Old 05-29-2010, 06:00 AM   #136
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Originally Posted by JayL View Post
I am worried it uses the same suspension parts....
I see cyclone knuckles break every race day, many
also I see many cyclone parts where the left is 1 degree and the right is .5 degrees, not accurate
I have not broken one Cyclone part, and I rail on the walls with the 4.0. Felt a couple TCX's. There nice. You will be fine on parts man.
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 05-29-2010, 07:15 AM   #137
mild seven's Avatar
Trader Rating: 62 (100%+)
Send a message via MSN to mild seven
the plastic parts from HPI are very good quality i reckon. more durable than Tamiya yet still have fairly good flex and less wear.
mild seven is offline   Reply With Quote
Old 05-29-2010, 08:34 AM   #138
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by Tony Vega View Post
Had the TCX in my hands thanks to Hiro from HB who is at the Reedy Race. Very nice indeed. I'll be waiting patiently for one.
i, unfortunately will NOT be waiting patiently, when is this thing coming out?!
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 05-29-2010, 09:23 AM   #139
should be end of june or early july...hopefully.
Kiznasty is offline   Reply With Quote
Old 05-29-2010, 09:38 PM   #140
Trader Rating: 26 (100%+)
I was hanging out at the REEDY Race today and the HB crew said it will not be released until the end of August 2010.
JoeyE is offline   Reply With Quote
Old 05-29-2010, 10:35 PM   #141
Slideaway's Avatar
Yeah, it seems to be longer than expected... ...We cannot do anything anyway so, let's try to be patient.
I confirm there's a slight toe-in angle difference on the Cyclone rear hub.
You can meet 0.5/1 difference from left to right because the pin in the molding tool is not 100% normal to the wheel axis.
But you can get things ok using the right reamer on both hubs. Then the pressure socket screw on the suspension shaft will put everything in the right alignment.
Or you can choose the purple anodised alu hub too. But mind the suspension flex...
Ludo
Thai Ride Tech Support.
Slideaway is offline   Reply With Quote
Old 05-30-2010, 12:37 AM   #142
"I confirm there's a slight toe-in angle difference on the Cyclone rear hub."
That has always been a problem since day one. Most of us use the aluminum set to take away the slight toe angle. I hope they solve this with the TCX.
Old 05-30-2010, 04:39 AM   #143
slakr's Avatar
Trader Rating: 28 (100%+)
OUCH
I see the Aluminum Rear Hub Carriers in 0 & 1... what degree are the stock kit pieces?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 05-30-2010, 05:03 AM   #144
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
zero is stock on the other Cyclones - don't know why they'd change it here, considering toe-in is really adjusted by the suspension parts, not in the rear hubs
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 05-30-2010, 05:07 AM   #145
cosmo1974's Avatar
Location: Adelaide AUSTRALIA (5.754 mins SE of The Parks)
Arrow
Korey has an explanation of inboard and outboard rear toe here:
Hot Bodies Cyclone
"I'm either retired or unemployed, depending on when the money runs out !" > AERCCC_#25 > LargeOutdoorAsphaltTrack > CycloneTC + TekinRS_HWXerun_ESCs + Duo2_17.5 + SMC_Fantom_LiPos + BLS551 + MX3FG + TC1030 + MM >> =======TRACK_VIEW_FROM_SPACE========> http://www.nearmap.com/?q=@-34.857766,138.560313&ll=-34.857766,138.560313&z=19&t=h&nmd=20100614
cosmo1974 is offline   Reply With Quote
Old 05-30-2010, 05:11 AM   #146
k_bojar's Avatar
Hot Bodies Cyclone
i realize that you can adjust toe in both places, but he did ask about the stock pieces.
I should have clarified my statement by saying that its limited toe-in adjustment in the hubs - the major adjustments are handled via the suspension blocks
its all good
Old 05-30-2010, 06:35 AM   #147
slakr's Avatar
Yes, my specific question was what degree are the stock pieces... thanks K.
The explanation by Korey was good info too... thanks for that cosmo.
Old 06-02-2010, 07:07 PM   #148
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Is there a release Date for the TCx
Or should we be waiting till after the World's before release?
v-dezign // black diamond
Hoot RC for Local Supplies > www.hootrc.com.au
Me_MrTyson is offline   Reply With Quote
Old 06-02-2010, 07:12 PM   #149
Slideaway's Avatar
I heard "End of July" but other people heard "End of August" during the Reedy race... So after the Worlds for sure.
Ludo
Old 06-02-2010, 07:16 PM   #150
Hebiki's Avatar
Worlds is on 7/22? Not sure if that's right?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
