Old 01-29-2011, 02:11 PM   #1996
AGNO's Avatar
Originally Posted by Matt W View Post
if the only problem with the 3racing 39t pulley is a slightly looser belt, i assume u can tighten it back up by rotating the bearing holder?
No, unfortunately, is not enough even the minimum position, the belt is still excessively tight
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-30-2011, 02:24 AM   #1997
mac853's Avatar
Oh really, looks of we have to change the longer belt?
Originally Posted by Marcel View Post
It's a Photon belt in front and a Serpent belt (front belt from a nitro car) in the rear.
Could somebody tell me which car belt of Serpent is meaning about, please?
Best regards
mac853 is online now   Reply With Quote
Old 01-30-2011, 02:47 AM   #1998
Send a message via AIM to Matt W
Default 3racing gear diff
Thanks for the advice agno,
i assume to get it to work you have to run the 38t pulley, tc belts and sakura zero pulley on the spool? Do you know how this affects the final drive ratio?
Matt W is offline   Reply With Quote
Old 01-30-2011, 06:59 AM   #1999
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Mike Haynes won Touring Expert!
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 01-30-2011, 07:14 AM   #2000
http://www.serpent.com/product/804104/
This one should fit if you use a 40tooth pulley in rear. Looks "Heavy duty" in a electric touring car.
regards
Marcel
Marcel is offline   Reply With Quote
Old 01-30-2011, 07:27 AM   #2001
AGNO's Avatar
38 pulley on diff and sakura pulley on TCX spool with standard belts TCX, internal gear ratio 1,9.
Old 01-30-2011, 07:39 AM   #2002
AGNO's Avatar
I saw the race live streaming, big victory by Mike Haynes, congratulations.
Old 01-30-2011, 08:45 AM   #2003
mac853's Avatar
regards
Marcel
What, 195T?
But TCX rear belt has just 64T, isn't it?
Old 01-30-2011, 08:46 AM   #2004
Do you think the sakura spool will fit in the tcx because that will save drilling new holes? Do you have the part number for the sakura spool pulley, is it the one way, roller or differential?
Also im using the yokomo bd5 outdrives on the hb spool so they should be able to fit on the sakura spool aswell.
Old 01-30-2011, 09:56 AM   #2005
Originally Posted by mac853 View Post
What, 195T?
I think it's 195mm overall lenght.
195mm / 3mm per tooth = 65T
regards
Marcel
Old 01-30-2011, 11:42 AM   #2006
mac853's Avatar
regards
Marcel
But could be usable with 39T pulley of 3racing than not be too loose?
Thanks for your reply anyway!
Old 01-30-2011, 11:44 AM   #2007
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Glad to hear that - Mike's a good guy and I'm glad to see the TCX agrees with him
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-30-2011, 12:00 PM   #2008
I'm using it with the 40T Yokomo gear diff...
regards
Marcel
Old 01-30-2011, 01:09 PM   #2009
EJ20's Avatar
Default Snowbird 2011
Congrats Mike Haynes!
- HOTBODIES - AHRP -
EJ20 is offline   Reply With Quote
Old 01-30-2011, 02:21 PM   #2010
SammyZ's Avatar
Trader Rating: 138 (100%+)
goodjob michael haynes on your win!
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
