Old 01-03-2011, 01:48 PM   #1726
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Part numbers please.
thanks for the update
Originally Posted by Yokomo_Ant3 View Post
Guys do the mod i am about to do and you shouldnt have any problems with front driveshafts. I will be using Yokomo BD5 spool outdrives which are a direct fit onto the std spool with a litlle bit of sanding to get the pin hole to line up. Then use Tamiya/top/yokomo driveshafts. Should work sweet with no issues. Ill post pics when ive done it
Guys thinking of getting this car but are worried about driveshafts or weakness whatever, dont let it put you off, its a really good car and parts are now becoming available again at most shops. ALL of the touring cars on the market have a weak spot were they are designed to break in a crash Theres one solution... Dont
Cheers,
Antoni
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 01-03-2011, 03:01 PM   #1727
Hugh Jazz's Avatar
These are the out drives we are talking about http://www.rc-mushroom.com/product_i...ducts_id=19229
and these are the yoke cvds i am using http://www.rc-mushroom.com/product_i...ducts_id=16984
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 01-03-2011, 04:20 PM   #1728
PRC
PRC's Avatar
Default alloy hub and knuckle...
I've broken so many hub and knuckles on this car in the one month that i've own this car, it's getting ridiculous. My question would be - Has anyone upgraded their C hubs and Kuckles to alloy? And how would the front arms hold up on impact with those upgrades?
Hotbodies TCX,Tamiya DF03Ra, HPI RS4 Rally, Tamiya XV-01Pro, Tamiya F104 VerII pro, Tamiya F103Exotek, Tamiya F104pro, Exotek F1R, HPI F10 Exotek, Tamiya FF-03Pro
Futaba 3PKS, Spektrum
Hobbyking Nanotech lipos (If it ever gets here...)
Tekin, Hobbywing,tamiya silver can
PRC is offline   Reply With Quote
Old 01-03-2011, 04:50 PM   #1729
mangoman's Avatar
i hope you havent been buying the cheap cyclone s c-hubs?
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 01-03-2011, 04:57 PM   #1730
louielou's Avatar
Trader Rating: 16 (100%+)
Default c hubs
which c hubs r the strong ones, and does anyone where i can get the pro4 front arms? i ran those on my tc, those things never broke.
Luis
email-vegaloulou@aol.com
Ebay account LOU840
louielou is offline   Reply With Quote
Old 01-03-2011, 05:19 PM   #1731
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I too am using the Pro4 arms and they hold up. I bought a bunch of XRAY nuckles, the Hard type, and they are great. You will have to shim a bit but that allows bonus adjustment up and down.
I recently took an idea posted a few pages back and removed some of the steel from the HB outdrives to allow Hudy 52MM ECS drive shafts. I took HB pins and pressed them in the ECS bones. When you do an over all measurement, they are in between 44MM and 46MM HB drive shafts. I found it strange where the Hudy measurement began and ended to total 52 MM.
I have not yet broken a C-hub, they seem to be strong.
What you put on next may allow for something else to fail. I would consider that since we all are waiting for parts relief from HB.
I hope HB parts start appearing in the USA soon...
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 01-03-2011, 05:23 PM   #1732
CSF0623's Avatar
The c-hubs and steering blocks were carried over from the first Cyclone, so there is no change with that. As for the arms on the TCX they came from the last car the TC. Yes, they are a bit brittle (graphite) but you also have to remember it has more holes for different shock positions which also makes it more vulnerable for breakage. HB has the original plastic arm that came from the previous Cyclone that is alot more durable but has less options for tuning that you can use as well. The only other weak part of the car would have to be the 46mm drive shaft/bone on the TCX as mentioned before. I heard that HB will be bringing in steel 46mm drive shaft/bone soon, which should last alot longer than the aluminum one. I'll admit to breaking an arm since I have had the car (2 months) but this was due to a collision with another car that was parked on the track. So far I have had nothing but good luck with this car and have placed with some the best at WCRC and is far better then my Cyclone TC. Just my 2cents.
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 01-03-2011, 05:26 PM   #1733
Ty
Ty's Avatar
Trader Rating: 25 (100%+)
Since Tamiya steering knuckles fit do the c-hubs from the 416/417 fit the TCX as well? I know the plastic parts from the TA05 (the c-hubs) held up much better than the kit parts. Please let me know if anyone has tried the Tamiya c-hubs on the TCX.
Also, I ordered the Yokomo steel 45.5mm drive shafts (just the bone, not the whole axle assembly) and the Yokomo spool cups from driftspeed.com.
Antoni, are you certain the Yokomo steel drive shaft bone will fit with all the stock TCX axle and CVD internals? Do I need anything else besides the parts I ordered?
Ty is offline   Reply With Quote
Old 01-03-2011, 05:38 PM   #1734
evostyle's Avatar
Trader Rating: 102 (98%+)
TCX available in case anyone is interested.... Thanks
Hot Bodies TCX touring car TC sedan
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
evostyle is offline   Reply With Quote
Old 01-03-2011, 06:05 PM   #1735
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
http://rcmarket.com.hk/product_info.php?products_id=915
http://rcmarket.com.hk/product_info....oducts_id=6298
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 01-03-2011, 06:09 PM   #1736
Nope that is all you need. I have tested and the Yokomo driveshafts also fit in the Axle aswell as the Tamiya ones
Antoni Caretti
Old 01-03-2011, 06:47 PM   #1737
Ty
Ty's Avatar
Antoni,
Thanks for the help again. I also ordered some Tamiya plastic c-hubs and some Pro4 plastic c-hubs to test along with the carbon kit parts. I also bought some Tamiya steering knuckles too just in case I break another stock part. I did jam on a Parma Xray T2 hard bumper too (I made it fit basically). I hope that helps a bit too with front end protection. I will let everyone know how it goes.
The Tamiya steel bones are available from a great seller on eBay under the seller name of rdvtg. He is super fast on shipping. Just search his store for the Tamiya part number. His store address is http://stores.ebay.com/Rdvtg-Hobbies and like Antoni stated the part # is 51092.
Old 01-04-2011, 04:07 AM   #1738
John Doucakis's Avatar
Kit almost done
Electronics to be installed when I find what I am looking for.
Click on the photos for more..
John Doucakis is offline   Reply With Quote
Old 01-04-2011, 04:44 AM   #1739
dameetz's Avatar
Originally Posted by John Doucakis View Post
Kit almost done
What balls are you using on the shocks top and bottom?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 01-04-2011, 09:57 AM   #1740
cyclone speed's Avatar
Hello Everyone,
I just got a few questions that i cant find any answer ...
I went racing today ( not a race day, just went to the track for practice ), the track was very litle wet ( humid ), there were a few leaves on the track, and it was 4 celsius outside .
When I was going slowly, the car would handle well, but most of the time, when i would accelerate mid-exit of corner, the back end would slide out
When i would go 80% throtle and 20% steering, it was ok, but as soon as i was steering a litle too much, the back would go lose .
Is it a setup problem, traction problem or driving problem ? Could i higher front droop for more weight transfer at the back, or streignten the rear shocks ?
Thank you for any help
PS : Im runing 13.5 BL
By the way, most people have good looking weights with carbon, are they pre-prepared, or do people just stick carbon stickers ?
cyclone speed is offline   Reply With Quote
SEO by vBSEO 3.5.0
