Old 03-06-2011, 02:17 PM   #2326
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by charlie_b View Post
Drive clean, drive smart, and keep checking on your car for everything and you should be fine.
+1
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 03-06-2011, 06:27 PM   #2327
olhipster1's Avatar
Trader Rating: 90 (100%+)
Send a message via Yahoo to olhipster1
Default update
i just wanted to give an update on the Pro 4 arms...
I put on the High Traction Pro4 Arms...
and wow...the car had so much more steering..it was great.
and to top it off...
the arms so much more durable...
finally a weekend without breaking one single thing.
I recommend to everyone to put the arms on the car.
The lower shock mounting holes line perfectly to shock position 2 & 4 on the current arms.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 03-06-2011, 08:36 PM   #2328
Suspended
Trader Rating: 86 (100%+)
is it called HPI High Traction Suspension Arm Set hpi31420?
littlealex is offline   Reply With Quote
Old 03-06-2011, 10:09 PM   #2329
olhipster1's Avatar
Default 31420
you got it.
CAUSE and EFFECT
Old 03-07-2011, 05:46 AM   #2330
Originally Posted by Yokomo_Ant3 View Post
Its a HPI motor, 4.5T
motor is "Z5", a new series motor !!
mos-leung is offline   Reply With Quote
Old 03-07-2011, 08:16 AM   #2331
dameetz's Avatar
Today I tested the Spec R gear diff for TCX. The outdrives are different in design than their previous models for other cars. It has 2 grooves and the diameter is the same for the shaft. The X ring also seated perfectly tight in the housing. So after some sanding of the bevel gears (as per instruction) I assemble it and use 1000 silicone oil.
After running it for 4 packs, there was no leak at all. The new design outdrives with the grooves really worked. I just hope it stays like this, I m going to test it again tomorrow. Overall I m really satisfied with it.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-07-2011, 08:29 AM   #2332
jmackani's Avatar
Trader Rating: 14 (100%+)
I have the gear diff, but I have a question for others out there with it. Do the drive shafts need any type of blades put on them now? Seems to be some slop in the stock cvd's in the rear.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 03-07-2011, 08:50 AM   #2333
steveonamission's Avatar
You sure do need the blades.
I got a bit of a shock when i went to order
some, 10 for just two here in the UK, that's 16$ , LOL crazy.
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Old 03-07-2011, 09:20 AM   #2334
AGNO's Avatar
3Racing Blade work very well and are inexpensive.
http://os.3racing.hk/products.php?products_key=2232
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 03-07-2011, 10:13 AM   #2335
Yeah i noticed them, but they are non exsistant here, demon power products used to do them, but not anymore, not going to purchase overseas for just blades. The HB ones shouldn't be anywhere near the price they are. The price of HB parts in the UK is generally a ripoff anyway, cheers though.
Old 03-07-2011, 10:45 AM   #2336
John Doucakis's Avatar
A bit more info on this please?
Z5 is the type? Who is the maker? is it HPI?
Thanks.
John Doucakis is offline   Reply With Quote
Old 03-07-2011, 11:43 AM   #2337
Thanks.
the maker is DUALSKY,they make e-powered air plane motor ,this the track & field series. Z5.just launch about a month before TITC.
Hara tested the 4.5 and5.5t ,not sure which he use in the race.
vm2 ,tm e4,mi 4,cup racer,yokomo d1,TCX,PHI RDX,MI4CX,TC6,china made pro-d.
ps.just came back to this hobby this year after22 years .
oldnoob is offline   Reply With Quote
Old 03-07-2011, 12:24 PM   #2338
Originally Posted by Advil View Post
The pro-d was never released in the US so of course there are no parts. Steel shafts for the TCX are coming soon but not available yet. Hopefully soon. I am hoping they decide to release DCJs for the TCX but we will have to wait and see.
PS I am not a HB representative but I will do my best to help you if I see you at my local track.
The steel shafts that you are talking about was in HARA's titc TCX ,that means it might be out very soon...
Old 03-07-2011, 05:37 PM   #2339
TheCoolCanFanMan's Avatar
Originally Posted by warnos View Post
Anyone used these 46mm driveshafts for the front from rclitemods?
http://www.litemodz.com/product_info...roducts_id=414
or
http://www.litemodz.com/product_info...roducts_id=289
Have not heard anyone on the TCX forum comment on them.. must be better then the aluminum ones..
Hi Guys
I ran the steel CVD's at our Friday night club which is aprox 22mtrs x 12mtrs and about a 8 second lap time with NO probs what so ever. I also ran them again yesterday at the last round of EWS which I was 3rd in the A and finished 3rd overal, but won the EWS series overal Track size 34mtrs x 16mtrs with a 10.80 second lap
I feel peeps need educating when fitting/running these awesome driveshafts.
1,
Make sure when building them make sure the C, clip is completely seated in the groove within the axel. I not, you may find it benificial to remove a little material from one end of the C clip so that the clip fits in and the ends of the clip meets flush.
2,
Make sure that once together that they are completlt free of any knotching.
3,
Make sure you place the spring is seated well in the outdrives (personally they work the best with the LM spool) and that the shaft is under tension within the outdrives.
4,
Make sure there is no movement/float left and right of diff/spool, as this will put extra load on a separate CVS.
5,
Check the servo saver don't have excesive movement within it.
6,
You won't need as much ackerman when running CVS's iv'e found.
7,
you might want to check the max lock out on your steering too, as if there is any movement it would be advisable to put a small 0 ring on the steering knuckle so stop the knuckle from flexing round in a crash, which is when problems mat arise.
8,
You will also find that you can reduce the steering curve on your handset, as will find corner speed is far smoother so therefor quick than standard CVA's
9,
The other thing you will find is, that tyre wear is far less than with CVA's as there is NO chatter from the CVS's at all.
10,
You may think that you u need CVS's n the rear of the car, but you would be wrong, again these work well in cojunction with the front CVS's as again tyre wear is far less than the standard version, as there is no judder, so again less wear.
Well I hope this has helped you make up your minds about the CVS's. I know there been issues, as i have been working closely with Litemodz on these drive shafts
If I can help in any 'technical' questions I can help with please ask.
Cheers Malc
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 03-07-2011, 06:51 PM   #2340
Robertcooper88's Avatar
Has anyone put the Spec-R gear diff in the front yet? Did you need a longer belt?
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
