Old 01-28-2011, 08:52 AM   #1981
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by David Galdo View Post
Did you re-sign a new contract yet?
No I haven't. Do you think that's the issue? Who do I contact to extend my contract? Is hiro or perez still with hb?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 01-28-2011, 12:07 PM   #1982
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Sent you a PM.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 01-28-2011, 02:35 PM   #1983
Send a message via AIM to Matt W
Default Gear Diff
Hey guys,
any news on when the spec r gear diff will be available for the tcx, they keep changing the release date!! I cant believe they created a diff for with almost every size pulley and missed our car out, very annoying!!
Matt W is offline   Reply With Quote
Old 01-28-2011, 08:30 PM   #1984
AGNO's Avatar
Originally Posted by Matt W View Post
Hey guys,
Yes, it is true they have further delayed the delivery, it is now February 10
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-28-2011, 08:42 PM   #1985
ngo8's Avatar
Send a message via ICQ to ngo8
i cant wait to get a leaky gear diff for my TCX
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 01-28-2011, 09:12 PM   #1986
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
My Non leaky gear diff is going great But i will get a leaky one for the front
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-29-2011, 02:39 AM   #1987
AGNO's Avatar
Even my 3Racing works very well , only I'm curious to try the Spec-R .
Old 01-29-2011, 03:56 AM   #1988
Default 3racing gear diff
what is this 3racing gear diff people keep talking about, does it work in the tcx or does it need alot of modifying??
Old 01-29-2011, 05:47 AM   #1989
AGNO's Avatar
Need two modifications, are described here
Hot Bodies TCX
Old 01-29-2011, 07:15 AM   #1990
Thanks Agno,
I assume as 3racing have now created a 39t pulley there is no modification needed appart from shimming!! just a couple of questions tho........
+ I assume the hb driveshafts with the blades fit fine?
+ Does the diff leak at all?
+ Do you find the plastic gears wear or break easily?
+ What weight oil is best for high grip carpet, I hear 1000 is good for tarmac and around 3000 for carpet?
Old 01-29-2011, 08:24 AM   #1991
Mike Haynes (TCX) TQ'd ahead of Dumas (Top) and Kevin Hebert (AE).
V-Dezign 4.0
Old 01-29-2011, 09:02 AM   #1992
RaceAce701's Avatar
Trader Rating: 84 (99%+)
good job mike bring it home
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 01-29-2011, 12:22 PM   #1993
AGNO's Avatar
Thanks Agno,
Unfortunately 39T pulleys are wrong and can not be used (at least my)
+ The blade HB fit perfect
+ The 3R diff dont leak
+ Now seems to no wear
+ I use 1000, but for carpet is best 2000/3000
Old 01-29-2011, 01:22 PM   #1994
mac853's Avatar
Yes, the 39t gear diff pulley is slightly bigger than car's original 1, but i think this is not the big matter.
Since loose the belt is usable.
mac853 is offline   Reply With Quote
Old 01-29-2011, 02:04 PM   #1995
Default 3racing 39t pulley
if the only problem with the 3racing 39t pulley is that its bigger and tightens the belt, i assume u can loosen it back up by rotating the bearing holder?
