Old 02-04-2011, 07:04 AM   #2056
SammyZ's Avatar
Trader Rating: 138 (100%+)
japanese touring master Atsushi hara!!
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 02-05-2011, 04:17 AM   #2057
Send a message via AIM to Matt W
Default Mike Haynes
Hey,
I was just wondering what turnbuckles you used with the losi type r cups because the standard HB ones r not long enough?
Matt W is offline   Reply With Quote
Old 02-05-2011, 08:15 AM   #2058
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Cyclone Bender View Post
Maybe with all the money they would save they could make some spare parts for the rest of us to keep our cars running. Just a thought....
It's a business and Haynes is good for sales. I understand where you are coming from but those of us who arent masters of driving or setup we need a person to help with setup. I'll take a person who knows the car in and out over a few spares.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 02-05-2011, 11:31 AM   #2059
fleetmaster's Avatar
Trader Rating: 16 (100%+)
I think he was referring to a lack of spares being available for the general public to buy, not looking to score freebies ..........
Also, that sponsoring Mike Haynes would help in saving money ( to make the parts we all need available ) , by not dumping a heap of money to bring Hara and the others out to the U.S.......
This is how I read it anyway ?!
fleetmaster is offline   Reply With Quote
Old 02-05-2011, 12:17 PM   #2060
b_recliner's Avatar
Trader Rating: 22 (100%+)
Hire Haynes. Get me the supplies I require.
Tracks: Richfield Raceway, LCRC, DRP
Current Cars: Xray t4 '14, Schumacher Cougar KF, Schumacher Mi5, Losi 22 2.0, Losi 8ight E 3.0
b_recliner is offline   Reply With Quote
Old 02-06-2011, 05:49 PM   #2061
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Selling a TCX if anyone wants one
FS- Hardly used Hotbodies TCX
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-07-2011, 03:42 AM   #2062
Any ideas on keeping the rear from stepping out on rubber asphalt?
I am running the kit setup with both front and rear shocks mounted three holes from middle of shock tower, silver sway bar front and copper at rear.
I removed the rear sway bar which help a little and was also told to remove more droop (to have very little) which did not really help much, actually made it slightly worse!
Am running Sorex 36's.
Any help would be greatly appreciated!
mr lee is offline   Reply With Quote
Old 02-07-2011, 04:44 AM   #2063
san.'s Avatar
Trader Rating: 59 (100%+)
Mr Lee, you need to post your entire current setup, if anyone is going to be able to give you pointers.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 02-07-2011, 04:53 AM   #2064
Don't know what else to add.....its the standard kit settings with the small changes mentioned above!
Old 02-07-2011, 06:07 AM   #2065
AGNO's Avatar
In Italy we always use controlled tires Sorex 36 indoor and outdoor, this basic setup works very well, a lot of grip and easy to drive, it works well also with gear diff.
http://www.petitrc.com/reglages/hotb...926/index.html
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 02-07-2011, 06:08 AM   #2066
san.'s Avatar
I just thought it would be easier for the HB Team Drivers to look at your setup details here on the forum, instead of referring back to the manual.
Here's Ty's setup from Paved Nationals you can use as a reference.
http://www.hotbodiesonline.com/pdfs/..._Nats_2010.pdf
Old 02-07-2011, 06:35 AM   #2067
2xs
Entering or Exiting the corner?
2xs is offline   Reply With Quote
Old 02-07-2011, 06:46 AM   #2068
Exiting a corner! I really have to back off and wait for the car to run straight before I can apply power otherwise it just slides/spins out.....
My diff is really smoothe and has a very slight amount of slip. Have heard that a tight diff could cause these problems I am having but I don't think it can be the problem here!
Oh am also running an LTCR.
Thanks for the setup sheet San. I did look at that when setting mine up but just decided to go with the shock tower mount settings and leave the rest as standard hence I mentioned that above.
Old 02-07-2011, 06:57 AM   #2069
mojoman's Avatar
Try adding more toe to the rear. You can also go to a 1.5mm or 1mm shim under the inside rear camber links ie: drop them. Lastly you can reduce your roll center by dropping you rear lower arms. Instead of a 1.5mm shim try a 1mm.
HTH,
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 02-07-2011, 07:16 AM   #2070
Thanks very much for the suggestion mojoman! I see that on Ty's setup sheet he also has the 1,5mm shims.
In technical terms how does dropping the inside rear camber link height effect the rear from breaking away?
BTW I am already running the kit 3 degree rear toe block.
