Old 01-04-2011, 10:04 AM   #1741
M3Armand's Avatar
Originally Posted by CSF0623 View Post
The c-hubs and steering blocks were carried over from the first Cyclone, so there is no change with that. As for the arms on the TCX they came from the last car the TC. Yes, they are a bit brittle (graphite) ....
Looks like the C hub carriers and the hubs (aka steering blocks or knuckle arms) are carryover from the HPI Pro4! These are the "graphite" parts and looks like have been known to be brittle going back to the Pro4.
So can someone tell me what is the advantage of using these parts when the same parts from the Sprint 2 are a direct fit and seem to be made of the same plastic as I have in my older RS4 Pro which have never broken on me?
M3Armand is offline   Reply With Quote
Old 01-04-2011, 11:17 AM   #1742
CSF0623's Avatar
Graphite has less flex which can give you more control, but that lack of flex will most likely break during a bad enough wreck rather than give a bit like plastic.
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 01-04-2011, 11:19 AM   #1743
CSF0623's Avatar
Originally Posted by John Doucakis View Post
Kit almost done
Electronics to be installed when I find what I am looking for.
Click on the photos for more..
Are your front MIP CVD's from the Cyclone? BTW nice build on your TCX!!
Carl F.
ACTIVRC.COM P1BRAND
Old 01-04-2011, 12:32 PM   #1744
M3Armand's Avatar
Sounds like I'm leaving the Sprint 2 parts on... you can't control the car when one wheel is flopping around since the graphite hub broke...
Old 01-04-2011, 12:54 PM   #1745
John Doucakis's Avatar
Originally Posted by dameetz View Post
What balls are you using on the shocks top and bottom?
Sorry mate, I cannot disclose any info about my balls. Its a private matter.
TAMIYA
Top end: 53599 Fluroine Coated 5mm Alum Ball Nut
Low end: 54209 Fluroine Coated 5x5mm Alum Ball con/tor
only in combination with
HPI A471 - Nitro RS4 shock parts set
Thanks!
HPI PRO4 MIP 46mm, although I think the Cyclone's 44mm MIP would also fit.
John Doucakis is offline   Reply With Quote
Old 01-04-2011, 01:39 PM   #1746
dawgmeat's Avatar
Whats the release date for the gear diff?
dawgmeat is offline   Reply With Quote
Old 01-04-2011, 03:14 PM   #1747
san.'s Avatar
Trader Rating: 59 (100%+)
The MIP 44mm will only fit the rear TCX setup, not the front.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 01-04-2011, 03:41 PM   #1748
Airwave's Avatar
I was very disappointed by the Pro4 46mm MIP... In fact they are thinner than the Moore version.
One race without any big crash and my MIP is twisted just under the pin...
I thnik I'm definitely into the Yokomo thing... So let's me summarize once again:
- I order this part YOKOMO BD5 FRONT UNIVERSAL SHAFT 45.5MM
- And this one YOKOMO BD-5 FRONT SPOOL REPLACEMENT SET
- Sand the outdrives 1mm to made their hole align with the holes in my TCX spool
- Replace my TCX MIP by the UNIVERSAL SHAFTs on my front drive (nothing else to do, direct fit)
And tada, I got a TCX BD5
Can't believe this is so simple, really?
Airwave is offline   Reply With Quote
Old 01-04-2011, 03:59 PM   #1749
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Watch out though, STD Yokomo outdrives are weak, and won't last many(any) big crashes on indoor tracks.... Get the steel ones if you can
Luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 01-04-2011, 04:18 PM   #1750
Airwave's Avatar
Oh you talk about these UNIVERSAL DRIVESHAFT FRONT STEEL ?
Can I mount these directly instead of my purple dogbones?
Will the Yokomo assemble with the HB Coupling and the HB universal axle without problem?
Old 01-04-2011, 05:27 PM   #1751
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Yes it is that simple Lucky ive owned a few cars over the past year so had the parts to muck around with and find out what fits Luke is talking about these Spool outdrives: http://www.rc-mushroom.com/product_i...ducts_id=19229 Although the steel ones would offer a bit more driveshaft chatter from what i found on the Yokomo, and would be a lot harder to remove the "lip" without a dremel or grinder.
Luke
The Yokomo outdrives are MUCH stronger than the Tamiya ones. The Tamiya ones only lasted 3 cornerns when i first drove with them They snapped under brakes The best way is to use the plastic outdrive with a sleeve over the top and they wont break anymore
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 01-04-2011, 11:04 PM   #1752
Airwave's Avatar
Oups my bad!
I was sure he was talking about the dogbones...
Ok so the BD-010F are ok, but with YOK-D-046...
Finally...
Old 01-04-2011, 11:04 PM   #1753
Hugh Jazz's Avatar
Are these the sleeves you are talking about
http://www.rc-mushroom.com/product_i...ducts_id=17764
Dont know if i like the idea of blue on my purple car
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 01-05-2011, 01:18 PM   #1754
Airwave's Avatar
That's why these ones could be better
Old 01-05-2011, 02:43 PM   #1755
Send a message via AIM to Matt W
Default Carpet setups
Hey guys,
has anyone got any good setup sheets for a high grip track with possibilities of traction roll?
Also has anyone got any of the carpet setups for alexandra stocker, freddy sudhoff, etc as u never see any of them online?
many thanks!!
Matt W is offline   Reply With Quote
