Hot Bodies TCX
#1951
#1952
Anyone know of a upgraded (stronger) front driveshaft for the TCX? These purple ones that you get seem to be super weak for modified. Im up to my 6th one. Ive used TOP photon ones but there very small pin on the end of the dogbone and it flops around in outdrive cup.
anyone got a remedy? gotta be 46mm.
#1953
#1954
these fit good?
#1955
http://rcmarket.com.hk/product_info....oducts_id=7650
http://rcmarket.com.hk/product_info....oducts_id=5901
#1956
#1957
Hugh,
Thanks, now i know why you guys were finishing races and i wasnt lol.
Never mind. .. . my driveshafts were braking when i hit the brakes on the straight. lol haha
I will get the HPI steel ones. Thanks all
#1958
HPI # 88914 are perfect, can be mounted without modifications and is very durable, the use for many months, combined with the cup joint also have little chatering.
#1960
The Yokomo Driveshafts/Spool Outdrives sound like a good idea for the TCX
........I've also gone through 6 of the Kit 46mm Driveshafts, since I've Owned the Car
A good alternative that I recently found & changed to were the 46mm Steel Driveshafts from Tamiya - Part No 51092.
........as the Pins are smaller on those, it meant that they had to be Removed, the Holes were then Opened up slightly with a 3/32 Drill Bit, so the Std TCX Pins(from a Broken pair of HB 46mm Driveshafts) could be Installed!
They are now an absolute Perfect Fit, allow me to carry on using the Std TCX Spool Outdrives & being Steel, they are Super Durable!!
.....it also still gives me the Option of using the 'Upgrade' HB POM Solid Axle Cup Joints(Part No 67731), if I ever decide to use them!
Dean.
Dean.
#1961
I ran the Hotomo spool this weekend. Used BD5 steel outdrives, filed down to fit the HB spool. I used Tamiya steel 46mm drive shafts, the HB Axles & needle rollers. I also opted to use the TOP Photon Axle covers, and do away with using a grub screw in the needle roller to secure the pin. Also used the TOP pins that come with the covers as they are slightly longer than the HB items, and also used the BD5 pins that came with the outdrives to connect them at the spool.
Worked so well I didnt even have to think about them all weekend !!!
Im going to opt for the steel Yokomo 45.5mm shafts once they arrive as they are a snugger fit in the outdrives.
Pictures will be posted up tonight on www.UKRCRacer.co.uk !
#1962
If you put the oneway in as a spool you can run 44mm steel driveshafts with no mods.Anybody know if anybody got the gear diffs for these yet as i want one for our nationals in 14 days.
colin
Currently running a tamiya one.
colin
#1964
Click on the following link for a pic of the spool. The pics are large so bear with them loading up.
The pics are of the outdrives, filed down using a dremel and spinging up the outdrive in a drill to get a flater finish. The drive shafts are a combo of Tamiya, HB & TOP. I used the TOP drive pins through the hub and needle roller. I also used the Yokomo pins to secure the outdrives.
Spool Outdrives
Spool
Fitted Spool
Drive Shafts
Thank you to those drivers who had the ideas on what to use, helped me settle on this and it works a dream. Going to swap to Yokomo steel 45.5mm drive shafts as these WILL fit ok.
Spool Outdrives
Spool
Fitted Spool
Drive Shafts
#1965
Spool Outdrives
Spool
Fitted Spool
Drive Shafts
Spool Outdrives
Spool
Fitted Spool
Drive Shafts
