Old 03-10-2011, 01:14 PM   #2371
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by nf_ekt View Post
WRD.
If you know the exact shim specifications, post it up. Or I can just figure it out on my own .
i can take a pic of the tcx diff in my cyclone TC tonite when i get home from work..
but basically, i used 2 packages of the Z892 (10x12x.2mm) shims (that's 20 shims total) on each diff...then just balance as needed
there will be some wobble in the diff, but i don't know how this will effect performance in the long run
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-10-2011, 02:37 PM   #2372
Trader Rating: 77 (100%+)
Originally Posted by k_bojar View Post
yes, the TCX spec-r diff is a straight drop in for the TCX...just need to get a set of blades for the dogbones because there is a little wiggle in the outdrives - nothing too horrible that is performance robbing, just need for a better fit
I found the spec-r diff online. Anyone know where to find and part number for the blades?
goin2drt is offline   Reply With Quote
Old 03-10-2011, 02:37 PM   #2373
Send a message via AIM to Matt W
Default Upper camber links
Hey,
Ive recently been running the 2 degree toe blocks ff and fr and have noticed the car being very snatchy on the front. I have also been running 4mm spacers under the front and rear camber links to get rid of grip roll?
Does anyone know the main handling effects of raising or lowering the upper camber links. I know it mainy affects the amount of camber change and slighlty changes the roll center.
Any thoughts??
Matt W is offline   Reply With Quote
Old 03-10-2011, 05:07 PM   #2374
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Matt W View Post
Hey,
Any thoughts??
Try 1mm under the front blocks instead of 1.5mm. I wouldnt use 4mm under the camerlinks as the car will lean on the outside edge of the tire too much. Go back to 2mm. Also, what wheelbase are you using on the front now? Try a shorter front wheelbase, so 1mm on the back of the arm, and 2.75 on the front. And what ackerman shims and Knuckles are you using on the car?
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-10-2011, 09:27 PM   #2375
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default Carpet setup
Arn0, helped me setup a PDF setup sheet.
if you want take a peek.
It's what I've been using for a medium to high bite carpet track.
File Type: pdf TCX_Olhipster1_OpenHighTractionCarpetTrack201103.pdf (398.2 KB, 149 views)
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 03-11-2011, 05:24 AM   #2376
Anyone?
Old 03-11-2011, 06:24 AM   #2377
Part number of blades is 61333
quick-nik is offline   Reply With Quote
Old 03-11-2011, 06:33 AM   #2378
2xs
Interesting setup. But why did you put 1mm shims under the front outer camber link? And why so much rear camber?
2xs is offline   Reply With Quote
Old 03-11-2011, 06:38 AM   #2379
olhipster1's Avatar
Default reply
I drive a little different..but the setup just works for me...may not be for everyone..
with Jacos it's usually best to run a lot of camber, makes the car stick better.
if you're running other brand tires reduce the camber to
1 - 1.5 degree in the front
1.5 - 2 degree in the back.
1mm outer camber link....i was playing around with setup...put in 0 thru 1.5mm...and found 1mm to my liking.
another note is that my tires have not been overheating when running this setup.
CAUSE and EFFECT
Old 03-11-2011, 06:46 AM   #2380
2xs
Thanks for the quick reply. I run Sweep Xtreme Carpet tires and have noticed that they have a lot of side bite. I will have to try your suggestion about the camber.
Old 03-11-2011, 08:03 AM   #2381
unknownmember's Avatar
Quick questions,
How wide is the ball socket of the stock Heavy Duty ball cups? And what's the chances of these http://www.amainhobbies.com/product_...w-6mm-Thread-2 fitting the threads of the TCX parts. Just looking to eliminate the flop and play as much as possible so i'm willing to fork out a wad if you guys seen better ones.
unknownmember is offline   Reply With Quote
Old 03-11-2011, 08:24 AM   #2382
2xs
Originally Posted by unknownmember View Post
Quick questions,
For the price of those you can get several different brands of ball cups to try out. Personally I like the HPI heavy duty ball cups and the RPM ball cups.
Old 03-11-2011, 10:38 AM   #2383
Default Setup help....
Thanks Antoni,
Here is my current setup......
I run on a very grippy open carpet track and the car is very snatchy on the front end and very nearly grip rolls on corner entry after quick directional change......
2 degree ff and fr toe blocks
1mm under all toe blocks
4mm under all upper camber links
Front wheelbase, 2.75 front, 1mm rear
Rear wheelbase, 2 front, .75 rear
Rear hub, .75 front, 2 rear
4mm akerman
Front toe, 0
Rear toe, 3
Front camber- 1.5
Rear camber- 2
500 weight oil front
400 weight oil rear
1mm 3 hole pistons
Hpi Gold and silver springs
Front shock position, 1 on wishbone, 4 on tower
Rear shock position, 3 on wishbone 5 on tower
Front droop, 6
Rear droop, 5
1.4 front roll bar
1.2 rear roll bar
5mm ride height all round
I also glue the front tyre edge to help with grip roll......
Any thoughts?????
Old 03-11-2011, 11:31 AM   #2384
stuey's Avatar
Thanks Antoni,
4mm akerman
Front toe, 0
Rear toe, 3
Front camber- 1.5
Rear camber- 2
400 weight oil rear
1mm 3 hole pistons
Front droop, 6
Rear droop, 5
1.4 front roll bar
1.2 rear roll bar
Any thoughts?????
use a softer front spring (pink)bigger holes in pistons (1.1-1.2) lay shocks down on front tower.
stu
stuey is offline   Reply With Quote
Old 03-11-2011, 11:45 AM   #2385
olhipster1's Avatar
Quick questions,
I change the ballend & links to TOP photon...pretty much super solid...do a search and i have a few pics posted on this thread.
slop is virtually eliminated and super easy to work on the car.
but if anyone wants bling try the AE TC6 Ti coated ball with the AE TC6 ballcups. super nice...my next purchase
CAUSE and EFFECT
