Old 02-12-2011, 01:09 AM   #2101
AGNO's Avatar
Spec-r are also excellent, though the originals TCX are by BANDO and are among the best available.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-12-2011, 04:18 AM   #2102
terryh's Avatar
Default Advice Needed
I have made the decision to get a TCX, however, the parts problem is holding me back, so, hoping you guys can assure me that it wont be a problem in getting parts, and maybe point me in the right direction on where to get them.
I also know the front dogbones are weak and there are alternatives around. What is the easiest way to overcome this problem? Also, when I buy the kit, is there any other parts I should be looking to buy at the same time, spares, and option parts that I should have/need when building the car for the first time? I'm not interested in fitting a gear diff at the moment so dont worry about that.
Any help you guys can give me would be gratefully appreciated.
Thanks in advance.
Terry
terryh is offline   Reply With Quote
Old 02-12-2011, 04:32 AM   #2103
warnos's Avatar
Just get the TCX.. I have not had a problem with the front drive shafts running 17.5 boosted. Running mod might be a different story.. running the slower classes the idea is they are more efficient.
Thanks in advance.
Terry
Just had to rebuild my diff as it was slipping last night.. can't wait for this Spec R Gear Diff to actually be avalible..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 02-12-2011, 05:35 AM   #2104
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Thanks in advance.
Terry
I haven't has issues getting parts...you just need to know where to look at the places that normally have a good supply..
right now, I cannot find front/rear arms at my normal 'cheap' store so I had to get them at closer to full price at another online location..
biggest thing you'd need to get spares is arms and front knuckles
the front bones will handle 17.5 - but I went and got the Pro-D 46mm shafts, just to be safe
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 02-13-2011, 07:56 AM   #2105
RaceAce701's Avatar
Trader Rating: 83 (99%+)
where did u pick up ur pro d shafts from
i spun the end off one of the alluminim ones right after the halloween racce
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 02-13-2011, 10:04 AM   #2106
Suspended
Trader Rating: 86 (100%+)
try rc market in hk or hpi site
littlealex is offline   Reply With Quote
Old 02-13-2011, 01:04 PM   #2107
k_bojar's Avatar
Rcmarket in hong kong - about the only place I found them at
Old 02-13-2011, 02:15 PM   #2108
RaceAce701's Avatar
ya i was afraid of that oh well i guess i have 2 sit down and see what else i need then
Alex "ACE" Kubilus
ACE design works
Old 02-13-2011, 02:28 PM   #2109
AGNO's Avatar
Default Smokem TCX-FX
New chassis from Smokem!
Old 02-13-2011, 02:30 PM   #2110
RC MARKET's Avatar
around later 2 weeks back instock again !
RC MARKET is offline   Reply With Quote
Old 02-13-2011, 02:44 PM   #2111
Trader Rating: 77 (100%+)
Default Rebuild ball diff
Time to re-do the rear ball diff. Anyone have the step by step to get it perfect. First time re-building.
Secondly who has the TCX front bumper in stock?
goin2drt is offline   Reply With Quote
Old 02-13-2011, 02:56 PM   #2112
k_bojar's Avatar
the foam part of the plastic part?
either should be readily available - looks like the same one I have on my other cyclones, which are the same ones that are on the Pro4 so a standard HPI issue foam bumper..
plastic is the same, lower is part of the body post kit from the Pro4/cyclones
Old 02-13-2011, 03:18 PM   #2113
Foam part.
Old 02-13-2011, 03:24 PM   #2114
SammyZ's Avatar
Trader Rating: 138 (100%+)
wow that looks nice, where do you get it?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 02-13-2011, 03:35 PM   #2115
mac853's Avatar
Could somebody tell me where had Smokem guys found that gear diff?
Best regards
mac853 is offline   Reply With Quote
