Old 01-09-2011, 10:32 AM   #1801
AGNO's Avatar
Originally Posted by dameetz View Post
Finally done....and raced it today for 1st time.....got TQ and won at our local series race....I just follow Agno's set up (thanks bro) posted few pages back with only few changes on the droop and ride height....the car was dialed straight away....
Here's the pic of it...
Excellent Dameetz! I am happy that my setup was to help.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-09-2011, 12:06 PM   #1802
SpeedySST's Avatar
Originally Posted by S.A.W View Post
Hi,
Is there supposed to be an O ring in the 'cylinder nut' #HB70720 ? as mine turn really easy, I think they might move while racing.
X ray cyclinder nuts work as well. Just depends on if you like the silver color.
SpeedySST is offline   Reply With Quote
Old 01-09-2011, 12:21 PM   #1803
AGNO's Avatar
Hi,
There is a problem with the use of nuts with Oring (I've to tried) the thread of the shock is not sufficient to adjust the ride height... however the original work well and do not become loose
Old 01-09-2011, 12:24 PM   #1804
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Originally Posted by goin2drt View Post
I love my TCX and I am sure all the guys in this thread do as well. The ability to get parts is REALLY wearing thin on my patience. Something to consider if you have not purchased one yet.
however, it seems everyone is starting to get their inventory of HB parts back in stock also, unless your track has a large HB following, you'll always have issues getting parts - same thing if you're a tamiya guy in xray land
suspension-wise - they are the same as the TC, wish i have spares of...diffs appear to essentially be the same except for the longer outdrives..
but is there any huge improvement over the old cyclone?
and, this isn't a TCX question - but what's with the fans coming back on the TC chassis again?
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-09-2011, 12:25 PM   #1805
John Doucakis's Avatar
dameetz
Nice looking car. I like how you are color coordinated. Is that some kind of wrap on the speedo and servo?
S.A.W.
A quick fix is to 'scratch' inside the treads of the cylinder nut with a knife or any sharp tool. Just make 3-4 vertical cuts on the threads.
This will make the nut spin much less but it won't harm it.
John Doucakis is offline   Reply With Quote
Old 01-09-2011, 02:01 PM   #1806
warnos's Avatar
For me I had my 1st run with it yesterday.. with a setup I am still working on... the car's fastest lap is 0.2 sec faster then my old Cyclone Exotek TC and thats with tires that were almost dead... I was pretty happy with this as the car felt so different to my old car then I saw the lap times were better.. really does feel like the car turns so much better. Way more balanced.
One bad thing about the car.. man are the pinions and spurs a pain to change when compared to the TC.. but thats ok..
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 01-09-2011, 02:51 PM   #1807
Hi,
For adjusting roll, when should I use spacers under the blocks versus tuning with roll bars?
Thanks in advance.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 01-09-2011, 05:26 PM   #1808
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Exactly why a few people here dont use them. This is only a problem though if you make the shock longer for more droop. I think if you run the shock length at 64mm they will just be ok.
Go from underneath the car to undo/tighten the pinion. Thats how i do it and its really easy.
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 01-09-2011, 08:28 PM   #1809
TYTESSMANN's Avatar
I need a little help, I don't run tc alot and I haven't run the 13.5 in the TCX yet but I am going to be running 13.5 TC next weekend on a 40 x 70 track , usually very tight layout, I am wondering what gearing I should start with, I am running a 115T spur with an LRP 13.5. Thanks.
HotBodies/HPI Racing, Proline Racing, O.S. Engines, Orion, Savox, A Main Hobbies, Upgrade RC, Savox, Muchmore, Avid, Lunsford, MIP, 110% Racing, LMR, MR33, Zig Racing, Live RC, Red RC, Neobuggy.net, tytessmann.com
TYTESSMANN is offline   Reply With Quote
Old 01-09-2011, 09:17 PM   #1810
san.'s Avatar
Trader Rating: 59 (100%+)
Ty, what speed controller and firmware version?
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 01-10-2011, 02:13 AM   #1811
Trader Rating: 24 (100%+)
anyone used a gear diff in a TCX yet? if so which one and how did u fit it
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 01-10-2011, 03:49 AM   #1812
The Xray 38T spec R and Tamiya 37T spec R also fit when you change the front pullies/Belts. You can also convert an NT1 diff
Antoni Caretti
Old 01-10-2011, 04:28 AM   #1813
AGNO's Avatar
I use the 3Racing, here are the instructions for assembly.
Hot Bodies TCX
Old 01-10-2011, 06:29 AM   #1814
Mike Haynes's Avatar
I converted my driveline to 40tooth like top/yoke, and use spec r, you need 3mm longer belt front and rear for it to work.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 01-10-2011, 06:57 AM   #1815
The Spec-R gear diff for TCX will be end of this month ready! So no need to modify other gear diffs.
FreddySudhoff is offline   Reply With Quote
