Old 03-28-2010, 12:44 PM   #1
*BBB*'s Avatar
Default Debating: TC3 Nitro vs Electric
Trying to decide which to get.. Will the nitro version with a OS .18tz n racing pipe be as fast? or faster? than a good electric setup?
Thanks for your opinions
[ Inferno VE MM2650 ][ Inferno GT2e MM2200 ][ XO-1 ][ Baja 5B ][ Baja 5Te ][ Jato ][ Grave Digger ][ MERV ]
*BBB* is offline   Reply With Quote
Old 03-28-2010, 01:10 PM   #2
Trader Rating: 38 (100%+)
Electric with the proper motor is faster and less hassle than a nitro car.
or8ital is offline   Reply With Quote
Old 03-28-2010, 07:33 PM   #3
Default Fast TC3s
+1 on the electric. Even a mild electric motor will deliver quicker lap times than a nitro mill. The nitro sounds cooler and might be about as fast on a large oval, but electric gives you a lit more options.
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Old 03-29-2010, 06:50 AM   #4
snoopyrc's Avatar
The single biggest advantage that I can find to a Nitro car is that when you run out of juice you just squirt it again and run some more. You can get more punch and more speed from an electric with a hot brushless setup. Raw torque and acceleration. Boo Yaaaaa !!
Of course the key here is a GOOD electric set up. Nitro will run all over a weak electric system.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
SEO by vBSEO 3.5.0
