Old 12-24-2010, 10:29 AM   #1606
Dog Bone's Avatar
Everything is out of stock right now. To be honest, I'm really disappointed in the parts support for the new chassis...
Hopefully this situation rectifies itself in the next month or so - I really only need the 46mm bones, so hopefully those are restocked soon...
Ken Miller
T4 2015
CRC Xti WC/GenX-10
Dog Bone is offline   Reply With Quote
Old 12-24-2010, 10:55 AM   #1607
mac853's Avatar
Questions??
Originally Posted by AGNO View Post
I positioned the bearing holder to the maximum possible position and the belt is properly tensioned, At the rear, I chose one step less the maximum position getting the correct tension.
In fact i have TCX now but not starting building yet, i want using gear diff in front, so i decided now, after chatting with you, using 38T pulley gear diff in front and original diff cup with 38T pulley of Sakura in rear.
Unfortunately, as you said new 39T could not worth due larger pitch, so i said before "larger belt in front", just because i think just put 39T gear diff of 3racing could help little with small adjustment in bearing holder even is different pitch, to keeping original pulley in the rear, but you said is not enough and worth, is too tight.
Anyway, thanks from your help!
mac853 is offline   Reply With Quote
Old 12-24-2010, 10:58 AM   #1608
mac853's Avatar
Questions??
Could sakura ones of 3racing, maybe HD ones, i heard it's too 46mm with same size of diff cup cushion.
Could Somebody confirm if is possible using 3racing's bones and roller joints, please?
Best regards
Old 12-24-2010, 12:16 PM   #1609
AGNO's Avatar
Unfortunately the new 39T pulleys 3Racing are not really usable (at least my two), are completely wrong, I noticed that the centering of the hole for the axle is wrong, in addition to the pitch and the diameter of the pulley.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-24-2010, 01:26 PM   #1610
SammyZ's Avatar
Trader Rating: 138 (100%+)
sadly, parts are hard to get for all Japanese touring cars.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 12-24-2010, 01:37 PM   #1611
jmackani's Avatar
Trader Rating: 14 (100%+)
Does anyone think that hot bodies will come out with a gear diff to get around all the hack type solutions that people are improvising with?
jmackani is offline   Reply With Quote
Old 12-24-2010, 01:48 PM   #1612
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Anyone know if these will fit the TCX? Any mods necessary?
http://os.3racing.hk/products.php?products_key=4963
Ty is offline   Reply With Quote
Old 12-24-2010, 02:18 PM   #1613
AGNO's Avatar
In January you will come out differential gear Spec-R
Old 12-24-2010, 02:35 PM   #1614
jmackani's Avatar
Thanks Agno. I noticed most setups are running pink springs. Is there a chart of spring rates anywhere? Springs seem to be hard to find in stock, so I have an xray also that I may be able to use something with the same rate if I could get the numbers.
Old 12-24-2010, 02:39 PM   #1615
mac853's Avatar
I am also asking but only the bones and roller joint, not the shaft.
Old 12-24-2010, 04:35 PM   #1616
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
the pin is not as big as on the HB driveshaft........
if you have some broke HB shafts, push the pin through, then get your tamiya, 3 racing or what ever 46mm steel shafts, push the pin through, and re-drill the shaft for the correct size pin.
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 12-25-2010, 01:06 AM   #1617
AGNO's Avatar
Spring chart HPI/HB Hara
http://www.rctech.net/forum/attachme...1&d=1293267857
Old 12-25-2010, 01:52 AM   #1618
mac853's Avatar
In fact i have describe Sakura's diff cushion could fit in tamiya's bones, why don't we use TRF 46mm steel bones with Sakura's cushion, be possible?
Best regards and Merry X'mas
Old 12-25-2010, 09:57 AM   #1619
MikeR's Avatar
Most items are in stock south of the border;
stormerhobbies.com
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-25-2010, 12:26 PM   #1620
M3Armand's Avatar
You know, as I am building my TCX now, i am finding it annoying that the "standard" kit setup doesn't contain the parts that the pros are using as their "base" setup. So not only is the kit $460ish, but now we will need to cough up more money for additional items no matter how small (for ex- 40w shock oil, 3 hole pistons, springs, and they don't even include cheap allen wrenches)
M3Armand is offline   Reply With Quote
