Old 01-17-2011, 07:18 PM   #1891
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Yokomo_Ant3 View Post
Wait till you put some power into the car The std ones will snap under braking load in modified.
I only run boosted 17.5 and they are fine.
LCRC Raceway http://www.lostcreekcycles.com/lcrc.htm
Proline Racing http:://www.prolineracing.com
jmackani is offline   Reply With Quote
Old 01-17-2011, 07:42 PM   #1892
Dog Bone's Avatar
A pro driver at a recent race I participated in switched to the pro-d steel drive shafts simply because the aluminum ones were just not up to the task. And he didn't hit *anything*.
This was after he replaced one aluminum drive shaft as the ball-end was starting to deform, and two quallies later, one of them broke. The aluminum drive shafts just aren't strong enough.
This was in the 13.5 Boosted class....
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 01-17-2011, 07:50 PM   #1893
mangoman's Avatar
You will probably find even clipping a dome/kerb and jumping in the air/landing will put a lot of stress on the unis with a spool in there.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 01-17-2011, 07:54 PM   #1894
jmackani's Avatar
I must have the special ones that have no issues yet then. Then again, I am not a pro either.
Old 01-17-2011, 07:56 PM   #1895
jmackani's Avatar
No disagreement on the spool part.
Old 01-18-2011, 05:49 PM   #1896
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
ok - got a crazy question...
i thought I saw this in the thread, but can't search and find to save my life
did I see someone say that they use TOP pivot balls because they are longer then the HB ones?? this would be to help take out some of the slack in the suspension arms???
am i going nuts?!?!?!??
thanks
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-18-2011, 08:47 PM   #1897
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Default top links
I've been using the Top Links and pivot ball system on the car...removed 90% of the slop...
Used the short Top Photon ball ends and Lunsford TI rods.
Steering rack - file about .25 mil from the inner links, each one, other wise may bind.
* make sure to locktite the screws let dry then place the capture ball and torq down.
Can't put the Top pivot ball on the inner camber links...(or at least I didn't want to take the chance of it becoming loose). I will try to use a low profile 3mm screw from the bottom of the camber plate, just needs to clear the spool.
only thing left is to buy the shim kit for the steering rack and all slop will removed.
All together spent about $35 bucks....2 pack of links 2 packs of pivot balls and 3mm screws and TI Rods
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 01-19-2011, 12:13 AM   #1898
bukil's Avatar
Trader Rating: 39 (100%+)
We use the tc5 lunsford titanium turnbuckle kit w/ losi jrxs type r islets. No slop.
HB ballstuds work with this combo.
☆ ActivRC ☆
bukil is offline   Reply With Quote
Old 01-19-2011, 01:36 AM   #1899
k_bojar's Avatar
I'm sorry, I didn't make myself clear But I like some of those suggestions
I meant in the lower suspension arm pivot blocks - the ones that attach to the chassis, the ones that hold the suspension arms to the chassis
Old 01-19-2011, 06:41 AM   #1900
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Default Crafty
Found this photo from the DHI cup, someone got crafty Lots of yokomo parts there
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-19-2011, 07:04 AM   #1901
olhipster1's Avatar
just use .25 shims....and all arm front to back slop will be gone.
I wouldn't want to remove the ability to adjust the arm so I would keep that to original specs.
I think you're probably talking about the TOP parts for the old car "Scythe", but thought most the suspension parts for that car were the PRO4, Cyclone parts.
CAUSE and EFFECT
Old 01-19-2011, 10:32 AM   #1902
Yep, that's my car, i fitted a yokomo gear diff during the DHI CUP.
I'm also using the yokomo steering arms, just to get more steering in thight corners. The car worked very well in the finals...just missed a better result because of my bad driving in the qualifing
regards
Marcel
Marcel is offline   Reply With Quote
Old 01-19-2011, 12:10 PM   #1903
Hugh Jazz's Avatar
regards
Marcel
What belts did you use?
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 01-19-2011, 12:38 PM   #1904
I have been trying to get a 416 Spec R Gear Diff but cant seem to find one. I know there is a post detailing exactly what you need when fitting the 416 version, can someone please advise what is needed when fitting a BD5 Spec R Gear diff as these seem easier to get.
Thanks in advance
Stephen_102 is offline   Reply With Quote
Old 01-19-2011, 12:45 PM   #1905
dawgmeat's Avatar
Thanks in advance
Is that a custom chassis
dawgmeat is offline   Reply With Quote
