Hot Bodies TCX
#1862
@ cyclone speed
You can try a harder rear anti roll bar. Go up to 1,4mm thickness. Will make the car more easy on power.
#1863
#1864
#1866
#1867
balance
thanks for the photos San. i have another question, this weekend i ran my car and noticed that the shocks, at 64mm in length; i could not get anymore droop past 6. do alot of people run the tcx like this or lengthen the shocks alittle more for performance or is in better to keep them at 64mm.
#1868
I think it was Ty or Andy's setup that I noticed 64.5mm shock lengths.
#1869
LOOKING FOR SOME HELP
I RECENTLY BOUGHT TWO CYCLONE TC'S FROM A GUY AND THE FIRST DAY I WENT RACING I BROKE THE SERVO SAVE TUBE WHICH IS FINE SO I ORDERED ANOTHER ONE BUT WHEN I WENT TO SWITCH IT OUT THE GUY GLUED THE INNER TUBE INTO IT.. SO I AM HOPING THAT SOME ONE HAS JUST THE SMALL INNER TUBE THEY WILL PART WITH I REALLY JUST DONT HAVE THE EXTRA MONEY LATING TO SPEND ON EXTRA PARTS I REALLY DONT NEED.. I DONT NEED THE SERVO SAVER OR THE SPACERS ALL I NEED IS THAT SMALL INNER TUBE.. I ATTACHED A PIC BELOW SO EVERYONE KNOWS WHAT I AM TALKING ABOUT SINCE I PROBABLY DIDNT DESCRIBE EVERYTHING PROPERLY AND I AM SURE I DIDNT CALL THE PARTS BY THERE CORRECT NAME..
#1870
That tube is not a part of this TCX kit. Wrong thread, try thread:
http://www.rctech.net/forum/electric...ml#post8426993
#1871
Best battery for TCX
Hi,
I happy that I have received TCX! so new chasis new questions... Maybe you can advice what battery best for TXC? I mean, weight, size and power.
I use:
Standard TCX chasis
Tekin RC ESC
Tekin Redline 17.5 motor
Savox low profile servo
I am racing mostly on medium or high grip carpet with rubber tires. Our weight limit is 1350g.
Thank you for any advices.
I use:
Standard TCX chasis
Tekin RC ESC
#1872
Hi,
I use:
Standard TCX chasis
Tekin RC ESC
I use:
Standard TCX chasis
Tekin RC ESC
#1873
Went testing today, got a chance to run a 0 block, and it was bloody awful...
Im convinced now that less front arm sweep , gives more initial, as it was soo aggresive on initial turn, i could'nt handle it over a 5 minute run, aswell as my laptimes being slower, found it quite strange that the car reacted so much with the change, completely different animal
Went back to the 2.5 block and all was good again.
#1874
#1875
I wouldnt go longer than 65mm if you want to use higher ride heights as we talked about a few pages back
