Old 03-18-2002, 07:03 PM   #1
Default tc2 problem!!!!!!!!!!
while i was playing with my mr-4tc today after replacing wires, my power capacitator blew and some liquid that smelled like a stink bomb came out. After an inspection, i saw where it exploded. do i have to send in the speedo and does this effect the speedo or can i just replace it?
was ist los? is offline   Reply With Quote
Old 03-19-2002, 11:50 AM   #2
Charlie's Avatar
It's possible that the Capcitor went bad. You can change it and try it again. If the cap fails again there may be an internal problem with the ESC. You can find complete Novak Service Info in the SERVICE section of www.teamnovak.com
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 03-20-2002, 09:43 AM   #3
Send a message via AIM to rctaylor
Hey Charlie,
What happened to the Novak forum?
I remember it was up not too long ago, but i can't acess it now.
Was there too much flaming or something?
rctaylor is offline   Reply With Quote
Old 03-20-2002, 09:52 AM   #4
benraldo the ho's Avatar
Send a message via AIM to benraldo the ho
when swapping wires around did you reverse polarity to the cap? that may be what caused it to blow. check your wiring job to make sure your wires arent crossing posts.
benraldo the ho is offline   Reply With Quote
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 07:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 08:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 06:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 04:08 AM
SEO by vBSEO 3.5.0
