Old 12-29-2010, 08:40 PM   #1666
mangoman's Avatar
You didnt by any chance con ryan into loaning you his gear diff for a test did you?
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-30-2010, 02:37 AM   #1667
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
I already tested one at the Metro masters I will hopefully have one soon
Antoni Caretti
Team Schumacher - Team Scorpion - Sweep Racing - Bezerk RC - Adelaide RC
Yokomo_Ant3 is offline   Reply With Quote
Old 12-30-2010, 05:00 AM   #1668
san.'s Avatar
Trader Rating: 59 (100%+)
Does anyone of a buy link for the Spec R TCX Gear Diff?
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 12-30-2010, 08:54 AM   #1669
dameetz's Avatar
I m still building mine. Do you guys add more spacers in addition to the included 0.2mm spacers on the axle (between the wheel hex and the uprights), coz there's still play if I move the assemble wheel hex which is not to my liking.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 12-30-2010, 08:55 AM   #1670
dameetz's Avatar
Has Spec R made one for TCX already?
Old 12-30-2010, 08:59 AM   #1671
san.'s Avatar
Originally Posted by Airwave View Post
It seems that the Spec R gear diff is (finally) available for TCX!!!
No DIY anymore!!!
Just waiting on the link.
Old 12-30-2010, 09:00 AM   #1672
steveonamission's Avatar
I personally didnt, dont have hardly any movement myself.. maybe about .1
Only shimming i messed about with was for the steering rack, that thing is nasty after a couple of runs, so gave it some attention.
www.fuller-paint.blogspot.com
steveonamission is offline   Reply With Quote
Old 12-30-2010, 09:43 AM   #1673
dameetz's Avatar
Thanks, will do that.
Old 12-30-2010, 09:48 AM   #1674
AGNO's Avatar
The gear diff. Spec-R will be available in January, yet no link.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-30-2010, 11:01 AM   #1675
stitchy's Avatar
Hey Carl, since you didn't come by yesterday, I put your 46mm bones back online!
We also got some arms, diff screw sets, sway bar sets and belts in
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 12-30-2010, 12:08 PM   #1676
M3Armand's Avatar
Speaking of "play and not to liking", has anyone done anything about the play on the shock mounts? There's actually NO play in the direction of the shock movement, but all 4 shocks move forwards and backwards along the screw lines. I'm thinking it's pretty pathetic. But maybe there's a reason for this?
M3Armand is offline   Reply With Quote
Old 12-30-2010, 12:54 PM   #1677
jmackani's Avatar
Trader Rating: 14 (100%+)
I have also noticed the shock play. I was looking at my buddies and his does not have it. From what I can see, if you tighten the nuts farther it compresses the plastic and forms a bulge that takes the play right out. So, I think we just need to tighten them further.
jmackani is offline   Reply With Quote
Old 12-30-2010, 02:01 PM   #1678
AGNO's Avatar
You can reduce the movement of the shock by making a cut with a cutter as shown in the drawing, but I would not worry so much about this movement also serves to self-center shock absorbers during movement.
http://www.rctech.net/forum/attachme...1&d=1293746183
Old 12-30-2010, 02:02 PM   #1679
M3Armand's Avatar
I thought about "compressing" the plastic.... But then that would add unnecessary friction since it's the "pivot" point for the shock... I was thinking of adding rubber grommets (or an O ring), but I'm wondering what the "official" assembly is supposed to be.
Can any factory driver chime in here?
Old 12-30-2010, 02:46 PM   #1680
im confused on this part... checking mine, they are correct length, so when i tighten the nut to the start of the shock plastic mounts, the only movement the shock has then is the correct amount of pivot movement... strange.
