Old 02-22-2011, 12:47 PM   #2206
Barry_Hughes's Avatar
Originally Posted by Tabushi View Post
But no solution available from other brands but direct fit ?
thanks,
try e-bay for MIP CVD's I have the 46mm versions product part HPI80827
and they are excellent
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 02-22-2011, 01:00 PM   #2207
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Where to get them ?, cant find online ... link ?
got mine from rcmarket - can't post a link at work, our web filters block that website as vehicles
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-22-2011, 02:06 PM   #2208
mojoman's Avatar
DCJ's now in stock here and here. Thank you Jamie Hanson!
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 02-22-2011, 02:22 PM   #2209
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
They are 46mm or close ?, for front on TCX ?
thanks
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 02-22-2011, 02:25 PM   #2210
k_bojar's Avatar
thanks
nope, they should be 44mm - they are intended for the 'old' cyclones...I have them on my cyclone TC and they are definitely shorter then the shafts on my tcx
Old 02-22-2011, 02:33 PM   #2211
mojoman's Avatar
Option part for the TCX. Check it out.
Casey Castleman
Old 02-22-2011, 02:35 PM   #2212
k_bojar's Avatar
right, they are...but they aren't 46mm like the TCX needs in the front.
they WILL work, IF you use the multi-diff from the TC in the front of the TCX, but they aren't a direct fit with the stock/standard from diff/spool from the tcx
so, its true its an option - but not a TRUE alternative for the front end of the TCX
one of the links on hotbodiesonline tells you that you need the from spool/one-way setup from the TC to use those parts on the TCX
Old 02-22-2011, 02:37 PM   #2213
Trader Rating: 17 (100%+)
They do "fit" the TCX but they sit too far out in the spool outdrive and make it fail easier. Best bet would be to avoid the current 44mm DCJ unless you have "Hara" driving skills. Or you could put them in the rear of your car....
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 02-22-2011, 02:52 PM   #2214
steveonamission's Avatar
Can it be just a simple case of fitting the PRO-D 46mm steel bones on the DCJ's so you can run them up front, as i have a a couple spare PRO-D bones, or does the DCJ bone have a different design to the standard bone ball end?
steveonamission is offline   Reply With Quote
Old 02-22-2011, 02:56 PM   #2215
k_bojar's Avatar
it has a different design - since its 'double jointed' ... I think the 46mm on a DCJ axel will then be too long..plus the DCJ aren't rebuildable - there is no set screw to take them apart
at this point, the only option is to fit (and its an exact fit) the 46mm Pro-D steel bones to the axles that come stock on the tcx - unless HB releases a DCJ for the tcx in the near future
Old 02-22-2011, 03:11 PM   #2216
future
Yeah im running them on the standard axles up front, have been for a while now, but they have increased the chatter at the front over the aluminium bones, not that chatters always a bad thing. Thanks for the DCJ info.
Old 02-22-2011, 05:43 PM   #2217
The TOP 46mm bones work with the existing front end hardware. The only thing you need to do is open up the spool cups with a dremel tool because you will need to use the TOP blades. The TOP bones have to much play in the HB spool cups. This creates a lot of play and backlash in the front end.
silky is offline   Reply With Quote
Old 02-22-2011, 05:55 PM   #2218
mojoman's Avatar
The part you need for the DCJ's is specific to the TCX p/n68720 it is a multi diff basically the same as what you have now only with the option to use it as a one way differential as well. The price at A Main is around $50.00.
HPI Europe's description
HTH
Casey Castleman
Old 02-23-2011, 01:56 AM   #2219
Any News about Smokem? I cant weit for this Chassis :-)
rcweb is offline   Reply With Quote
Old 02-23-2011, 02:10 AM   #2220
hijinx's Avatar
Trader Rating: 47 (100%+)
Smokem chassis are saweettttt as, have got them fitted to the both of my TCX's
Sponsored by Yokomo Australia Team Hearns Hobbies, AKA Tires from Ryper Hobbies.Fantom batteries and motors. Hobbywing,Pro Amps servos,Wild Turbo Fans,TWT. Yokomo BMax2 Hobbywing Fantom Ion4 8.5t. Yokomo BMax4 III Hobbywing Fantom Ion4 6.5t. Yokomo BD7 2016 Hobbywing Fantom FR-1 4.5. S2H BODIES for all your custom RC paint jobs.
hijinx is offline   Reply With Quote
