Old 02-21-2011, 04:47 AM   #2191
AGNO's Avatar
Originally Posted by rcweb View Post
Where can i get Purple screws?
I use screws Square ergal 7075, I purchased from RC Mushroom
www.rc-mushroom.com
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-21-2011, 05:05 AM   #2192
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Originally Posted by AGNO View Post
I recommend using 1K for the rear and minimum 500K for the front.
Thanks a lot for the advice.
Anyone here already mounted SPEC-R diffs in front on TCX ?
thanks
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 02-21-2011, 05:23 AM   #2193
Mike Haynes's Avatar
I use the top 46 front bone for gear diff
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 02-21-2011, 05:53 AM   #2194
AGNO's Avatar
thanks
I am waiting the arrival of the gear diff Spec-R, now I'm using 3Racing gear diff 38 pulley, at the rear with the original drive shafts 44 mm and at the front with the DCJ 44mm.
Old 02-21-2011, 07:21 PM   #2195
hacker's Avatar
Trader Rating: 140 (100%+)
does the spec r tcx diff fit the older cyclones tc's?
hacker is offline   Reply With Quote
Old 02-21-2011, 07:34 PM   #2196
san.'s Avatar
Trader Rating: 59 (100%+)
No, it does not fit.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 02-21-2011, 09:34 PM   #2197
b_recliner's Avatar
Trader Rating: 22 (100%+)
Can anybody tell me the part number of the tamiya 3 hole 1.1mm pistons that fit? I cannot find the hot bodies ones anywhere. Thank you!
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 02-21-2011, 10:41 PM   #2198
eceer's Avatar
These should see you right http://www.rc-mushroom.com/product_i...oducts_id=6889
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 02-21-2011, 11:07 PM   #2199
b_recliner's Avatar
Originally Posted by eceer View Post
Thank you friend!
Old 02-21-2011, 11:53 PM   #2200
unknownmember's Avatar
Default Gearing question.
Hey dudes,
I just got myself an SP 3.5T and the SP GT 2.0 ESC and was wondering if you guys can share your gearing plz Even if you don't run SP, as long as it's between 3-4T. Before I had a Novak setup and I was running 115 pinion and 41 spur which I took from the chart at back of the manual. I never really had the chance to see if I was under or over-geared or not coz the ESC blew and two of my batteries puffed nicely and I believe gearing was one of the suspect so I really don't want it to happen again. But whilst I had my Novak setup, i just did the typical place your hands on the ESC and motor and if you can leave you hand on it for a period of time or without dis-comfort your gearing is okay. Please spare me if I got it wrong lol, still new to this hobby.
unknownmember is offline   Reply With Quote
Old 02-22-2011, 11:23 AM   #2201
Tabushi's Avatar
Hello guys,
Anyone here knows of a more robust/durable CVD solution for the TCX in front ?. But something "plug and play" ?, without mixing components ?, direct fit ?
thanks !
Pat
Old 02-22-2011, 11:32 AM   #2202
Trader Rating: 17 (100%+)
Hello guys,
thanks !
Pat
I'm fairly certain a 46mm steel driveshaft will become available. We will have to wait for now...
Team Powers, SMC ( www.smc-racing.com the only place to order your batteries online.), Awesomatix, Gonzo Paints, BN Racing
www.TeamPowersUSA.com
"Imitation is the sincerest form of flattery."
Advil is offline   Reply With Quote
Old 02-22-2011, 11:40 AM   #2203
Tabushi's Avatar
But no solution available from other brands but direct fit ?
thanks,
Old 02-22-2011, 11:51 AM   #2204
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hello guys,
thanks !
Pat
get the Pro-D steel shafts...plug and play without issue..
technically, you are already mixing components - the aluminum shaft and the steel axle so this way, you are getting HB/HPI steel upper and lower parts
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-22-2011, 12:39 PM   #2205
Tabushi's Avatar
Where to get them ?, cant find online ... link ?
