Old 02-13-2011, 06:34 PM   #2116
eceer's Avatar
Originally Posted by B18C Turbo View Post
wow that looks nice, where do you get it?
http://www.smokem-racing.com/Home.html
☞ Adelaide RC Team driver ☜
☞ Switchmedia ☜
☞ They're not toy cars, they are fine examples of engineering. When driven correctly are a joy to behold. ☜
eceer is online now   Reply With Quote
Old 02-13-2011, 06:52 PM   #2117
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by AGNO View Post
New chassis from Smokem!
My car looks good The chassis works really good guys, the car has more steering, more grip and is a lot more stable. Hopefully it works well at TITC next week
Originally Posted by mac853 View Post
Could somebody tell me where had Smokem guys found that gear diff?
Best regards
It is a custom made gear diff that my friend has made for me
On another note, im pretty happy with my car, i changed A LOT yesterday, even had the dremel out But finally got a consistant fast car that does everything it should do. The LTC-R body made a big differance.
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 02-13-2011, 08:09 PM   #2118
san.'s Avatar
Trader Rating: 59 (100%+)
Brand new TCX for sale:
New Hot Bodies TCX - Unopened $360 Free Shipping
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 02-14-2011, 07:39 AM   #2119
bigz's Avatar
is this stiffer than the current tcx chassis?
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 02-14-2011, 01:29 PM   #2120
fleetmaster's Avatar
Trader Rating: 16 (100%+)
No, that chassis is like the 416fx by smokem. More flex at the front and rear extremes of the car , from what I've heard, it's an excellent upgrade.....
fleetmaster is offline   Reply With Quote
Old 02-14-2011, 04:20 PM   #2121
The overall stiffness of both chassis is quite similar, just very different flex characteristics between the two chassis.
Antoni Caretti
Old 02-14-2011, 05:01 PM   #2122
Smokem Racing's Avatar
That's right Ant. The flex is more concentrated at the front and rear ends of the car. But the TCX-FX is slightly softer overall when compared to the standard HB chassis.
Don't beat them. SMOKEM...
shop.smokem-racing.com
facebook.com/smokemracing
Smokem Racing is offline   Reply With Quote
Old 02-15-2011, 02:51 AM   #2123
Anyone knows where can i get the PRO-D shaft (HPI-88914) in stock? Preferably in Europe?
Itchy is offline   Reply With Quote
Old 02-15-2011, 03:16 AM   #2124
jackdani's Avatar
you should say a "yokomo chassis"!!
by the way, it is clear that the yoko's works very well...so they are doing right with this one!
- Team Durando DNX408 v2
- Alpha a852 Lutz edition
- Runner Time fuel
- Sanwa m11x
- Pitshark.it
jackdani is offline   Reply With Quote
Old 02-15-2011, 06:05 AM   #2125
AGNO's Avatar
To be honest, the lightweight frame with holes for flex was first proposed by Hot Bodies at the TITC 2010, was later revised by Yoko...
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-15-2011, 01:08 PM   #2126
pitbull racing's Avatar
Hey guys does anyone know if the arms of the cyclone are any stonger than the ones on the tcx. I have been braking alot of them with some pretty small hits on the boards. Or any stonger one's out there
pitbull racing is offline   Reply With Quote
Old 02-15-2011, 01:13 PM   #2127
I had the same problem at one particular track. I think its down to the amount of thread on the axle sticking out past the wheel nut. Try either nylock nuts or cutting off some thread.
markrobinson is offline   Reply With Quote
Old 02-15-2011, 01:21 PM   #2128
san.'s Avatar
Do you mean the Pro4 arms? If so yes, the Pro4 arms are more durable. The Cyclone arms are the same as the TCX.
Just keep in mind, that you might have to make setup changes when using the stiffer arms.
Old 02-15-2011, 01:41 PM   #2129
Thank you now I just need to find some pro4 arms
Old 02-15-2011, 01:54 PM   #2130
Airwave's Avatar
One thing very important about arms breaking...
Be sure you are using right length screws to fix dampers to lower arms... If you are using +2mm screws (like I was, believing it could prevent some unscrewing...) you are in fact weakening the arm...
So when you hit something, the screw will "help" to break the arm...
Airwave is offline   Reply With Quote
SEO by vBSEO 3.5.0
