XXX-S threaded shocks
I bought the .28 threaded front shocks, #LOS5052 and the .36 threaded rear shcoks, #LOS5053 from Stormer and had a question acout what I got. The fronts came with the short threaded tubes, nuts and the caps. The rears only came with the threaded tubes and the nuts. Was I supposed to get the shafts with each of these sets aand also the caps for the rear shocks or is this right?
Also, do I need to run the shorter .28 shock shafts in the front .28 threaded tubes? I currently have the stock shafts in both the front and rear.
Thanks for any help,
Rob
Rob
Ok, thanks. So now I assume I need to buy the .28 shafts for the front shocks for them to work properly?
That is correct, you need the short shock shafts for the front only. It would have been better to order the entire kit mentioned above, but you can still get the parts needed.
Flash
Flash
Regional Moderator
A-5081
