Old 12-03-2010, 01:08 AM   #1486
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Where can setups be found for this car? Looking for Hara's IIC setup and asphalt setups.
Thanks,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 12-03-2010, 01:22 AM   #1487
Ryan Maker's Avatar
Send a message via MSN to Ryan Maker
Thanks,
Antoni
Petit RC Caretti
http://www.petitrc.com/reglages/hotb...tBodiesTCX.htm
Shake.
Awesomatix - Muchmore - Protoform - Silverback - Radtec - LeeSpeed - Hiro Seiko - SG PitDesign - Plaig
RC MAKER - www.rcmaker.com.au
AWESOMATIX - R1 WURKS - VOLANTE
Ryan Maker is offline   Reply With Quote
Old 12-03-2010, 01:29 AM   #1488
Originally Posted by Ryan Maker View Post
Haha yea i just found them
Thanks bro
Antoni Caretti
Old 12-04-2010, 11:51 AM   #1489
John Doucakis's Avatar
Default Body compatibility TC - TCX
Can someone confirm whether the body posts from the TC are in the same position as in the TCX and also in relation to the car's wheelbase?
In other words, is a TC body a direct fit to a TCX ?
Thanks,
John
John Doucakis is offline   Reply With Quote
Old 12-04-2010, 12:22 PM   #1490
AGNO's Avatar
Thanks,
John
Yes, they are identical.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 12-05-2010, 05:34 AM   #1491
Bubblehead's Avatar
Does anyone know who has the following in stock? part #68734 Universal Drive Shaft 46mm
Bubblehead is offline   Reply With Quote
Old 12-05-2010, 12:25 PM   #1492
Question, which set of arms are the better on impact.
#67719 graphite or #73506 carbon graphite
silky is offline   Reply With Quote
Old 12-05-2010, 01:09 PM   #1493
san.'s Avatar
Trader Rating: 60 (100%+)
The 73506 are a bit stronger.
Awesomatix USA||Roche RC USA||Mon-Tech Racing USA||Sanwa
san. is offline   Reply With Quote
Old 12-05-2010, 02:09 PM   #1494
peter.'s Avatar
hello is the spec-r geardiff already available for the TCX
and where is this vor sale
peter. is offline   Reply With Quote
Old 12-05-2010, 02:32 PM   #1495
ark
Originally Posted by ark View Post
Hi guys I thought Id share my gear diff conversion with everybody. Its a Spec R Xray 38tooth diff giving a 1.9 final drive and no need to change any belts. The diff needs about 1 mm of shimming. Xray 50mm driveshafts and blades. The driveshafts are a perfect fit into the axles. Front pulley is a xray ball diff pulley which has had the centre hole enlarged a little with a body reamer and elongate two holes for the screws.
Hi guys a little more progress on the car. For those of you looking for an alternative for the front end I have fitted a T3 spool and Hudy spring steel 52mm shafts for a stronger replacement of the original alloy 46mm shafts. All is needed is a little shimming of around .5-.75. This is a 38t pulley to work with the gear diff. Just pity there is a little less Purple on the car now
Thanks for the parts Ant
ark is offline   Reply With Quote
Old 12-05-2010, 02:53 PM   #1496
peter.'s Avatar
thanx ark but I knew that all I want the original that made especially for the TCX will like to trf416 t3 yokomo
Old 12-05-2010, 03:09 PM   #1497
mangoman's Avatar
Do you mean 67717?
http://www.hpieurope.com/piw.php?lang=en&partNo=31420
I was always of the impression the softer high traction arms were more durable.
If you can even get them anymore. Been a while since i played with my cyclone
Not that i ever broke a suspension arm.
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 12-05-2010, 03:22 PM   #1498
Looking sweet Dman. At least you wont have to worry about driveshafts shearing during a race Looking forward to my car arriving and experimenting with it
Antoni Caretti
Old 12-05-2010, 03:58 PM   #1499
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
In search for shock springs for tight indoor carpet track. I found a setup that runs silver and blue springs. Also the pink linear spring. What is the difference with the regular springs and linear springs. I see setups with blue and pink but it does not say linear.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 12-05-2010, 08:53 PM   #1500
Suspended
Trader Rating: 86 (100%+)
can you tell where does it need to be shimmed? thank you
littlealex is offline   Reply With Quote
