Old 12-28-2010, 03:28 PM   #1651
CSF0623's Avatar
Originally Posted by stitchy View Post
got it ha.
should have 8 left.
I'll take all 8!
Carl F.
ACTIVRC.COM P1BRAND
CSF0623 is offline   Reply With Quote
Old 12-28-2010, 04:59 PM   #1652
Mike Haynes's Avatar
Originally Posted by goin2drt View Post
amain just got a ton of parts in. Many parts have been on backorder forever but most are back in. Unfortunately the axles are not.
If it helps the top stub axle is a direct fit, and has 2 sets of pin holes
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 12-28-2010, 05:10 PM   #1653
stitchy's Avatar
these axles?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 12-28-2010, 09:16 PM   #1654
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by M3Armand View Post
You know, as I am building my TCX now, i am finding it annoying that the "standard" kit setup doesn't contain the parts that the pros are using as their "base" setup. So not only is the kit $460ish, but now we will need to cough up more money for additional items no matter how small (for ex- 40w shock oil, 3 hole pistons, springs, and they don't even include cheap allen wrenches)
Yeah,
I come from an xray t2 009 and to tell you the truth, the instructions and parts quality are inferior for the tcx. The setup details are nothing. Items like no instuctions for setting shock rebound and even measuring droop from two different points on the hubs can mislead people. I do run a ve8 and this is why I switched touring cars. Next season I may be back to xray.
jmackani is offline   Reply With Quote
Old 12-28-2010, 09:21 PM   #1655
jmackani's Avatar
Dunno if I could agree since I haven't put the car on the track yet. But the differences I've noted so far are:
Pro setup vs standard
1) Shock piston - pros seem to use the slightly thinner 1.1mm thickness piston with 3 holes vs 1.2 mm x 2 holes
2) Shock oil - 40 wt vs 30 wt
3) Droop - 8.5 mm vs 6 mm
4) Front shock mount - #3 vs #5 position
5) Rear shock mount - #3 vs #6 position
6) Front toe block - 1.5/2.0 vs 2.5 degrees
7) Front drivetrain purple spacers - 1 mm vs 1.5 mm
8) Front hinge pin spacers - various vs .75mm/2mm
9) Rear hinge pin spacers - various vs .75mm/2mm
10) Rear diff - gear diff vs ball diff
11) Front springs - pink vs gold
So from above, at minimum we'd need to additionally buy 1, 2, 6, 10 and 11... Seems like quite a bit of changes to me!
I'm just saying that for the $$$ spent, I think they should have at least included the damn pink springs, 3 hole pistons, additional purple spacers, 40 wt shock oil and front toe blocks.
I'm surprised that the kit came with double sided sticky tape!
That droop difference is really not much. The setup sheet measures droop from the center of the arm, whereas the instruction manual measures from the bottom of the arm. It's about 3mm from what I can see. So, 9mm or 6mm is the same depending on where you measure from.
Old 12-29-2010, 04:09 AM   #1656
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
set ups develop over time, you cant expect a car to come with everything you need for a particular set up......
nearly all the guys in europe have gone back to a ball diff.
springs, thats completely track vaiable, a non issue
same with the shock oil, a non issue.
the kit set up is designed to work reasonably well at a large amount of tracks and surfaces. not just specific for carpet or tarmac.
the only thing i would say "should" come with the kit, is 1.1x3 pistons.
hth
luke
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 12-29-2010, 05:54 AM   #1657
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Got bored so i decided to take a few pictures of my car. Hanging out to drive it again, only done a few runs in it Enjoy!
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 12-29-2010, 06:48 AM   #1658
Trader Rating: 77 (100%+)
What are those two pieces mounted to the rear shock tower in the last two pics? Car looks nice. I need of that CF tape to put on my servo, looks good.
goin2drt is offline   Reply With Quote
Old 12-29-2010, 06:55 AM   #1659
unknownmember's Avatar
Originally Posted by san. View Post
Black 44mm in stock..........We are all waiting on the 46mm's.
Thanks for the heads up dude, but only if I need the 44. But gonna get them anyways, need lots of spares.
unknownmember is offline   Reply With Quote
Old 12-29-2010, 07:32 AM   #1660
san.'s Avatar
Trader Rating: 59 (100%+)
The top purple rails are called "body stiffners". Most people use them when they run lighter/thinner bodies. The other two black posts help prevent body tucks.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 12-29-2010, 07:33 AM   #1661
Anybody found the stock wishbones to be brittle? I broke one front and two rears last night. The front was totally my fault, but the rears were a light brush on a track marker and they broke at the inner hinge pin holes.
Is there a more flexible alternative avaliable?
markrobinson is offline   Reply With Quote
Old 12-29-2010, 07:40 AM   #1662
san.'s Avatar
If by wishbone you mean suspension arms, then go with the Cyclone/Pro 4 carbon graphite:
https://www.ssl-stormerhobbies.com/c...ns&pn=HPI73506
The part# is HPI73506
In some cases, you might have to tweak your setup a bit when using these arms.
Old 12-29-2010, 08:07 AM   #1663
steveonamission's Avatar
There isnt alot of material for the hingepin to go through i agree, so especially in a light brush (i find these the worst crashes) leading to a sudden yank on the suspension from a wheel catching the corner, they dont have much chance.
As said above, if your going though them, then best bet is to try the PRO 4/Orginal Cyclone wishbones, they are alot beefier allround then the TC/TCX ones. Though i guess they change the geometry?
steveonamission is offline   Reply With Quote
Old 12-29-2010, 09:59 AM   #1664
Thanks for the suggestion guys. Will look into these
Old 12-29-2010, 03:24 PM   #1665
San already explained what both are The Body posts are Corally parts
For anyone else interested the Carbon steering brace is made by Smokem Racing. http://www.smokem-racing.com/SB.html
Cheers,
Antoni
Antoni Caretti
