by AGNO View Post
I tried it today, really good, operation and installation are perfect, no oil leak.
http://www.rctech.net/forum/attachme...1&d=1300471487
What happens if you dont use blades ?
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 03-20-2011, 07:02 PM   #2448
From ETS, the final version of the new spindles steering, on the Moore car, there is also a strange shock tower.
We hope to be available soon!
Its hard to tell what ackerman shims he is using, but it looks like there are very little, the hole on the knuckle looks to be further back than the tamiya steering block.
Antoni Caretti
Old 03-20-2011, 07:04 PM   #2449
You MUST run blades, otherwise the driveshaft is going to be wobbling around like crazy in the outdrive, and the outdrives will last a few corners before they are chewed out.
Antoni Caretti
Old 03-21-2011, 12:59 AM   #2450
AGNO's Avatar
+1
The use of blade is required.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-21-2011, 05:57 AM   #2451
M3Armand's Avatar
3Racing blades do not need no modification, can be fitted perfectly on the original drive shafts TCX.
+1
Can someone please post the part numbers for these 3Racing blades? As a bonus, where to buy them from?
M3Armand is offline   Reply With Quote
Old 03-21-2011, 06:22 AM   #2452
AGNO's Avatar
http://os.3racing.hk/products.php?products_key=2232
http://www.rcmart.com/catalog/rc-cyc...th=595_870_890
Old 03-21-2011, 08:09 AM   #2453
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
this is where I just ordered 2 sets from...
http://store.hkshobby.com/product_in...oducts_id=3718
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-21-2011, 08:29 AM   #2454
Pls look at the anti Roll Bars in andys Car.
Are they From the pro4??
rcweb is offline   Reply With Quote
Old 03-21-2011, 08:56 AM   #2455
k_bojar's Avatar
doesn't appear to be so. looks exactly like the ones I have on my TCX and my TC
Old 03-21-2011, 09:03 AM   #2456
I think at the rear are different
Old 03-21-2011, 09:18 AM   #2457
k_bojar's Avatar
nope - same exact ones i have on my TCX...
HB made an aluminum version of these, but this is the standard plastic/composite ends that come with the kit...sorry, dude - nothing fancy there
Old 03-21-2011, 09:37 AM   #2458
On the bulkheads are different Aluminium Parts.
That is Not in my tcx
Old 03-21-2011, 09:52 AM   #2459
k_bojar's Avatar
huh?? the only thing I see that's different (aside from the knuckles and shock tower) is the FR suspension part...
everything else on that looks 100% outta the box and i've stared at this image for awhile now...
Old 03-21-2011, 09:56 AM   #2460
steveonamission's Avatar
He means the split rollbar holders with aluminium sway bar stoppers.
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
