Old 03-14-2011, 11:53 PM   #2416
CL
CL's Avatar
Trader Rating: 32 (100%+)
Originally Posted by stuey View Post
i would check again the front 416 short arms are shorter than tc and tcx arms the shock locations are in the same place but the roll bars are in a differnt location so the geometry is not the same.
Opps! You're right. The 416 arms are 1mm shorter. My bad!
Believe in yourself!
CL is offline   Reply With Quote
Old 03-15-2011, 12:04 AM   #2417
Default ok
ok
bev0550 is offline   Reply With Quote
Old 03-15-2011, 11:15 AM   #2418
Coldn's Avatar
Send a message via MSN to Coldn
We can use TRF416 or TRF417 46mm CVD in Hotbodies?
I'm searching in many stores, and nobody have TCX 46mm CVD or Pro-D 46mm CVD in Stock..
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 03-15-2011, 11:30 AM   #2419
Dog Bone's Avatar
Just an FYI....
I finally switched my TCX over to the steel front drive-shafts this past weekend, and I had to open up the spacing in the outdrives so the pins from the drive shaft wouldn't bind...
I tried multiple packages, and all the drive shafts exhibited the same behavior.
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 03-15-2011, 12:52 PM   #2420
olhipster1's Avatar
Trader Rating: 91 (100%+)
Send a message via Yahoo to olhipster1
The following options exist:
-top photon 46mm or tamiya bones...needs blades and open/file spool cups.
-Photon and/or Yokomo dog bones with Yokomo steel cups. No mods needed, no blades needed.
there are quite a few threads about this...please search in the TCX thread.
dog bones, arms, blades, steering mods....etc.etc..
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 03-15-2011, 01:47 PM   #2421
cheehtae's Avatar
Trader Rating: 15 (100%+)
I have a photon and cyclone universal CVD that I could sell if anybody needs it. I think I have three will have to ck and post picture. PM me if interested. Don't mean to hack this thread. Also have a spec r uni for tamiya 416, missing th middle part though.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 03-16-2011, 08:41 AM   #2422
mojoman's Avatar
Tested the exotek chassis yesterday. If you are having a flex issue ie: snap steer or traction roll this is a definite upgrade! Although the chassis is a lot thinner than the stock chassis it provides more stability to the car and allows for more consistent lap times. The chassis pretty much puts everything close to the center line of the car. Now I just need to dial in a little steering.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 03-17-2011, 12:50 PM   #2423
Barry_Hughes's Avatar
try here http://demonpowerproducts.co.uk/prod...oducts_id=5982
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 03-17-2011, 08:44 PM   #2424
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Not to threadjack, but if someone has a exotek chassis for the cyclone (I figure maybe one of the HB loyalist might have one), send me a pm, thanks. Also thanks to k_bojar for emailing the diff pics to me.
nf_ekt is offline   Reply With Quote
Old 03-18-2011, 04:09 AM   #2425
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
no problem about the pics glad i could help ya out
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-18-2011, 05:18 AM   #2426
Trader Rating: 45 (100%+)
Is the Spec-R TCX gear diff a direct fit or is some shimming needed? TIA.
Apex is offline   Reply With Quote
Old 03-18-2011, 05:23 AM   #2427
k_bojar's Avatar
Are you asking me?? I was referring to dropping the TCX gear diff in a cyclone TC and shimming is an understatement
But as far as the TCX, no more shimming needed then for the regular diffs
Old 03-18-2011, 05:34 AM   #2428
Was asking anyone that has put the Spec-R TCX diff in their TCX. Thanks!!
Old 03-18-2011, 11:05 AM   #2429
AGNO's Avatar
I tried it today, really good, operation and installation are perfect, no oil leak.
http://www.rctech.net/forum/attachme...1&d=1300471487
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-18-2011, 11:50 AM   #2430
k_bojar's Avatar
hey...I see you're using the 3racing blades - are they a direct fit for the HB dogbones or do they need to be modified any?
