Old 03-02-2011, 05:47 AM   #2281
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally Posted by Yokomo_Ant3 View Post
Andy did an awesome job at TITC, definatly a very friendly guy too, on and outside the track too His car was insane, so much steering and grip, when i first saw him drive it on the practice day I knew it was going to be right up there. Hara and Andy ran very different setups, so it shows that there is more than one way to get the car to go fast. I was pretty happy with my car making the Mod B main in my first international event It was just funny how much the track can change hour to hour, first you have traction roll, then understeer. All a learning experience though
Congrats, recognized your name from this site.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 03-02-2011, 06:37 AM   #2282
Trader Rating: 77 (100%+)
Originally Posted by goin2drt View Post
Add pink and gold springs to the list of items I can't find. Anyone know where I can purchase all of the above?
Anyone?
When will HB start getting back in stock and supporting the TCX. I love my car but am so frustrated with the availability or lack there of on parts. I am ready to sell it and get something else. I only get to drive once a week or so and to miss a week because of parts really sucks.
goin2drt is offline   Reply With Quote
Old 03-02-2011, 06:46 AM   #2283
Trader Rating: 29 (100%+)
What kind of parts are you looking for? I have been able to find almost everything I have needed for the car.
A list of the few places I check and order from........
Horizon Hobbies
Tower Hobbies
Stormer Hobbies
Amain Hobbies
SpeedtechRC
For the normal parts, all these places have what I needed. From bulkheads, to arms, c-hubs, and now DCJ's
Former fast guy just trying to keep up......
Jamie Hanson is offline   Reply With Quote
Old 03-02-2011, 06:49 AM   #2284
san.'s Avatar
Trader Rating: 59 (100%+)
Anyone?
Stormers and SpeedTech have most of the parts you're looking for.
Here's are the spring sets you're looking for as well. There's only 2 in stock, if I were you, I would order them asap.
Here's another source.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 03-02-2011, 07:08 AM   #2285
Just ordered the springs. That's awesome thanks. I still need the following. I will check a few of these other sites but Amain and a few others have been out.
1 mm spacers
1.2 mm 3 hole pistons but I understand Tamiya has the same ones that fit and those are at Speedtech
1.5 pivot block
1.0 pivot block
73507 hub set
Thanks for the help
Old 03-02-2011, 07:13 AM   #2286
san.'s Avatar
1 mm spacers
1.5 pivot block
1.0 pivot block
73507 hub set
Thanks for the help
You can get all the above from SpeedTech and the hubs from here.
Old 03-02-2011, 07:21 AM   #2287
Thanks San. Just ordered those and headed to speedtech today to see Albert. I am happy now. Thanks for the support. Now if I could only drive better and break less.
Old 03-02-2011, 07:24 AM   #2288
louielou's Avatar
Trader Rating: 16 (100%+)
Default shock towers
what is the differences between the stock shock towers and the Spec r 2mm down shock towers? How is it so suppose to help in performance?
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 03-02-2011, 08:07 AM   #2289
dameetz's Avatar
I want to know this too...from what I can think of is to get more ride height adjustment. In my case my local track is very bumpy,I need at least 6.5mm ride height to clear the bumps especially at the long straight. I m almost running out of thread on the shock tower trying to get that height, so maybe by using the 2mm lower shock tower, i will get some thread back.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 03-02-2011, 08:34 AM   #2290
Actually, it will change the piston position in the shock body. When the 2mm lower shock mounting holes were used, the piston position will be 2mm higher that will generate less pack in the shock. It frees up the car a lot.
Hope it helps.
Hi-LowBlow is offline   Reply With Quote
Old 03-02-2011, 09:27 AM   #2291
Mike Haynes's Avatar
Hope it helps.
or you could use a shorter ball end and just have a lower cg
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-02-2011, 12:10 PM   #2292
bukil's Avatar
Trader Rating: 39 (100%+)
You might run into droop problems if you are using 1.5mm under toe blocks. I think.... depending on your shock length
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 03-02-2011, 07:41 PM   #2293
Suspended
Trader Rating: 86 (100%+)
did anyone try the spec r towers on their tcx? does it make handling any better?
littlealex is offline   Reply With Quote
Old 03-02-2011, 08:04 PM   #2294
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 03-03-2011, 01:42 PM   #2295
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
this may not be the correct spot, but the spec-r gear diff will fit all the versions of the cyclone...just found that out today
of course, you need some shims - but it will fit
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
