Old 02-18-2011, 01:50 PM   #2161
hkshobby.com has spec-r gear diffs
Steve Walter
Sweep Racing USA/ Speed Passion USA/ Karens Famous Cookies (Transporter)
SRW141 is offline   Reply With Quote
Old 02-18-2011, 06:04 PM   #2162
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default SRW141
Hey Steve.
are you running the HB?
been a while...hopefully you make it up Horsham soon.
Quick question
How does everyone like the servo saver that comes with the kit?
Not sure if I should change it out.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-19-2011, 03:22 AM   #2163
warnos's Avatar
works fine for me.. got a Kimborough and it just looks like its the same servo saver.
Originally Posted by olhipster1 View Post
Hey Steve.
Quick question
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 02-19-2011, 02:14 PM   #2164
Send a message via AIM to Matt W
Default Topdeck screws
Hey,
Has anyone had trouble with the topdeck screws tightening after a few runs, sometimes they're almost impossible to get out!!
any ideas on solving this problem, perhaps grease or countersunk washers??
Matt W is offline   Reply With Quote
Old 02-19-2011, 02:45 PM   #2165
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
Originally Posted by Matt W View Post
Hey,
Hey Matt,
I'm using Alloy screws which solves the problem completely! I know what you mean though, i had the same problem. Titanium would probably be fine too!
Hey Steve.
Quick question
The kit one isn't the best, it has a strong spring, but it is short also, which causes it not to get good strong leverage on the steering rack. I went with a Tamiya Servo Saver, but using a 3 Racing Purple 18mm Alloy Horn, gives more leverage and is a great, strong servo saver!
Hope this helps!
Ryan.
Awesomatix - Muchmore - Silverback - Roche - Radtec - LeeSpeed - Protoform - Futaba - Hiro Seiko - SG PitDesign
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Old 02-19-2011, 03:29 PM   #2166
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hope this helps!
Ryan.
Hey Ryan - do you happen to know the part number for that 3Racing arm?? I've been looking for that part
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-19-2011, 05:16 PM   #2167
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
3RAC-HTS30/PU
http://os.3racing.hk/products.php?products_key=4064
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 02-19-2011, 07:40 PM   #2168
k_bojar's Avatar
Originally Posted by RAL View Post
thanks!!!
Old 02-20-2011, 01:32 AM   #2169
Ryan Maker's Avatar
thanks!!!
Thanks RAL, That one is actually the smaller version of the one i use.
I use http://os.3racing.hk/products.php?products_key=4114
Which is 1,5mm taller, fits perfectly. Nothing wrong with that one, but i find the 18mm one to work better
Ryan.
Old 02-20-2011, 04:16 AM   #2170
k_bojar's Avatar
Ryan.
thanks, mate!!
Old 02-20-2011, 07:58 AM   #2171
Trader Rating: 77 (100%+)
Default Ball cups
Anyone using different ball cups. The kit ones seem weak and they are not perfectly straight once screwed on.
goin2drt is offline   Reply With Quote
Old 02-20-2011, 08:50 AM   #2172
Default Screw kit
Also does anyone know where to get AND part number for upgraded screw kit for the TCX.
Old 02-20-2011, 09:05 AM   #2173
k_bojar's Avatar
i've used the same ones on all my cyclones and they are anything but weak - especially the grey HPI ones that come in the kit...
alot of guys have swapped them out to get rid of some of the slack/slop in the suspension - not because of strength....I'm using Losi Type-R ends, opened up a little with an a hobby knife to allow the turnbuckle to start threading in...
as far as them not being straight - that's all on the assembler, man you need to pay attention and adjust as you build them because if a metal threaded rod (for all purposes) going into soft plastic - too much 'force' one way or the other will throw the rod off its straight course
Old 02-20-2011, 09:21 AM   #2174
Mine are not gray but good point on the assembler comment I will give it another go.
Old 02-20-2011, 09:51 AM   #2175
Originally Posted by BlueEagle View Post
Hey all, thinking of picking up a TCX for outdoor racing on medium to low grip asphalt (parking lot). Any recommendations on what extra things I would want for setup/spares? This is for boosted 17.5.
Anyone? Are parts so scarce that you don't want to compete for spares with one more person?
Different front axles and front arms seem like a good idea for durability, but was hoping someone could point me to a setup sheet and/or any other helpful swaps for a good build. Went through the last 50 pages in this thread and didn't see a good listing.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
