Old 02-07-2011, 07:57 AM   #2071
303slowdown's Avatar
Trader Rating: 21 (100%+)
if your spinning out on power i would add more front droop to transfer more weight to the rear of the car ,also blue rear springs could help too.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 02-07-2011, 08:15 AM   #2072
Thanks 303 will look at that too this weekend!
Anyone have a spring chart that shows the HPI/HB to Tamiya equivalents or there abouts as I only have Tamiya spring sets?
mr lee is offline   Reply With Quote
Old 02-07-2011, 08:33 AM   #2073
san.'s Avatar
Trader Rating: 59 (100%+)
http://www.hpiracing.com/graphics/in...2-V9-Color.jpg
The suggestion above is for the Blue Pro 4 (15.3) springs.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 02-07-2011, 08:34 AM   #2074
2xs
I have a chart I made with as many brands as I could find. HPI/HB, AE, Tamiya, Yokomo, Schumacher, Xray. Currently it is in excell, but I can turn it into a pdf to share when I get home from work. If anyone is interested in it just shoot me a PM.
2xs is offline   Reply With Quote
Old 02-07-2011, 08:45 AM   #2075
Thanks dude, excell is fine.
Old 02-07-2011, 08:48 AM   #2076
Yeah thanks I noticed that. I have a chart for the HPI springs and saw that it was a little softer than the silver. Just wanted to see how it compared to the Tamiya's as I have a couple of sets that I can use instead of buying HPI ones.
Cheers
Old 02-07-2011, 09:29 AM   #2077
mojoman's Avatar
Thanks very much for the suggestion mojoman! I see that on Ty's setup sheet he also has the 1,5mm shims.
In technical terms how does dropping the inside rear camber link height effect the rear from breaking away?
BTW I am already running the kit 3 degree rear toe block.
Dropping the camber links will give you more camber gain through the corners as your car leans there will be more contact patch on the tire. If you haven't already tried to increase the rear camber to 2* that should help as well. As stated more front droop will help as well.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 02-08-2011, 12:27 AM   #2078
Thanks for the explanation dude!
I am running a fraction off 2* all round....probably 1.95
Will try move to 2* exactly and see from there then will try the rest of the suggestions.
Old 02-08-2011, 01:14 PM   #2079
fleetmaster's Avatar
Trader Rating: 16 (100%+)
From what I understand , it makes that end of the car roll deeper into the corner, generating more grip.
Have you taken the rear top deck screws out to allow more flex ? You could try this if all else fails......
fleetmaster is offline   Reply With Quote
Old 02-09-2011, 05:29 PM   #2080
Trader Rating: 77 (100%+)
Default spur gear
I need a 94t spur gear. What brand and part number will fit? I tried a Precision Racing and the holes did not line up. Thanks so much.
goin2drt is offline   Reply With Quote
Old 02-09-2011, 05:40 PM   #2081
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Default RE spur
i've installed RW for xrays fit great. can only use two screw holes
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 02-09-2011, 07:57 PM   #2082
stitchy's Avatar
RW Supalite gears
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 02-10-2011, 12:16 AM   #2083
windstar's Avatar
I'm using the robitronic gears, they got holes in it, so no problem with the screws of the motor.
windstar
No TC at the moment, Team Associated RC5.2 x 2, Tam Associated RC10 B6, T.O.P Racing Rebel 12 (2013), VBC Lightning 12M, Sanwa M12
windstar is offline   Reply With Quote
Old 02-10-2011, 01:19 AM   #2084
AGNO's Avatar
Originally Posted by stitchy View Post
+1 I always use these.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-10-2011, 02:43 AM   #2085
Ooh never thought of removing the screws, thanks dude!
I will have lots of testing to do this weekend....during the race meeting ....its all good as it is my first time doing 10.5 so don't expect to get to the top just yet.
