Old 03-13-2011, 09:44 AM   #2401
jag88's Avatar
Originally Posted by Mike Haynes View Post
I have run both chassis on my cars on carpet now. Either one is for sure an upgrade from stock, they are both nice and narrow, and have the battery moved in with no extra work. The smokem chassis flexes more then the exotek, depending on what your looking for you can make the choice. I'l be running outside real soon so i'm not to sure just yet which will run better there. I have a bit of a fear of my battery flying out so my preference is the exotek untill smokem adds some retainers.
Do you have a preference for carpet (medium grip) ?
Thanks.
jag88 is offline   Reply With Quote
Old 03-13-2011, 12:05 PM   #2402
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally Posted by M3Armand View Post
Does this have the exact same geometry as the originals?
Do you have the part number and does this have the exact same geometry as the originals?
Thanks guys...
Originally Posted by quick-nik View Post
If I remember correctly, the 73506 make a slightly shorter wheelbase in the front. Despite, the geometry remains the same.
Quick Nik is correct, you will want to shim these arms forward.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 03-13-2011, 03:30 PM   #2403
CL
CL's Avatar
Trader Rating: 32 (100%+)
Thanks guys...
http://www.speedtechrc.com/store/ebp...id=618&id=6112
They have the same geometry, but the location of the swaybar ball joints on the arms are slightly different. If you run hotbodies c-hub on Tamiya arms, you will also need to shim them. I have a cyclone TC and a Tamiya 416WE. I have not break any arm on the 416WE but instead have bent the suppension mount on it.
Believe in yourself!
CL is offline   Reply With Quote
Old 03-13-2011, 09:56 PM   #2404
Default new proto top deck
heard that its slighty thicker ..
vm2 ,tm e4,mi 4,cup racer,yokomo d1,TCX,PHI RDX,MI4CX,TC6,china made pro-d.
ps.just came back to this hobby this year after22 years .
oldnoob is offline   Reply With Quote
Old 03-13-2011, 10:17 PM   #2405
unknownmember's Avatar
Default Setting droop...
Sup guys,
Does anyone have difficulty setting droop using the factory team gauge and block? Because the car to me is very sensitive so if I don't get it bang on it'll dig left or right. I've checked the camber links and they're within .01 ~ .02 from each other. Tips much appreciated
I've also isolated it to rear drive by taking out the front belt.
unknownmember is offline   Reply With Quote
Old 03-14-2011, 08:56 AM   #2406
Coldn's Avatar
Send a message via MSN to Coldn
Hello, I have a TCX
somebody know if HB have any front CVD of steel that I can use instead of original? yesterday my original CVD broked in a strong brake and I didnt have one to replace. and the store dont have in stock
Cyclone TC - Futaba 3PM Fasst
Speed Passio GT2.0 - MMM 10.5t
Nanotech 6000mah
Coldn is offline   Reply With Quote
Old 03-14-2011, 09:43 AM   #2407
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by Coldn View Post
Hello, I have a TCX
Steel Pro-D Shafts are a direct fit.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 03-14-2011, 11:10 AM   #2408
Coldn's Avatar
46mm?
Nanotech 6000mah
Old 03-14-2011, 11:15 AM   #2409
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
46mm?
yes, exact fit in every way no modification required
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-14-2011, 11:47 AM   #2410
Coldn's Avatar
Do you know were I can buy?? I found out of stock in any stores
Nanotech 6000mah
Old 03-14-2011, 11:49 AM   #2411
k_bojar's Avatar
the post from san has a link in there...that's the only place I know of that they are available - that's where I got mine from
Old 03-14-2011, 12:44 PM   #2412
Coldn's Avatar
out of stock too..
Nanotech 6000mah
Old 03-14-2011, 04:28 PM   #2413
stuey's Avatar
i would check again the front 416 short arms are shorter than tc and tcx arms the shock locations are in the same place but the roll bars are in a differnt location so the geometry is not the same.
stuey is offline   Reply With Quote
Old 03-14-2011, 05:17 PM   #2414
Suspended
Trader Rating: 86 (100%+)
i have a slightly used tcx for sale
tcx
littlealex is offline   Reply With Quote
Old 03-14-2011, 07:45 PM   #2415
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by oldnoob View Post
Attachment 722517
Hotbodies had a few prototype top decks at TITC, that one didnt end up getting used.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
