Old 01-02-2011, 10:57 PM   #1711
pcar951's Avatar
Trader Rating: 19 (100%+)
Wow, 1 pack out of a drive shaft is not cool. I'd really like to try the TCX but, it's scary with so many fragile parts and very little inventory everywhere it seems.
pcar951 is offline   Reply With Quote
Old 01-02-2011, 11:29 PM   #1712
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Guys do the mod i am about to do and you shouldnt have any problems with front driveshafts. I will be using Yokomo BD5 spool outdrives which are a direct fit onto the std spool with a litlle bit of sanding to get the pin hole to line up. Then use Tamiya/top/yokomo driveshafts. Should work sweet with no issues. Ill post pics when ive done it
Guys thinking of getting this car but are worried about driveshafts or weakness whatever, dont let it put you off, its a really good car and parts are now becoming available again at most shops. ALL of the touring cars on the market have a weak spot were they are designed to break in a crash Theres one solution... Dont
Cheers,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-02-2011, 11:33 PM   #1713
Hugh Jazz's Avatar
Cheers,
Antoni
You beat me to it Antoni. I should have my spool cups by friday i hope ( with your sway bar mounts). Yoke CVDs are in my car now. I am going to go Yoke CVDs front and rear.
Dan Maher
Hugh Jazz is online now   Reply With Quote
Old 01-02-2011, 11:36 PM   #1714
Sweet thanks Dan. I have already sanded down some outdrives so ill do a test fit now. The internal diameter is a perfect fit onto the HB spool were as Tamiya spool outdrives need to be drilled out. And the Tamiya ones are a much weaker material and wear/snap way quicker.
Antoni Caretti
Old 01-02-2011, 11:39 PM   #1715
Hugh Jazz's Avatar
Yeah i tried them last night and thought i would wait for the new ones before i started to sand.
Dan Maher
Old 01-03-2011, 12:13 AM   #1716
Aaaand Presto
I went a lil too far when sanding the inside hence the small gap, but its all good The Yokomo outdrives require less shimming that the Tamiya ones also which is always a plus These outdrives would be similar in material to the POM Hotbodies ones.
Antoni Caretti
Old 01-03-2011, 03:09 AM   #1717
Default Hey Yokomo ANT 3
Where did you get those purple hex screws from, they look smart
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 01-03-2011, 03:48 AM   #1718
The purple screws are made by Square from RCMushroom
Antoni Caretti
Old 01-03-2011, 04:02 AM   #1719
The turnbuckles look a funy color
Team Crusty
starman is offline   Reply With Quote
Old 01-03-2011, 04:23 AM   #1720
Dog Bone's Avatar
I'm not entirely clear on what the benefit is of using the Yokomo outdrives.
Is it just that the Yokomo outdrives are longer, and you can us the 44mm HB drive shafts, or is the intention to completely remove the HB outdrives, drive shafts, and axles, and replace them with Yokomo parts?
I too have had problems with drive shafts breaking and bending, so I'm looking for a solution. I've ordered a bunch of replacement drive shafts, but I'm looking for a better solution.
Other than avoiding running into things, that is
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 01-03-2011, 04:28 AM   #1721
The diameter of the pin on the Hotbodies driveshafts are much bigger, so u cant use other driveshafts with the std spool cups unless u dremel them out and use a blade. And obviously the same reason vice versa so you need to change both items if you want to use a steel driveshaft of another company. The bones all fit the Hotbodies Axles. Those are the only parts you need to change and some shimming is required for the spool.
Hope that helps
Antoni
Antoni Caretti
Old 01-03-2011, 04:30 AM   #1722
Those are the Titanium Turnbuckles and because of the material they cant match the colour perfectly
Antoni Caretti
Old 01-03-2011, 04:37 AM   #1723
Dog Bone's Avatar
Hope that helps
Antoni
Yup, sure does.
Which Yokomo drive shafts did you use? I see that there's a 44mm and a 45.5mm version. And, you're using these outdrives, correct?
http://www.rc-mushroom.com/product_i...ducts_id=17327
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Old 01-03-2011, 04:47 AM   #1724
Yup, sure does.
Those are the ones. You just need to sand the bottom lip off a bit for the hole to line up. Im using Tamiya 46mm but 45.5mm are the Yokomo ones to get if you get Yokomo driveshafts.
Cheers,
Antoni
Antoni Caretti
Old 01-03-2011, 12:20 PM   #1725
cyclone speed's Avatar
Hello Everyone,
I just got a few questions that i cant find any answer ...
I went racing today ( not a race day, just went to the track for practice ), the track was very litle wet ( humid ), there were a few leaves on the track, and it was 4 celsius outside .
When I was going slowly, the car would handle well, but most of the time, when i would accelerate mid-exit of corner, the back end would slide out
When i would go 80% throtle and 20% steering, it was ok, but as soon as i was steering a litle too much, the back would go lose .
Is it a setup problem, traction problem or driving problem ? Could i higher front droop for more weight transfer at the back, or streignten the rear shocks ?
Thank you for any help
PS : Im runing 13.5 BL
cyclone speed is offline   Reply With Quote
