Old 01-07-2011, 10:07 AM   #1771
louielou's Avatar
Trader Rating: 16 (100%+)
Default parts
does anyone know where i can find 1.5deg, 2.0deg, 3hole shock pistons, and DCJs here in the US.
Also how are u guys installing the hudy ECS drive shafts, and which shafts r they; along with any other parts i might need?
And for the Spec R gear diff what else is needed to make this install work the right way? Any help or point in the right direction appreciated.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 01-07-2011, 10:31 AM   #1772
2xs
All of the US sources that I am aware of are sold out of the pivot blocks. But for shock pistons you can use TRF416. I have tried Schumacher pistons in a set of shocks and they seem to work. They are not ideal as the diameter is 0.1mm smaller than the HB piston.
2xs is offline   Reply With Quote
Old 01-07-2011, 10:37 AM   #1773
Mike Haynes's Avatar
I have schui pistons in mine, drilled to 1.1, have been working well
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 01-07-2011, 10:45 AM   #1774
2xs
Are those 1.1mm 3-hole pistons?
Old 01-07-2011, 11:41 AM   #1775
ngo8's Avatar
Send a message via ICQ to ngo8
you can also use the tamyia 3 hole pistons they are adirect fit and work really good .
Xray|ORCA|Sanwa|Trinity|KoPropo
ngo8 is offline   Reply With Quote
Old 01-07-2011, 11:46 AM   #1776
san.'s Avatar
Trader Rating: 59 (100%+)
Available here:
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=2
And in black here:
https://www.ssl-stormerhobbies.com/c...ns&pn=HOT61395
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 01-07-2011, 11:48 AM   #1777
ali_g's Avatar
freddy,
do you have any setups for low traction asphalt tracks?
☆ JU.C RACING ☆
https://www.facebook.com/Ju.Cracing
ali_g is offline   Reply With Quote
Old 01-07-2011, 01:04 PM   #1778
mojoman's Avatar
does anyone know where i can find 1.5deg, 2.0deg.
I found all the blocks including the discontinued 1 deg on ebay.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 01-07-2011, 02:27 PM   #1779
steveonamission's Avatar
Originally Posted by steveonamission View Post
So, i've only just got around to fitting different front pivot blocks, i wanted to try a 0, so no front arm sweep, noticed as i fitted it, the ackerman steering increased, but what i didnt like, was the driveshaft angle did too! Doesnt seem right to me, ive got driveshaft sweep now.
Anyone running a 0 degree block? Wondering if anyones running kit ackerman of 4mm with it, turnbuckles are in a very aggresive ackerman position with it.
What about the driveshaft angle? Would that effect the car at all?
Thanks for anyones input.
steveonamission is offline   Reply With Quote
Old 01-07-2011, 02:54 PM   #1780
AGNO's Avatar
I often use the 0 pivot, my impression is that the model is a little less reactive, but the curve runs more consistently.
With 4mm thick it has little ackerman.
Using 2 x 1.5 mm to keep centered the suspension arm and I have little driveshaft angle.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-07-2011, 03:04 PM   #1781
Trader Rating: 77 (100%+)
Default Going crazy
Taking the ol' TCX out to WCRC this Saturday for the first time in about 3 weeks. Been a while and I can't hardly wait.
Just thought I would share
goin2drt is offline   Reply With Quote
Old 01-07-2011, 09:20 PM   #1782
ngo8's Avatar
Bring youre spare parts you will need them
Old 01-07-2011, 09:36 PM   #1783
louielou's Avatar
Default shock pistons
Thanks for the info everyone. I'll have my New TCX by monday, can't wait!
Any idea what the part number might be for those Tamiya 3 hole shock pistons.
Luis
Ebay account LOU840
Old 01-07-2011, 09:46 PM   #1784
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Search for this on google: tamiya 53573
Ty is offline   Reply With Quote
Old 01-07-2011, 11:21 PM   #1785
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
hey all...i'm debating about getting one of these and retiring my ol' black cyclone...
is there any real advantage - aside from the lipo config on the tcx - to the TCX if i have the exotek HBX chassis, 18T pulleys and pro-spec rear diff on my cyclone?
also, what are the 'must' have upgrades for the TCX? i'll probably just be running super stock with it
thanks!
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
