Old 12-05-2010, 10:40 PM   #1501
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by littlealex View Post
can you tell where does it need to be shimmed? thank you
I would say side to side it has a little bit of play. So a shim just to take up the slop will do the trick. They are 10mm shims i believe.
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 12-05-2010, 10:51 PM   #1502
ark
Sorry, shim the spool. 10x15 shims are the go as Ant mentioned.
ark is offline   Reply With Quote
Old 12-05-2010, 11:05 PM   #1503
Hugh Jazz's Avatar
Originally Posted by mangoman View Post
Do you mean 67717?
http://www.hpieurope.com/piw.php?lang=en&partNo=31420
I was always of the impression the softer high traction arms were more durable.
If you can even get them anymore. Been a while since i played with my cyclone
Not that i ever broke a suspension arm.
Thats because you are to slow
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 12-05-2010, 11:09 PM   #1504
crabboy's Avatar
Trader Rating: 58 (98%+)
Originally Posted by ark View Post
Hi guys a little more progress on the car. For those of you looking for an alternative for the front end I have fitted a T3 spool and Hudy spring steel 52mm shafts for a stronger replacement of the original alloy 46mm shafts. All is needed is a little shimming of around .5-.75. This is a 38t pulley to work with the gear diff. Just pity there is a little less Purple on the car now
Thanks for the parts Ant
Wow good work Ark looks like you have a lot of resources at your disposal.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 12-06-2010, 12:52 AM   #1505
mangoman's Avatar
As opposed to someone who has to borrow someone elses car for spare parts! :P
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-06-2010, 11:58 AM   #1506
AGNO's Avatar
Hello guys, I attended the second carpet indoor race with TCX, Sorex 36 tires in 17.5 SuperStock category, performance is much improved thanks to your advice and especially to those of Hiro, the car was very fun and easy to drive, with a lot of grip at the rear, I could easily hit the A-Main with the sixth place, but unfortunately I was ranked seventh for a bad result in a final, the other two I hit a fifth and a sixth.
Below I posted my setup, I think is an excellent starting point, makes the model it very easy to drive, then you can gradually move to set up Hara IIC will make the car faster but a bit more aggressive to drive.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-06-2010, 02:15 PM   #1507
2xs
When adjusting the roll center on these cars which adjustment has a larger effect, moving the lower arms or the camber links?
2xs is offline   Reply With Quote
Old 12-07-2010, 09:59 PM   #1508
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Do you mean spacing the arm up and down VS the inner link spacers?
Jaz406 is offline   Reply With Quote
Old 12-07-2010, 10:23 PM   #1509
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Lower...
SchuMi2 is offline   Reply With Quote
Old 12-08-2010, 06:28 AM   #1510
2xs
Originally Posted by SchuMi2 View Post
Lower...
Thank you.
Old 12-08-2010, 12:44 PM   #1511
So, I am a new TCX owner who has managed to destroy a front drive shaft. I have read about all of my options and the only one that seems remotely possible in my time frame (this Sunday) is to modify the universal drive shafts from a TOP Photon.
Amainhobbies has T.O.P Racing Products Universal Shaft Set V3 (2)
[TRP-PO-SDT020] for sale. Is this the right part for me?
Also,I heard that if I do this I will need to trim the plastic blade. Where does this blade come from? Is it in my TCX kit or does it come with the parts from TOP?
Worst case scenario can I remove both my front drive shafts and run my car as a 2wd?
decion is offline   Reply With Quote
Old 12-08-2010, 01:08 PM   #1512
Trader Rating: 45 (100%+)
You can replace the driveshaft with these steel driveshafts which are used on the Pro-D and are direct fit. HPI 88914 Drive Shaft
http://rcmarket.com.hk/product_info....oducts_id=3977
Apex is offline   Reply With Quote
Old 12-08-2010, 03:35 PM   #1513
Are those 46mm?
Antoni Caretti
Old 12-08-2010, 03:36 PM   #1514
san.'s Avatar
Trader Rating: 59 (100%+)
Originally Posted by Yokomo_Ant3 View Post
Are those 46mm?
Yes, they are.
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
Old 12-08-2010, 03:39 PM   #1515
Originally Posted by san. View Post
Yes, they are.
Awesome, Thanks. Now i just need to find them in stock somewere
Antoni Caretti
