Old 02-25-2011, 12:41 PM   #2236
2xs
Originally Posted by steveonamission View Post
See that Hara's car at the titc is using a stiffer top deck, without the middle cut out, i guess to reduce flex reaction in the high grip conditions, i could do with one of them for carpet!
x2
I am also thinking about getting the Exotek XX chassis & steering brace. Does anyone know if the XX chassis is stiffer than the stock chassis?
2xs is offline   Reply With Quote
Old 02-25-2011, 08:31 PM   #2237
Suspended
Trader Rating: 86 (100%+)
did anyone tried exotek chassis with steering brace? is it worth it?
littlealex is offline   Reply With Quote
Old 02-25-2011, 09:38 PM   #2238
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by 2xs View Post
x2
read back a few pages and look for mike haynes comments about the exotek chassis
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-26-2011, 03:15 AM   #2239
Send a message via AIM to Matt W
Default Spec r driveshafts
Hi,
Im running the steel outdrives for the yokomo bd5 in my tcx and was wondering if the spec r double jointed ecs driveshafts for the yokomo would fit in the front?
Matt W is offline   Reply With Quote
Old 02-26-2011, 03:47 PM   #2240
Dog Bone's Avatar
I've read that Tamiya 416 knuckles will fit on the TCX; is anything else required? I've read that the x-ray knuckles require different bushings....will the tamiya ones work with HB bushings?
Also, I see that the Tamiya knuckles come on sets of two - are the knuckles L/R specific, or are they the same?
Thx!
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 02-26-2011, 04:16 PM   #2241
Suspended
i had used 416 axles for few months, it has some play at the spool outdrive but its driveable.
i m also using xray knuckles (no L or R) you can add .5mm shim under the bushing, no need to replace another brand of bushing
Old 02-26-2011, 05:18 PM   #2242
dameetz's Avatar
Thx!
The Tamiya knuckles are a bit thicker so you need to file it to fit in our c hub. The L/R are the same though. If you want a perfect fit without any mod, use Yokomo BD5 knuckles. Both Tamiya and Yokomo knuckles will change the ackerman, so readjust the ackerman angle accordingly.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-26-2011, 05:31 PM   #2243
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
I think it will have some flex built in for outdoor.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 02-26-2011, 07:43 PM   #2244
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Xray knuckles fit good, place a shim on the top side. Use the inner steering hole and the ackerman will line up very close to the HB outer hole.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-27-2011, 12:58 AM   #2245
AGNO's Avatar
Thx!
The knukles the 416/17 are easily assembled, simply turn upside down one a steering block busching #7522 (I rotate the top).
Tamy Knukle are the same R/L
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-27-2011, 04:55 AM   #2246
warnos's Avatar
Default Titc
TCX wins at TITC with Moore getting one over Hara... nice to see.
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 02-27-2011, 05:10 AM   #2247
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Imagine that, Hara in third!!! There was no way Moore was to be denied this conquest! He controlled it from the first qualifier.
A TCX finished 4th in the Brushless class (13.5) and dominated (TQ and Win) in the Open Blushless (11.5).
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-27-2011, 06:00 AM   #2248
I too had to use the XRAY knuckles. I use the #2 hole and 4mm of shims on the rack.
V-Dezign 4.0
Old 02-27-2011, 06:36 AM   #2249
AGNO's Avatar
Good result also for Freddy Sudhoff, at the European indoor EFRA took fourth place .
Old 02-27-2011, 06:49 AM   #2250
AGNO's Avatar
Of course, congratulations for the victory of Wong Hei Feng, 11.5 in open!
