Old 12-25-2010, 01:42 PM   #1621
Trader Rating: 45 (100%+)
Originally Posted by M3Armand View Post
You know, as I am building my TCX now, i am finding it annoying that the "standard" kit setup doesn't contain the parts that the pros are using as their "base" setup. So not only is the kit $460ish, but now we will need to cough up more money for additional items no matter how small (for ex- 40w shock oil, 3 hole pistons, springs, and they don't even include cheap allen wrenches)
Yeah, I know what you mean. You look at Hara's cars and they are all decked out with the titanium nitride shock and suspension shafts. Now that I think about it the 417 price is not that bad since it comes with all the hop-ups. I think I spent atleast another $200 on top of the $460.
Apex is offline   Reply With Quote
Old 12-26-2010, 01:39 AM   #1622
AGNO's Avatar
The TCX works very well with the standard setup, the hop up is not essential, just more "cool", even the 417 has the hop up available in addition to lots of aftermarket hop up.
Regarding the different springs, no model provides the complete set ( many Tamiya drivers use spring HPI / HB ...)
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-26-2010, 07:08 AM   #1623
SammyZ's Avatar
Trader Rating: 138 (100%+)
the hop ups ARE essential because the car simply does not look as cool as it possibly could. Im more of a pit racer anyways
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 12-26-2010, 08:16 AM   #1624
LOL, mainly bought the essential stuff for mod - aluminum rear diff, titanium susp and shock shafts, teflon shock bodies, titanium camber and steering rods, pom spool parts, and titanium screws for bulkheads and shock attachments. Kinda sucks my local track is mainly going off-road 24x7 so the on-road stuff will sit on the shelf until spring.
Old 12-26-2010, 01:54 PM   #1625
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
+1 Pit racing is where its at
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 12-26-2010, 02:35 PM   #1626
haywood's Avatar
Trader Rating: 48 (100%+)
Could we get a shot of your ride?
haywood is offline   Reply With Quote
Old 12-26-2010, 03:02 PM   #1627
SammyZ's Avatar
Hotbodies USA
SweepRacing USA
Old 12-26-2010, 03:09 PM   #1628
M3Armand's Avatar
Dunno if I could agree since I haven't put the car on the track yet. But the differences I've noted so far are:
Pro setup vs standard
1) Shock piston - pros seem to use the slightly thinner 1.1mm thickness piston with 3 holes vs 1.2 mm x 2 holes
2) Shock oil - 40 wt vs 30 wt
3) Droop - 8.5 mm vs 6 mm
4) Front shock mount - #3 vs #5 position
5) Rear shock mount - #3 vs #6 position
6) Front toe block - 1.5/2.0 vs 2.5 degrees
7) Front drivetrain purple spacers - 1 mm vs 1.5 mm
8) Front hinge pin spacers - various vs .75mm/2mm
9) Rear hinge pin spacers - various vs .75mm/2mm
10) Rear diff - gear diff vs ball diff
11) Front springs - pink vs gold
So from above, at minimum we'd need to additionally buy 1, 2, 6, 10 and 11... Seems like quite a bit of changes to me!
I'm just saying that for the $$$ spent, I think they should have at least included the damn pink springs, 3 hole pistons, additional purple spacers, 40 wt shock oil and front toe blocks.
I'm surprised that the kit came with double sided sticky tape!
M3Armand is offline   Reply With Quote
Old 12-26-2010, 03:33 PM   #1629
haywood's Avatar
That is sweet!
Old 12-26-2010, 03:55 PM   #1630
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
i know this might not be the best thread...but has anyone tried putting the 20t center pullies on a standard cyclone? if so, anything else needed besides the pulley and center shaft??
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-26-2010, 08:30 PM   #1631
SammyZ's Avatar
^^^best name on rctech hands down
Hotbodies USA
SweepRacing USA
Old 12-27-2010, 05:56 AM   #1632
AGNO's Avatar
I tried the standard setup and works very well, of course every pilot makes slight adjustments to better adapt it to their driving, regardless of the brand of the model.
The behavior of the shock is very similar between the 3 holes with 40wt and 2 holes with 30wt not need to replace them, depending on the track and driving feel, the same thing about the springs.
The differential gear does not always work well, Hara always uses the standard POM ball and wins...
Exrtra springs, extra oils and differential gear are optional on all models.
Old 12-27-2010, 08:31 AM   #1633
jag88's Avatar
Is that an RC12E ?
jag88 is offline   Reply With Quote
Old 12-27-2010, 09:00 AM   #1634
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Belts and make sure the shaft is drilled straight.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 12-27-2010, 09:21 AM   #1635
SammyZ's Avatar
is anybody else having trouble clicking on the "login" link on hotbodiesonline.com? I cant login, click on parts, or do anything
really on the website.
Hotbodies USA
SweepRacing USA
