Old 02-28-2011, 10:26 AM   #2266
Jim_1987's Avatar
Originally Posted by AGNO View Post
Use the drive shafts HPI 88914 PRO-D,are steel, indestructible,are used without modification.
Second that! 3 of us are using them at my local club with no issues. The hpi pro 4 drive shaft is another good option.
Jim_1987 is offline   Reply With Quote
Old 02-28-2011, 10:53 AM   #2267
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys,
Any online store where can i find PRO D or another alternative "just go and plug" replacement for 46mm TCX driveshaft ?
Im from southamerica and locally its impossible to get that parts,
thanks,
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 02-28-2011, 10:55 AM   #2268
AGNO's Avatar
Yes, you can also use MIP Pro 4, are long 46mm.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-28-2011, 11:16 AM   #2269
AGNO's Avatar
Originally Posted by Tabushi View Post
Guys,
thanks,
Here the pro-d shafts are available
http://www.rcmarket.com.hk/
Old 02-28-2011, 01:27 PM   #2270
stuey's Avatar
Originally Posted by steveonamission View Post
Try a shorter front camber link, that will make the car more aggressive, and stop the car rolling over itself and washing out, thats what i run on carpet, with the rear in the long camber link hole.
Just a suggestion.
Steven
i would look at how your car loads up on the suspension before adjusting the camber link shorterning the camber link will make the car initaly agressive but you will find going though the corner and exit it tend to push. and feel unsetled when getting back on the throttle.
looking at your setup i would start by standing your shocks up a hole on the tower this will make the front of the car react faster and change direction faster you may find that the car is a little to twitchy you colud then drop the oil weight by 5wt to smooth the transition out.
steve where do you race.
stu
stuey is offline   Reply With Quote
Old 02-28-2011, 02:18 PM   #2271
ark
Originally Posted by rendcool View Post
last year videos were even better ..
yeah hopefully some better ones come up. Andys car looked really smooth and from the photos the car looked pretty box stock i think
ark is offline   Reply With Quote
Old 02-28-2011, 04:31 PM   #2272
M3Armand's Avatar
Agno, do you have another part number aside from "HPI 88914"? Even the HPI site doesn't recognize that number.
Thanks in advance.
M3Armand is offline   Reply With Quote
Old 02-28-2011, 05:40 PM   #2273
Trader Rating: 77 (100%+)
Originally Posted by goin2drt View Post
Can anyone help me out? Do you know who carries the following? Seems OOS at a few of the places I shop at.
1.0 mm spacers/washers
1.5 and 1.0 pivot blocks
part 73507 - steering knuckles
part 73513 - body post
Not a need but a want as well is the top deck screws in purple M3x5mm
Thanks.
Add pink and gold springs to the list of items I can't find. Anyone know where I can purchase all of the above?
goin2drt is offline   Reply With Quote
Old 02-28-2011, 06:47 PM   #2274
Robertcooper88's Avatar
I have a couple of questions, I have searched through the thread with no clear answers to them.
Why use a gear diff in place of a ball diff in the rear? Plusses/minuses
Why use a Gear diff in the front in place of a solid axle?
I ordered two of the new gear diffs to try out. I live in South Florida and mainly race outside on a pretty smooth surface. Can anyone tell me how the gear diffs will benefit me?
Thanks in advance.
DischargeRC.com - Race-Opts MTS T2 - TRINITY FOR POWER
Robertcooper88 is offline   Reply With Quote
Old 02-28-2011, 10:38 PM   #2275
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Thanks in advance.
That's the part number on the ones I got (from rcmarket, I might add)... Search rcmarket for that part number and you'll find it there, that's what I did when I ordered mine
HPI USA site doesn't carry the Pro-D - you need to look at HPI japan to see the actual part on the site
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-01-2011, 09:52 AM   #2276
louielou's Avatar
Trader Rating: 16 (100%+)
Default blades
does anyone know where i could get some rear cup diff blades part#61333 her in the US.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 03-01-2011, 11:31 PM   #2277
stitchy's Avatar
Spec-R gear diff and 2mm down shock towers now available at SpeedtechRC!
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 03-01-2011, 11:56 PM   #2278
I got the Pro-d 46mm steel shafts the other day (3 packs.....I was pretty shocked I fuond so many).
They actually are just slightly to tight for the V3 outdrives. Ive run a file around the teeth of the outdrive to allow them a snug fit but able to move free in and out the teeth. Seems now I have a front end that will be bog standard in the sense of HPI parts, but pretty tough to crack.
Also managed to finally get some wishbones, been running pro4 one's for ages now.
Happy chappy I am
Jo90uk is offline   Reply With Quote
Old 03-02-2011, 02:39 AM   #2279
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Andy did an awesome job at TITC, definatly a very friendly guy too, on and outside the track too His car was insane, so much steering and grip, when i first saw him drive it on the practice day I knew it was going to be right up there. Hara and Andy ran very different setups, so it shows that there is more than one way to get the car to go fast. I was pretty happy with my car making the Mod B main in my first international event It was just funny how much the track can change hour to hour, first you have traction roll, then understeer. All a learning experience though
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 03-02-2011, 03:21 AM   #2280
k_bojar's Avatar
Just be careful of the spec-r low friction rear belt - it doesn't fit the TCX... It's a 63t belt instead of a 64t belt - the 63t will probably fit my TC, but not my TCX... I think they were advertised as 64t or erg-mart/spec-r's site - so I was a little bummed/annoyed, but oh well at least I can use it
So buyer beware that's not aimed at you, stitchy - just figured I'd put it out there in general
