Old 02-20-2011, 10:58 AM   #2176
Barry_Hughes's Avatar
Originally Posted by BlueEagle View Post
Anyone? Are parts so scarce that you don't want to compete for spares with one more person?
Different front axles and front arms seem like a good idea for durability, but was hoping someone could point me to a setup sheet and/or any other helpful swaps for a good build. Went through the last 50 pages in this thread and didn't see a good listing.
Get the 3 hole 1.1 pistons, pink springs and that's it!
as for spares wishbones, and steering hubs are the main requirements and if you can find them 46mm steel bones from the drift car.
I am using MIP drives and they are really good, but unfortunately are now longer made.
As for set up, the kit settings are fairly good, just drop the shocks down a bit to hole 3.
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 02-20-2011, 11:24 AM   #2177
Trader Rating: 23 (100%+)
I just ran a TCX for the first time yesterday and it ran really well. It was a kit setup with the change of less rear toe, less front arm sweet and camber angles. All the shim spacing and camber length heights were stock settings.
2 hole kit pistons with 40 and 35 weight AE oil.
Pink and silver springs................
I would like to get the nylon drive cups but can't find any. Would also like to get the DCJ's and a gear diff. Can't find those either. Mike Haynes has come up with an option also using a 40 tooth spool from a Photon.
Spare parts needed...... Front end stuff. Arms, c-hubs, and steering knuckles.
Former RC fanatic just trying to keep up......
BSR Tires / Spektrum RC
Jamie Hanson is offline   Reply With Quote
Old 02-20-2011, 12:42 PM   #2178
There is a gear diff now that you can get for the TCX why dont you just use that?
jordan.norwood@ is offline   Reply With Quote
Old 02-20-2011, 12:48 PM   #2179
RCBuddha's Avatar
Trader Rating: 33 (100%+)
does the spec-R diff use the 44 or 46mm drive shafts?
RCBuddha is offline   Reply With Quote
Old 02-20-2011, 01:23 PM   #2180
I would love to, but can't find a shop that has them in stock right now.
Old 02-20-2011, 02:22 PM   #2181
The gear diff would use 44mm shafts because it goes at the rear but properly would use the 46mm as well because racers have been using them at the front.
I am guessing that the gear diffs have all gone because the orders were placed when there were two links placed on this site saying that they were in stock. I just managed to get mine on the day they were released.
Old 02-20-2011, 02:43 PM   #2182
eceer's Avatar
This is where I ordered mine from http://www.egrracing.com/shop/110-ep...4_157_496.html it appears that they have some in stock. Atleast at this minute they do
Any suggestions on oil weight to start with?
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is offline   Reply With Quote
Old 02-20-2011, 03:18 PM   #2183
RCBuddha's Avatar
sorry, forgot to mentioned that I will be using dual gear diffs in my TCX
Old 02-20-2011, 04:32 PM   #2184
Trader Rating: 77 (100%+)
Anyone know who has RW Spur gear in stock? I need a 92 and 94 tooth. Nexus is OOS.
goin2drt is offline   Reply With Quote
Old 02-20-2011, 06:07 PM   #2185
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Thanks a lot i just bought 3 , 1 for front, 1 for rear and 1 for spares.
I race using front spool on my TCX, never tried a diff on front on electric touring, would be a good idea to start (low grip track) with 100.000 up front and 10.000 on rear ?
thanks
Patricio "PATO" Concha
E-Mail : pato_concha@yahoo.com
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 02-20-2011, 06:20 PM   #2186
Is this a nice Kit to turn into a drifter? Seems out of the box, has really nice high grade pieces.
Hpifanboi is offline   Reply With Quote
Old 02-20-2011, 07:19 PM   #2187
ark
thanks
Hi I normally run 1000 in the rear with a spec r. I go between 1k and 2k. 2k oil gives more rotation, good if the rear is too stuck. On the front, guys are running 300k normally
ark is offline   Reply With Quote
Old 02-21-2011, 12:01 AM   #2188
Where can i get Purple screws?
rcweb is offline   Reply With Quote
Old 02-21-2011, 04:44 AM   #2189
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Aluminum Screws
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 02-21-2011, 05:36 AM   #2190
AGNO's Avatar
thanks
I recommend using 1K for the rear and minimum 500K for the front.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
SEO by vBSEO 3.5.0
